Question about 4Button Remote 474P
How to program/use Valet 474P 3-button remote start fob
The unlock and lock button work well, but the Aux and the star (*) button does nothing. I got the car to start one time by pressing the star button but cannot get it to work now. I have tried several different ways of starting my car without luck. But the doors continue to lock and unlock. Please help!
2 Suggested Answers
SOURCE: How to reprogram Python 4Button Remote 474P ?
I had the exact same thing happen with my 4-button 474p remote. WITHOUT REMOTE START the correct sequence is:
1. Enter car - Leave door open.
2. Turn key to "on" position.
3. Within 5 (five) seconds press the Valet button 7 times then hold down. (Programs to channel 7)
4. Watch alarm light - It should now flash 7 times.
5. While still holding down the Valet button - Press the "lock" button on the remote and release. Should get a "chirp"
6. Now release and repress the Valet button once, holding down. You'll get the "chirp". Release Valet button.
7. Turn key "off". Exit vehicle and test remote. All 4 buttons should now work.
Posted on Oct 14, 2012
I need to find out where the valet/override button is located on my car....trying to program a new keyless remote
1. Insert key into the ignition and turn it to the On or ACC position, turn off radio. (do not start the vehicle)
2.Press and hold DISP button on radio until settings is displayed.
3. Press Seek until FOB PROG is displayed .
4. Press Prev or Next and BEGIN will be displayed
5. Press DISP and programming will begin when PUSH FOB is displayed. Press and hold Lock and Unlock together until vehicle chimes. This will signal successful programming. May have to hold buttons up to 20 seconds. Hold Lock and Unlock on additional remote until vehicle chimes again.
6. Exit programming mode. Scroll to Exit and press DISP to exit programming.
If you don't have the original radio, it can be done with a scanner.
Mar 19, 2016 | 2004 Chevrolet Chevrolet Impala
Tip
How to get a Viper alarm out of valet mode
Exiting Valet Mode with Key Fob:
1. Open the entry door.
2. Press the lock button.
3. Press the unlock button.
4. Press the lock button again.
5. Ensure the red LED is a steady glow.
Exiting Valet Mode with Valet Button:
1. Turn the ignition ON.
2. Turn the ignition OFF.
3. Press and hold the Valet/Program button for 10 seconds.
4. Ensure the red LED is a steady glow.
on Apr 14, 2010 | Vehicle Parts & Accessories
Tip
How to get a Viper alarm into valet mode
Entering Valet Mode with Key Fob:
Entering Valet Mode with Valet Button:
Programming a honda transponder key
did some quick research for you and found this easy and very clear step by step instructions on how to program your transponder car key to your vehicle.. this works for the following models though :
Accord 2003 to 2006
Civic 1999 to 2006
Element 2003 to 2006
Odyssey 1999 to 2006
Prelude1999 to 2001
Accord SE 1997
CR-V 1998 to 2006
Insight 2000 to 2006
Pilot 2002 to 2006
now here are the steps:
  1. Turn the ignition on
  2. Press Lock/Unlock within 4 seconds
  3. Turn ignition off and hen back on within 8 seconds
  4. Repeat steps 2-3 two times
  5. Press Lock/Unlock again within 4 seconds. The system should now lock and unlock the vehicle to indicate it is in programming mode.
  6. In the next 10 seconds: press Lock/Unlock button allowing the doors to lock/unlock once; then press lock/unlock button of each remaining key, allowing the doors to lock/unlock once.
  7. Switch ignition off and then remove the key
Civic 1996-1998
  1. Turn ignition on
  2. Press and hold the valet button which is situated on the radio within 5 seconds.
  3. System should now lock and unlock the vehicle indicating it is in the programming mode
  4. Within 5 seconds turn ignition OFF and press Lock/unlock on the remote fob to be programmed
  5. Within the next 10 seconds, press Lock or Unlock of any remaining keys, allowing the doors o lock or unlock once.
  6. Release valet key
Radio remotes 2 and 3 button types
  1. Switch ignition on and repeat for 3 times.
  2. Press he lock button, switch the ignition off and back on and then press lock button again.
  3. System should now lock or unlock
  4. Press the lock button of all remotes to be coded. The car should acknowledge this by locking/unlocking each time
  5. Switch ignition off to exit the programming mode.
If you will have any further doubts or question to ask i suggest you to check out the page where i found this which is http://www.carkeyadvice.com/step-by-step-fob-programming-guides/honda :) i hope this was the solution you were looking for mate! happy happy new year!
Dec 30, 2012 | 2007 Honda Pilot
Python 476p
May depend how it was programmed. My Python 476P was setup with Lock and Unlock pressed to get it to remote start. Then, get in the vehicle, put the key in the "on" position and press lock / unlock to get it to end the remote start cycle. Then Drive off ...
I got a second remote, followed some directions via YouTube to program. Key in the on position, then hit the valet button once, then press and hold. One chirp, hit lock on remote. Let go of valet button . Press, then press and hold, two chirps. Hit unlock. Continue for 3 (aux) and 4 (panic). End result was Lock would also unlock. Unlock did nothing. And Aux started the remote start sequence.
Having bought a vehicle used, then no manual made this a bit difficult. I will continue to test alternate programming to try to match the original remote so accidentally firing up the rig doesn't happen. My suspicion is I have to maybe do Lock, Aux, Lock/Unlock, panic instead. Good luck.
Oct 30, 2012 | Python Vehicle Parts & Accessories
Need program to add additional key fob to my Python 474P model on a 2005 Kia Sportage
To program additonal remote; open door, turn ignition on. Press and release valet button one time then, press and hold valet button. While holding valet button, press lock button on new remote. Turn ignition off. Test system.
Sep 29, 2012 | Remote Start System
Mar 09, 2012 | 4Button Remote 474P
How do I program a Viper 473 V Replacement Remote, to my 2004 Hyundai Santa Fe?
Set lock/unlock button
· open drivers door
· turn key to ON position
· press valet switch 1 time
· press valet switch again and hold
· when alarm chirps press lock/unlock on remote
· release valet switch
· turn key off
Oct 05, 2009 | Viper Security and Remote Start System...
My valet remote control RPN491 Starts vehiclr and unlocks doors but will not lock doors do I need to reprogram remoteto unlock doors?
Ok you said "unlock doors' but you said it already unlocks the doors. This remote should lock and unlock door on same button, if you are describing the 2 button remote. If it is not then it could be alot of things. Does the alarm lock itself? Does the alarm lock the door when you turn on the ignition? More info is really needed. Like what veh and what model alarm.
Sep 11, 2009 | DEI Valet Keyless Entry System
04 Escalade w / Valet Starter, all works but door locks
Hello 7suds,
Well, I'd go back and tell them about the doorlock problem. I know that 2 years is a little late to start complaining, but it's most likely a really easy fix.
The most probably causes are that the power doorlock output was either not programmed, programmed incorrectly, or it's not connected or improperly connected to the vehicle servos. Have the installer check the programming, especially the doorlock pulse duration. It's also possible that the remote is simply not sending the doorlock signal. Could just be a bad button. Have them switch the doorlock function to the right "AUX" button temporarily and see if that works. But in any case, the system needs to be tested to find out exactly what is causing the doorlock failure.
Hope this helps.
Jul 16, 2009 | Directed Dei Valet 561r Remote...
4Button Remote 474P Logo
313 people viewed this question
Top Python Vehicle Parts & Accessories Experts
rjivaro
Kevin Daniels
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
