Question about Indesit Washing Machines
Dryer not working indesit widxl 146
We have an indesit widxl 146 washer dryer. The dryer was put on before we went to bed last night and was still running this morning! The washing was still damp, so we halved the load (not that it was full anyway, and put it on again, but it was on for over 2 hours until we stopped it and still didnt dry the clothes. The clothes are not even warm when we stop it. Can anyone offer advice. Thanks
  • 209 Answers
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
Posted on Sep 09, 2007
barkencoa
  • 3463 Answers
SOURCE: Instruction Manual for Hotpoint washer dryer wd420
Try this link:
http://www.hotpointservice.co.uk/hs/pages/manual/manual/search.do
Enter the model number in the search box, and download instructions.
Please rate my solution.
Thankyou.
Posted on Mar 02, 2009
SOURCE: Asko Washer/Dryer (WCAM 1812); Dryer not working.
Update: The dry cycle is now working! Apparently the automatic overload/shut off on the heating element got tripped. We had a technician out this morning. He unplugged the machine, removed the top of the unit, and simply pushed a little red/orange button that was on top of the heating element. When we plugged it back in the heating element worked again. The technician was able to troubleshoot this by checking the amps while running the dry cycle. But the proof was really when we did a load and the machine heated up (just like it used to) during the dry cycle. This was actually a relatively simply fix - though could be dangerous as you have to open up the electrical area. The reset button is rather inconspicuous and located on top of the heating element, which is long (runs front to back in the center part of the top of the machine - which you can get to by removing the lid/top outer housing) and silver - wrapped in insulation. It's pretty obvious. The button is in a little metal fixture on top of the heating element. The technician told us that the rest can get tripped when the unit overheats. (We think this happened when the laundry tub overfilled and the hose was totally submerged - the machine was working overtime to pump out the water.) The technician also warned that this can happen if the machine gets turned off suddenly mid-cycle - especially during the drying cycle. He said that the heating element gets so hot, it needs to have a gentle cool down period, which is marked on the dryer dial for the last 20 minutes of the cycle. I hope this helps others!
Posted on Dec 02, 2009
SOURCE: L.G DIRECT DRIVE 7 WASHER / DRYER U.E ERROR CODE
My machine is doing just the same! It is about the same age as yours. I cannot believe this is it working properly, but the manufacurers are no help.
I am seriously thinking of getting rid of it, and would be loathe to touch an LG again.
Linda
Posted on Oct 08, 2010
SOURCE: Fisher Paykel Washer IWL 12 error codes 130 & 240
Had the same problem cleaned the terminals worked for a bit and came back. The problem is that the little circit board that the plug goes onto that sits between the winding of the motor the copper tracks are so small and they corrode. If you are handly with a solding iron you can replace the tracks with small wire, its mainly on one leg of each of the transistors that are all parrelled up. You can tell because it goes black. Or the easy way just take off the motor unpluging the sense plug then the three main power connectors Yellow, blue and red making sure you mark the correct order to put them back on. The sensor board just pulls out of the windings with a little arrow to but it back in the right place and buy the small board it has the part number on it to find it on the web. I only has three bits on it can't be expensive. Soldered mine up works a treat make sur you clean up the plug aswell, it mainly played up in humid weather.
Posted on Dec 22, 2010
The message flashing says 'door' what do I do?
You have a problem with the door switch interlock.
Indesit WIDE 146 (DE) Washing Machine Spares ' eSpares
www.espares.co.uk > Home > Washers & Dryers > Washing Machines > Indesit
  1. Cached
Items 1 - 10 of 60 - Universal stacking kit suitable for most washers and dryers measuring 60cm across More information. In Stock. Stock Number ES187394.
Get Indesit Washing Machine Spare Parts ' eSpares
  1. Cached
  2. Similar
Genuine Indesit washing machine spares including Drum lifters, Indesit ... Start your Indesit parts search by selecting your washing machine model number from ...
Indesit Washing Machine WIDE 146 (DE) Spares - indesitspares
www.indesitspares.co.uk/washing-machine/wide-146-de.../catalogue.pl?path...
  1. Cached
Indesit WIDE 146 (DE) Washing Machine Spares ... Fits models with serial number from 30127.0001 Please Note the above serial number changes does not ...
Indesit Washing Machine IWDE 146 UK Spares - indesitspares
www.indesitspares.co.uk/washing-machine/iwde-146-uk-f084074/catalogue.pl?...
  1. Cached
Indesit IWDE 146 UK Washing Machine Spares ... This part fits the following models: WIL133UK, WIL133UKCO, WIXE127UKV & Does Not Fit Mod. .... If you have just replaced the door seal on your appliance then you may need this retainer ...
Indesit Ecotime IWDE 146 Built-in Washer Dryer - White
www.indesit.co.uk/appliances_i/Washer_Dryer_IWDE_146/pid_F084074UK/42.do
  1. Cached
  2. Similar
Rating: 8.5/10 - ‎19 votes Indesit Ecotime IWDE 146 Built-in Washer Dryer - White, ... News & Offers; Service & Spares. Service · Spare Parts ... IWDE 146 reviews · Ask-an-owner ...
Washer dryer no wide 146 Google Search
Mar 24, 2017 | Washing Machines
INDESIT MODEL WIDXL 106 WHERE CAN I FIND CONTROL BOARD
you have to remove the top of the machine, it loacated behind the knowbs.
Mar 11, 2014 | Indesit Washing Machines
INDESIT WIDXL 146 TROOUBLE SHOOTING
What is the display showing? Is there a pattern to the flashing? Have you tried unplugging it for a minute to reset the computer?
Feb 19, 2014 | Washing Machines
Indesit widxl 126 washing machine fabric conditioner compartment blocked
Indesit widxl 126 washing machine fabric conditioner compartment blocked.
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2011 | Washing Machines
Washed load of towels wont work
try cleaning the drainage filter located under the front bottom panel.
Aug 14, 2009 | GE WSXH208A Front Load Washer
I WANT TO ASK ABOUT THE FUNCTIONS OF INDESIT WIXXL 146 WASHING MA
instruction book http://imagebank.indesitcompany.co.uk/brochures_online/pdf/indesit/Laundry/WIXXL146-GB-Hires.pdf
Jun 10, 2009 | Washing Machines
Water not draining although spin still ok. Then went bang!
Called out a plumber who diagnosed that the machine was not worth mending. He charged me £25. Now have new Indesit WM.
May 23, 2009 | Bosch Washing Machines
Cannot work out how to use dryer only
In your browser bar, type in --- indesit user manual
Then in the drop down list click on manuals- user guides- hanbooks
In the search box type in your model number, and you will be able to down load the instructions.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Washing Machines
HE5 Dryer not working
Hello dram65,
Check the door interlock switch, if that's malfunctioning or not sensing the door is closed.. it will disable the drying function,
Regards,
Rick
Dec 13, 2008 | Kenmore 82822 Electric Dryer
Indesit Dishwasher
disconnect the drain hose and lower it into a bucket if no water comes out there is a blockage in the hose/pump.
Jan 25, 2007 | Indesit 24 in. D63S Free-standing...
Washing Machines Logo
48 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
