Wussi inverter mini split show code p4
Wussi inverter does not turn off show p4 and then started but not cool
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
Posted on May 04, 2010
SOURCE: WE have Amcoraire Mini split unit heat pumps. One is
We have an Amcoraire 12,000btu mini split. The heat doesn't seem to be working. We can hear it trying to go on, the outside unit fan runs, but nothing comes out of the inside unit at all. This doesn't seem to be affecting the a/c part and we get no error codes. Is there something wrong with our unit?
Thank you.
Posted on Feb 19, 2011
ftw1952
  • 10319 Answers
SOURCE: Mini Splits flashing "ch" then
CH61 means Condenser coil temp high due to non cleaning of condenser/over charged gas/non condensable gas.
Clean your condenser coil. If still problem rests, due to non condensable gas also there will be high temp. Once remove the gas, flush out the system and vacumize and then do gas charging.
Posted on Jul 11, 2011
hvac1960
  • 2133 Answers
SOURCE: what does p1 means on my 12000btu pioneer inverter mini split ai conditioner?
air sensor defective. Replace it.
Posted on Aug 18, 2012
maxcarson
  • 7627 Answers
SOURCE: koppel super inverter displays P4
Wrong category, try Air Conditioner category. A AC expert may can help you. This is a PC Laptop category.
Posted on Apr 08, 2013
Hi, when i turned on my Senville mini split the fan will go on for 2 - 3 minutes and then the air conditioner will display P4. On the error code description, it say inverter compressor drive error.
contact the manufacturer to see if they can help you with this type of failure. the compressor and its controller are the two most expensive parts of the unit to repair.
Jul 29, 2016 | Inverter Heating & Cooling
Does not produce Heat
Sounds to me like it is defrosting the outdoor unit. Is this possible? The process takes a little bit to complete but it will then start up again.
Nov 14, 2014 | LG LA120HYV Art Cool 120HYV Ultra...
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
My orient split a.c shows Ec error in digital display
sir plz answer me my ac orien 1 ton showing EC error on display what is this i can't understand what is this plz reply
Jul 12, 2014 | Heating & Cooling
Wussi A/C inverter show code P4
Como encontrar el code del A/C Wussi modelo 18 (41O)
Nov 23, 2013 | Heating & Cooling
P 4 code means problem with the outdoor unit, Most likely low on refrigerant. Check all copper pipe connections for leaks first, then add refrigerant after checking pressures.
Jan 17, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
