Question about Hard Drives
Western digital My western digital wd2500b011 does not power up and I would like to find a solution to this problem. I have three more of these suckers and I'm afraid they all can go bad on me and loose all my data. Have any sugestions? can I just fix the power supply or something? please advise. tnx
Re: western digital
I am experiencing this now with a new 1TB drive (I bought 2 to replace my 1TB LaCie drive that  died about 2 weeks ago. Had Computer Forenzics recovered the data at massive expense $$$$.
So after getting 2 WD My Book Studio drives I had my data recovered to one of these 2 WD drives only to get it home and die (so it seemed). After exhausting all possibilities (so i thought) my brother suggested I switch the power packs over and lo and behold - bingo - the drive mounted on the imac desktop. The power packl on one of the two drives was dead when it came back from forenzics.
Now that's what I call reassuring!!!
So now I have to get a power pack for the backup drive. Poooooos.
Posted on Sep 26, 2008
  • 72 Answers
Re: western digital
Try swapping the cable and power supply with one that works, if that one works, its either the cable or powersupply if it doesn't work, then it's bad and you'll need to get it replaced.  the WD web page has a place where you can enter your serial number and they'll tell you if it's in warranty and set up an RMA for you, they'll ship you a new one first if you supply a credit card number for them to charge in case you don't send back the dead one.
good luck!
Posted on Oct 20, 2007
0 characters
3 Points
Hii, When I plugg in my western Digital Hard disk it sometime get detectable and sometimes not and it is sounding like Tic tic. Could you help me how to resolve this problem.
This is because the hard disk is not getting the sufficient power from the USB port. Try connecting your hard dik on other PC and repeat he steps three four times and see the behaviour.
Besides your hard disk is fine !!!
Vipin Kakkar
Jan 30, 2011 | Western Digital (WD3200JS) 320 GB Hard...
WD 1 TB is not working my laptop is not reading it spin for a sec and stop what would be the problem please help . Thanks
The disk-drive is "dying". If the WARRANTY (probably one to three years) on the W.D. drive still is VALID -- it probably is, you should contact Western Digital, and get it replaced, by exercising the warranty.
Sep 24, 2010 | Western Digital Elements powered by WD 320...
Problem with WD 1.5TB external hard drive
This appears to be a common occurrence with the My Book. It may be a heat dissipation problem from leaving the unit on for longer than it takes to back up your data.
I think you might need technical support from Western Digital. Do you have an alternate backup?
Mar 21, 2010 | Western Digital My Book Essential Edition...
I have a Western Digital Elements 500gb it has a 5pin power surply that is no longer working this unite is not even a year old and i can even find a new one for it
Contact Western Digital. The unit should still be under warranty so they should replace the defective power supply for you. Hope this helps.
Sep 15, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Western digital 500GB harddrive not switching on
Did You Try Using The Included AC Adapter To Power It Up
Jul 18, 2009 | Western Digital 500GB My Book World...
Power cord replacement needed
Is the product still under warranty? You can try which is the Western Digital Warranty Support pages.
Mar 18, 2009 | Western Digital My Book Home Edition 500...
Western Digital Hard Drive will not power on
try to change the power adapter..
its mayb broken..
happy trying..
good luck..
Apr 14, 2008 | Western Digital My Book Essential Edition...
Power Problem
I have sent my one to specialists and they quoted me on £400 to recover all my data :( this is a joke - I will never buy WD again....
Feb 24, 2008 | Western Digital My Book Essential Edition...
Hard Drives Logo
892 people viewed this question
Top Hard Drives Experts
Brian Sullivan
Brian Sullivan
Are you a Hard Drive Expert? Answer questions, earn points and help others
