Question about Magnavox NB820 Remote Control NB820UD
The dvr buttons do not work properly. the regular channel buttons work fine
We have a Toshiba TV and DVR. Every time we watch a DVD and try to return to cable TV, we get "no video signal." How do you get back to cable tv?
My mother in Law asks this question all the time, first rule never buy a fancy TV for a christmas present for *********** in law because she will call you on your cell at all hours to fix her TV !!!
Seriously though how do you have your TV set up.
for example Cable box to DVR then DVR into TV
If this is the case
Although I am not familiar with the exact setting for your TV they are all practically the same. In this case make sure TV is on then right setting for example is it HDMI, AV1, AV2 or do you have a selct Tv channel either way you may have to use the channel up and down button for the Tv to put it on the right one or even the source button if there is on the remote - if you dont have a remote for your tv use the buttons on the Tv itself, make sure cable box is on.
Still not working - again make sure the Tv itself is on the right chanel as mentioned above. Also make sure the cable box is on. Now press the source or AV button on the DVR until it comes through on the TV. It may even be just a simple case of pressing the TV/Video button or AV button on the DVR remote if it has one or changing the channels on the DVR.
Sometimes electronic devices can be temperamental. My satelite box for example is a cheap one from Radio Shack. I often get sound only through the TV. If I turn the box off and back on though it works fine again.
They can be right pains in the neck these things. Basically all you need to do is find the correct order of modes that the Tv, video and cable box need to be in.
Jun 03, 2011 | Televison & Video
My dvr freezes. i have picture and sound but unable to change the channel or anything dealing with the dvr. i have to manually push the system info button on the box then select done with the remote. ...
Believe it or not, this could be a simple battery problem in your remote. When my battery is low in my remote, some buttons will work and some not. I'd try replacing the batteries in the remote first. If that doesn't work, I would guess that you need a new remote. Sounds like your DVR works fine manually, so chances are that's not the problem.
Hope this helps.
May 14, 2011 | DISH Network DVR-625 DTV Receiver /...
Do not know how to get regular T.V. hooked up to this system
try using the red White cables from back of tv to back of dvd player/receiver. Do the same with DTV/dvr or cable box. not sure if cable box has red and white cable outlets, however the DTV-DVR does, The quick patch is from TV to back of dvd (input audio)side,....that should work
Sep 26, 2009 | Coby DVD-937 5.1 Channel DVD...
I can only get 2 channels on my TV hooked to Cable
Please do the Auto Channel Program once again and let me know.
Aug 28, 2009 | Westinghouse SK-42H240S Television
Audio Problem on a Pionneer DVR-810H Recorder
Thinking the problem might be the cable box..I bypassed the Tivo and hooked the cable box direct...there was audio on ch. 3 ....reconnected the Tivo and the audio was fine...strange?
Thank you.
Ken Havel
Greenville,WI
Oct 10, 2008 | Pioneer DVR-810H DVD Recorder
Suggestion doesn't seem to apply to my tv
Service menu settings and resetting if still nothings happen. Then DVD works fine and then the signal strength is 95%. Then the problem is your cable card provider. They blocked your channel this is the common problem of card deactivation. Just try this, take the cable connection and put an ordinary outdoor antenna, if still not working then the problem is in the signal board , but if it's works ok then the problem is cable card activation...
Checking the Diagnostics screen 1. Make sure the RF cable is plugged securely into the CABLE connector (not the ANTENNA connector) on the back of the DVR.
2. Tune to a channel that is having a problem and press RECORD to lock the tuner to the CableCARD.
3. Press the TIVO button and select Messages & Settings > Account & System Information > Diagnostics. Look for the number of the problem channel, and then look below it for the Signal Lock setting.
• Signal Lock: Yes means the DVR is detecting a signal for the channel. In this case, the DVR usually cannot display the channel because either the CableCARD has not been activated or during activation the card did not receive the provisioning necessary to display the channel. For more information, go to
Step 4: Determining if the CableCARD is activated.
• Signal Lock: No means the DVR is not detecting a signal on the channel. If this is happening for only one or a few channels, this channel may not be in your lineup. For more information, go to
How Do I Determine Which Cable Lineup Is Mine?
If you see Signal Lock: No, and Test Channels could not display any video on the CableCARD, use the following procedure to check the signal connections.
Checking signal connections 1. Partially eject the CableCARD(s) so that they are disconnected from the slot.
WARNING: If you remove the CableCARD(s) completely, you must take care to replace them in the same slot. Switching slots will unpair the cards; to re-establish pairing, you will need to contact your cable provider.
2. Press the LIVE TV button on the TiVo remote control. Do you see video?
• If you see video, the CableCARD activation was not successful. For more information, go to
• If you do NOT see video, go to Step 3.
3. Plug the RF cable connection directly into your TV. Do you see video? • If you see video, go to Step 4.
• If you do NOT see video when the cable feed is connected only to your TV, contact your cable provider.
4. Reconnect the cable to the DVR and try the following, in order. Press the LIVE TV button and check for video after each step.
a. Check the cable connection on the back of the DVR. Make sure the RF cable is securely attached to the CABLE connector.
b. Press the INPUT button on your TV remote control to cycle through the settings. The Input setting must match the physical connection between the DVR and your TV (HDMI or Composite, for example).
c. Press the FORMAT button on the front of the DVR to cycle through the settings. This ensures that the DVR is sending a compatible signal to your TV.
d. If you have any splitters installed, remove them and then reattach the RF cable to the DVR.
5. Restart the DVR. After the DVR restarts press the LIVE TV button. If you still cannot see video, contact the TiVo CableCARD hotline.
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
TV only will play HD Channels
This must be the setup for your TV box. Contact the support for your TV box.
Normaly, the TV should auto select the proper operation mode.
Jerry G.
Dec 25, 2007 | Samsung LN-T4665F 46 in. LCD Television
Audio on DVR recordings on non-digital channels squeals on playback
Try a system reset by unplugging the unit from all power, wait for 5 minutes and retry. This is an unusual problem...accordianman
Oct 13, 2007 | Arris DCT6200 DTV Receiver
Magnavox NB820 Remote Control NB820UD Logo
21 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
