Final Spin Cycle Amiss
Recently having trouble with washing machine either not totally getting rid of water from final spin -or- it doesn't spin all the water from the clothes and they are almost dripping wet. PLEASE HELP! My elderly mother is bent on going in debt to get a new washing machine. Just put a new pump on it yesterday and it's not any better.
  • 3 more comments
  • Bruce Lee Jan 02, 2008
    My washing machine(Fisher & Paykel, model:MW058K,Pride 5.5,Smart drive 8,top-loaded) didn't spin at high speed at the final washing step to dry up the clothes as before. It could only spin at low speed continuously unless I switched off the machine.I found that the rotor of the motor is directly attached to the spinning shaft and no belt was used. Could you please advise what are the possible cause(s) and resolution(s)?
  • daveyboy43 Jan 20, 2008
    My problem is very much the same. If I have a very small load in the washing
    machine,everything is fine.But if I put a normal to large load in the washer it will not go through the final spin cycle and the clothes are left soaking wet. We thought it might be the belt and my husband replaced it,but it's still doing the exact same thing. Is it possible the new belt is just to loose and he needs to readjust the tension on it? Any and all suggestions are welcome and appreciated.
  • Anonymous Mar 07, 2008
    After the "Spin Cycle" ends the clothes are still dripping wet with only a small amount of water in the bottom of the basket. Even after running it through another spin cycle the result is the same. During this cycle I hear the revolutions increasing and all seems fine until the end. Do you have any suggestions on how to correct this problem?
  • Anonymous Mar 30, 2008
    Same here, we had someone look at it a couple of weeks ago, and he just said it needed to be RESET. Any ideas on how to reset this thing? He wouldn't tell me.
  • jimbojones2 Mar 30, 2008
    Same here. I had a guy in two weeks ago, and he said it just had to be RESET. He wouldn't tell me how to reset it. Does anyone know? I have soaking wet clothes in there as I type... Please help!
The pump of nearly 90% of all problems,i had a pump motor that would only work one full cycle.The next load it would not empty after the first rinse cycle.The reason is that the pumps on these front loaders are constantly being used and build up alot of heat, being that they are a basic induction pump and do not last compaired to the old top loader that dont drain the water as many times as the front loader machines.I know this may not fix your problem but now you know what is happening.
Posted on Apr 16, 2008
  • 164 Answers
Depending on the make and the model, especially if it is a top loader, try replacing the belt. when the belts get older they stretch and slip a little, just enought o cause your problem
Posted on Oct 10, 2007
SOURCE:
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
Why does a kennmore washing machine work during the final spin and the water input does not stop?
does it only final spin? would say bad water inlet valve but should do the same in wash cycle also??
Mar 07, 2015 | Washing Machines
Ge toploadwasher that does not get water out of clothes after final spin
Could be that the spin cycle is not rotating at the required speed to wring out your clothes. Check that the cycle completes at a significant speed to generate centripetal acceleration forcing out the water. Perhaps the load is unbalanced which can trigger the spinning cycle to repeatedly stop during the spin cycle.
Jan 31, 2015 | GE Washing Machines
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Washing machine won't spin
Sounds like corrosion in the motherboard . Get an electronics serviceman to take a look, could just need soldering point to point connection. Hope this helps.
Jan 14, 2013 | Washing Machines
Washer will not start final spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 05, 2009 | Maytag EPIC MFW9700S Front Load Washer
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
Won't go into the final spin cycle and overflows
For Dinkysouth:
Apparently your machine is getting power to the water valves when it should be draining and then going into Spin. Also, since it keeps filling to the point where it overflows there must be a constant signal from the electronic board that bypasses the water level pressure switch. If you can, you should go into the Service Program and check the individual items. Most likely, you will end up needing a new board.
Jan 23, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washer will not Spin during SPIN CYCLES
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. (consult your manual to know where/how filter is cleaned). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 29, 2007 | Washing Machines
Washing Machines Logo
267 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
