Question about Sony VAIO VGC-LV180J 24-Inch All-in-One PC
My computer won't turn on
Battery lights up green and have had the cable that fits into back of computer checked wont power up
  • 26 Answers
If the logo comes try vaio recovery. Else service is the available option
Posted on Nov 23, 2013
Why wont my nookhd wont charge
If it\'s only two months old it may have a defective charging cable or adapter. If it\'s a new purchase and you can return it. To check to see if it might be the adapter and not the charging cable you have a few cheap ways to test this out.
General charging recommendations.
If you get power leave it on charge at least 3+ hours. This is the minimum time required if the battery is totally drained. If the Nook turns itself on during this process manually turn it off. The battery charges faster and more deeply if it\'s truely powered down. Charging more than 3 hours won\'t hurt it. In fact some manufacturers claim leaving thier products on charge for an additional hour after the charging light glows green is good as it leaves a slightly deeper charge on the battery. Also I believe leaving it alone for that hour allows it to cool the battery. Most manufacturers also recommend tottaly draining the battery at least once a month and then fully recharging it 1+ hours after charging light is green. They claim this helps the battery maintain a healthy charge and extends the battery life. Simply disconnect any charging cables, turn the unit on and just let it set. Don\'t touch it peroid just leave it alone until it turns off because the battery is totally drained. Then just plug it in and leave it. Only if the unit automatically turns itself on do you manually turn it back off.
Well that\'s about in in keeping the battery life and charge at its maximum.
If your AC power adapter has gone south there are only three ways to get around this. 1. Purchase a generic AC to USB adapter. 2. Purchase a genetic DC to USB adapter. Most of these can be cheaply purchased at most drug stores ect.. these days. You can even get DC to USB ones at dollar stores such as Dollar Tree. Good way to maintain your battery if your AC one goes south or you lose house current.
One other way to charge your battery is to plug the USB cable into your computer. Some manufacturers don\'t recommend this as this more often than not doesn\'t fully tank up your battery.
You can also get replacement charging cables at the same place you got the adapters. Places such as Walgreens, or CVS often have these at around five dollars a pop.
Apr 26, 2014 | NOOK HD 7 Tablet
Compaq sr2013wm
1/ do you have an ethenet cable plugged in ? is this light located on this plug ? unplug the cable first
2/ check that the monitor is switching ON
3/ find a power switch at the back of the case and switch off and/or unplug the power cable, for at least 10 sec
4/ switch on/connect power cable, and turn computer ON
5/ if nothing happens, then power supply may be dead ; don't worry it's inexpensive and super-easy to change ! but first check the manual (or manufacturer) for the meaning of the GREEN LIGHT ! Then open the case and CHECK if the computer is perfectly CLEAN, or DIRTY ; especially double check the RAM modules ! Clean everything with air spray and soft brush (pull out processor, ram, cards, if you find lot of dirt)
6/ after cleaning try to turn on computer again ; if fails, go to buy a new cheap power supply that fits your motherboard, or try to find someone that can lend you one for testing
good luck
Apr 13, 2014 | Computers & Internet
Htc wont charge and turn on
If it won't charge then you may have a defective charger, a failed battery or a loose solder joint at the charging port. If your charger plug is fitted with a fuse then consider checking the fuse is okay by trying a new one. Also, check your charger on a friends HTC, check their charger on your HTC. It really is a process of elimination to find the issue yourself.
The HTC won't turn on because it isn't charged, until you fix charging prob it won't turn on.
May 02, 2013 | HTC Flyer 7 inch 32GB Android Tablet PC...
HP pc854n does not turn on when buttonis pushed in, but green light is on on back of computer
Hi Robert,
Check the hard disks power connection.Make sure its well connected.Unplug the hard drive's power and then fit it back.Do the same with the interface cable[broad mostly 16 pins cable that goes from the motherboard into the hard drive]Also check the CMOS battery,probably remove it and fix it back making sure its firmly seated on its enclosure.[Removing the CMOS battery means you will have to reset date and time on your PC.]Check the RAM's and make sure they're well seated into their slots.You can remove them,wipe their slots off dust,and the fit them back.
Hope this helps.Thanks Robert!
Nov 21, 2011 | HP Pavilion Media Center a1330n - AMD...
My gateway profile 5 won't turn on. Checked plugs
Try to power drain it. Unplug all the power related devices that are connected, like a monitor data cable or external printer, just unplug all the cables in the back after you shut down your computer, press the power switch of your computer and keep it pressed for about 45 secs, release it, plug everything back and check it if its working. As well double check if that particular socket is usable, plug something else in to see if its working.
Jun 30, 2011 | Gateway Computers & Internet
My compaq presario cq60 won,t turn on. the power light next to the charger cable is on but it won,t turn on
The charger is functioning well. There are still two possible reasons why your computer is not turning on. 1. The battery, 2. The computer itself.
What you need to do is to isolate the problem.
Here's what you can do to isolate the problem.
1. Remove the battery from the computer.
2. Turn on the computer using the cord. Remember not to put back the battery yet. Just the cable and the computer connected. If the computer turns on, then, you need to replace the battery.
3. If it still not turning on by using the cord alone. Try to wiggle the cord to check whether it's loose or not. Check if there are some signs of power on the computer. If there is a power like lights lit in the computer, then, it's the computer that's having the problem. You need to bring it to a technician if that's the situation.
Please let me know if there are any development after doing the troubleshooting above so that I can get back to you if you need my help.
Thank you for using fixya.com
CARLO
Apr 13, 2011 | Compaq Presario CQ60-220US PC Laptop
I tried to restore factory settings on my Toshiba Saetellite L500D and it will not configure. Kept trying to configure - got to first screen where it asks you to press enter to commence system set up and...
Try to do a complete power drain by doing the following:
1.Remove the power cable.
2.Remove the battery.
3.Press and hold the power button for at least 10-15 sec to drain all remaining power stored in the board.
After this, try plugging the power cable without the battery and turn on the computer. Check if the computer will respond. Put the battery back.
Nov 12, 2010 | Toshiba Computers & Internet
Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Jul 06, 2010 | Motion Computing C5 Tablet PC
WHEN I PRESS POWER BUTTON NOTHING HAPPENS
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard. GOOD Luck.!!
Aug 27, 2009 | Insignia D400a PC Desktop
Computer won't turn on but power is on
Some time PC wont start when the Battery is Dead and when RAM's are loose contact. Check the battery power or replace if necessary. If battery is ok then Re-insert the RAM's. Before doing this switch off the power and remove the power cables. Again reinsert the power cables and start the pc. If it wont start check the SMPS. If possible test with another SMPS.
Hope this will be helpful
Thanks & Regards
Nanda Kishore.
Mar 31, 2009 | Toshiba Satellite A135-S4467 Notebook
Sony VAIO VGC-LV180J 24-Inch All-in-One PC  Logo
82 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
