Question about Bosch Nexxt 300 Series WFMC2201UC
WASHER WON'T START
TODAY I TRIED TO START THE LAUNDRY, THE TIMER RUNS AS IF ITS WASHING BUT THERE IS NO ACTION
I have a maytag mtw5770tq0 I just put a new timer on water will fill but will not start washing thanks Dennis
This could be a lid or door interlock failure depending upon the type of washing machine.
Jan 10, 2015 | Maytag Washing Machines
Why would a washing machine fill to proper level and then stop. no action after filling.
Power was never the issue or it wouldn't have filled at all. Also the pressure switch that detects water level must be okay since it stopped filling at the proper level. That leaves the control board or a relay that the control board uses to start the drum motor.
Sep 16, 2014 | Washing Machines
Washer won't drain and spin
Drain pump is cloged. What kind of washer is it . and you said stacked and laundry center. stacked is 2 seperate units and laundry center is one whole unit with both so whatcha got?
Feb 17, 2013 | Frigidaire Washing Machines
Washer went through cycle but washer was still full of water and laundry. Did not appear to have spun either. Turned the timer to spin and the timer made noise but did not spin or drain. Water has since...
sounds like the pump is goosed.....or may be just blocked............a penny is the ideal size to block a pump and stop it working...........let me know the outcome....
cheers
Mar 22, 2011 | Washing Machines
I pushed the button after the washing cycle had start for the purpose of stopping the cycle so that the clothing can soak before washing. When I returned about half an hour later, I pushed the button to...
I am taking this as a machine with a timer knob. If so, you may have to advance the timer manually to get it to go. You may have stumbled onto a slightly dead spot on the timer. I think I would just leave the lid up next time. That will stop everything and give you the soak time you so desire.
Jun 22, 2010 | GE EWA5600GWW Top Load Washer
HE4t Kenmore Elite Washer - timer doesn't work
Just call on line. Sears for the benefit of your washer
Sep 23, 2007 | Kenmore 45081 Front Load Washer / Dryer
Bosch Nexxt 300 Series WFMC2201UC Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
