Question about Braun SE 7181 WD Silk Epil 7 Epilator Xpressive Pro OrangeCopper
Braun Troubleshooting i charge the unit for a very lone time and it takes only 20 seconds of use before it starts flashing red again
    Top Expert:
  • Braun Master
  • 12,962 Answers
The rechargeable battery inside unit has reached the end of its usefulness and needs to be replaced.
Posted on Nov 25, 2013
Reset light has appeared.What action is required ?
There is no Reset Light as far as I know and the manual seems to indicate the same. I have a series 5. The green light shines when you are using it. The red light flashes when the power in the battery is less than 20%. Put it on to charge and the light will flash green until it is fully charged and then the light will be solid green.
All of the manuals are here from Braun
http://www.service.braun.com/product/search.asp?rg=NA&c=US&l=GB&typ=ui&frmTyp=subgrp&sgrp=subgrp&grp=SH01%3C%7C%3ESH02%3C%7C%3ESH03%3C%7C%3ESH04%3C%7C%3ESH08%3C%7C%3E&s=&subgrp=Series+7%2C+9000+series+-+Pulsonic%2FProsonic%2CActive+P
This manual page is showing the light indicators.
http://www.manualslib.com/manual/20437/Braun-Series-7-720.html?page=8#manual
Braun SERIES 7 720 User Manual Page 8
Apr 01, 2016 | Braun Series 7 720 Electric Rechargeable...
Why have I got a red light on the bottom of my shaver when I am using it
It is common for many Braun shavers, that if the indicator light flashes red while the shaver is being used (switched on and running), it means the battery is low and needs to be charged soon.
Below is an example from a manual for a Braun model 7526 shaver. You can search that site for other manuals if this is not the correct one.
This model shaver has 3 indicator lights:
1) Green (Charging)
2) Red (Low battery)
3) Blue (Power cord attached and plugged into the wall)
Download the manual for the model 7526 here: http://www.manualslib.com/manual/20281/Braun-5301.html#manual
"The green charging light shows that the
shaver is being charged. When the rechargeable
battery is fully charged, the charging light
flashes or goes off.
If later on, the charging light comes on
again, this indicates that the shaver is
being recharged to maintain its full
capacity.
The red low-charge light flashes when the
battery capacity has dropped below 20%,
provided the shaver is switched on. The
remaining capacity will then be sufficient
for 2 to 3 shaves."
Nov 09, 2015 | Braun Health & Beauty
I have purchased a Braun proffessional care electric toothbrush and cannot charge it. I have tried three different plug adapters. I have changed the toothbrush at Boots 3 times. I have tried to charge it...
Your electrical socket may be wrongly wired, with polarity mixed up. Try another socket. Also, some electric toothbrushes need to be "off" to successfully charge. Maybe the flasing red light for 10 seconds is telling you the toothbrush is "on" and not accepting charge.
Sep 12, 2017 | Oral B Braun B Professional Care 500...
How can I change my American Red Cross Ear thermometer from celcius to farenheit?
most thermometers have two buttons on and the take temperature, while its off hold the take temp. button for 10 to 15 seconds until it starts flashing Celsius or Fahrenheit when this happens use the take temp. button to choose either do not turn off the unit it will take a moment to set when it starts flashing again it is safe to turn off.
by the way it has very bad reviews does not seem to be a safe product-read http://www.amazon.com/American-Red-Cross-Instant-Thermometer/dp/B000KI8XME%3FSubscriptionId%3DAKIAJCOD6AQT3BOEWUXQ%26tag%3Deashomdec-20%26linkCode%3Dxm2%26camp%3D2025%26creative%3D165953%26creativeASIN%3DB000KI8XME
Jan 11, 2011 | Toys
My SB600 seldom firing when triggered manually on the red flash button. Only 2 or 3 times flashing after 30 attempt. Tried with new battery but same problem occured. Help.
If you are firing the flash manually it's giving full burst each time and the battery needs to pick up the charge from the bottom. So just numbers her for an example with a full set of batteries you manually flash, first burst takes 5 seconds to charge flash again it'll take 10 seconds, if you flash it again before that 10 seconds it'll now take 20 seconds and if you push that button again it might misfire because it just can't get the power up high enough to fire it. The flash isn't a studio strobe which is plugged into an outlet, you are working with battery power and each time you flash those batteries are under a huge load and each time you fire you kill them a little more I'm surprised you are getting 30 flashes from those batteries. My guess at full power you are going to start having problems after about 12 to 15 flash bursts and it's a rapid down hill drop in performance from then on. If you took those batteries out of the flash after that series of 30 flashes I'll bet they are hot. What you can do to help is set the system up with Nikon's wireless transmitter and utilize the new i-TTL system then you are taking performance.
Jan 07, 2011 | Nikon Speedlight SB-600 TTL Flash
The camera ran out of charge and now when i put it in the charger it wont switch on or charge up and the charge light is flashing intermittently. Thanks
I found this while trying to solve my very similar problem. It worked for me after about 7 times. Other people wrote that it wook them 20 times... good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Aug 05, 2009 | Casio Exilim EX-S880 Digital Camera
My camera wont charge correctly
I had the exact same problem so I went searching for an answer. Here's what I found and it really did work. I had to do it about 7 times... and I read others had to do it about 20 times. But worked for them as well. Good luck!!
ylu1 writes:
what i did was...
hope this helps.
Jul 29, 2009 | Casio Exilim EX-S880 Digital Camera
My Casio Exilim EX-S880 wont charge. when i put on the charger the red light blinks but it is not charging.
I had this exact same problem. Here's a solution. I had to do it about 7 times and others on Amazon said they had to do it about 20 times. But it does work! My light is a solid red as we speak! Good luck!
ylu1 writes:
what i did was...
hope this helps.
Jul 16, 2009 | Casio Exilim EX-S880 Digital Camera
My casio exilim s880 is playing up
Here's what I found and it actually worked after about 7 times. Others said they had to do it about 20 times. Good luck!
ylu1 writes:
what i did was...
hope this helps.
Dec 09, 2008 | Casio Exilim EX-S880 Digital Camera
Braun SE 7181 WD Silk Epil 7 Epilator Xpressive Pro OrangeCopper Logo
472 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
