Question about Ovens
I've just changed my thermostat in my Moffat oven electric s I thought that was the problem but it still is running at full temp Can anyone help is there something else I need look at
  • 25 Answers
SOURCE: Moffat Electric oven
check your breaker
Posted on Dec 12, 2007
  • 1462 Answers
SOURCE: NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
probably the element. to save wasting money, check continuity with a multimeter
Posted on Jun 25, 2008
SOURCE: Need wiring diagram for old 1960's General Electric Wall Oven
55de40b.jpg Hopefully this will help. Don't know if it is the same model, but it is a 60s GE built in oven.
Posted on Jan 10, 2009
  • 44 Answers
SOURCE: i turn on my Technika electric oven (TB60F) and
hi
behind the panel at back of oven is the fan and around that is a fan element the changes are this will be you problem . just remove panel and check weather the element has burnt out
regards
Posted on Mar 19, 2009
SOURCE: Moffat Self-Cleaning Oven will not self-clean
did you try setting a start and stop time with the time knobs? i had the same problem til i set 3 hrs on the start and stop, then let it sit (after locking the door and turning the knob to clean). after it was warmed to cleaning temp, the light for cleaning came one...
Posted on Jun 11, 2009
Where is the fuses located on a moffat stove
There are none. It is wired into the buildings electrical panel. You have to know where the circuit breaker panel is to find a tripped breaker
Aug 10, 2016 | Moffat E32 Full Size Electric Convection...
Moffat oven fan wont turn off. just keeps blowing cold air but eveything else is working
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
: I offer free advice bcuz God is so good!
Jun 03, 2015 | Moffat Ovens
I have Moffat E32ms 208V ,but my singal fase 240v. What I can do.
Those voltages are interchangable...you can hook it up with no problems...
heatman101
Aug 18, 2010 | Moffat E32 Full Size Electric Convection...
Electric oven thermostat. I just replaced this after replacing the oven element earlier. It seems to work, except, it never shuts off. That is to say apparently the thermostat is incorrectly set. There is...
Yes this the adjustment screw Counter clockwise should decrease the temp. clockwise should increase the temp. :note there should be a thermal sensor mounted on the back wall of the oven that may be bad also.
Hope this helps
Please leave feed back
Dec 03, 2009 | Ovens
Our heater is 3yrs old and it is giving off a metalic smell when the hot water tap is turned on. We have had other hot water tanks and never had this problem. This is the first Moffat hot water tank we...
This may sound strange, but here is what to do. (the full explaination is rather long)
Turn power off to the heater. Turn off water supply to heater. Drain at least a gallon of water out of the heater and diconnect one of the pipes at the top. Add a gallon of bleach. Reconnect pipe. Turn water back on to heater and run each hot water faucet in the house until you can detect the odor of bleach, then shut them off. Let the system stand for at least an hour. Now, turn each valve back on and run until the odor of bleach is gone. Turn power back on to heater.
Nov 09, 2009 | Moffat E32 Full Size Electric Convection...
I need a operations manuel for and E32 moffat
Try this site. http://www.moffat.co.nz/Catalogue/SalesPDF/E25.pdf
If this isn't it let me know and I will keep searching. Hope this helps.
Aug 27, 2009 | Moffat E32 Full Size Electric Convection...
E32MS Convection Oven not heating properly fan working intermittently
Replace thermostat. Service Engineer best but if you are competent then you could replace yourself.
Sep 19, 2017 | Moffat E32 Full Size Electric Convection...
Jun 25, 2008 | GE Profile JT912 Electric Single Oven
Problem with oven on Moffat Program Gas Cooker
Sounds to me like the oven thermostat has gone.
Dec 30, 2007 | Moffat Ovens
Ovens Logo
137 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
