Question about Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump
How do I fix the seal? - Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump
    Top Expert:
  • 12,223 Answers
Please follow this steps . God bless you
  1. Turn off the pump motor and close the input and output valves.
  2. Loosen the fasteners that secure the tube connecting the pump and motor.
  3. Move the motor away from the pump housing.
  4. Remove fasteners holding the diffuser to the backplate.
  5. Inspect the diffuser and O-ring for wear, replacing as needed.
  6. As needed, remove fasteners attaching the impeller to the shaft. Alternately, the impeller may be screwed on to the end of the shaft.
  7. Remove the impeller and seal from the shaft.
  8. Inspect and replace the impeller and seal.
  9. Reassemble the pump.
Posted on Nov 24, 2013
F 5 error top draw only
Fault code F5 is a lid fault error. It could be one of many issues and generally will need a technician to fix it. The problem could as simple as the lid seal that seals the drawer being displaced or the actuator motors that bring the seal down being faulty. Turn the mains power off to the dishwasher and back on. This should bring the actuator motors to start position. If this does not fix it then check under the top housing for any signs of lid seal break. If it looks ok then you have to call technician to fix it. The fix involves taking the drawer out carefully without damaging the wiring and hoses underneath and checking the lid seal assembly underside of dishwasher housing.
Mar 15, 2015 | Fisher and Paykel 24 in. DD603H W Built-in...
How do i fix front seal leak? is there stop leak for that?
You can get stop leak products at your nearest auto parts store. Ask them for suggestions about the best one for your vehicle.
Feb 25, 2015 | Volvo 240 Cars & Trucks
Express van
Depends what you mean by "cam seal". Do you mean the seal that goes under the front engine cover? It involves taking of the pulleys and belts. To get a mechanic to fix it will cost quite a bit because of the time factor. If you have the tools and a couple of hours you can fix it yourself and the seal itself won't be expensive.
Apr 02, 2014 | 1990 Mitsubishi Minivan
I have a 1997 rav4, with an oil leak between engine and tranny. Is that an expensive fix?
Check that it is not the rear of the sump gasket that is leaking. If not then the fix will be to remove the gear box. If manual the leak may be at the clutch shaft input seal which is relative minor fix. If auto it will be torque converter seal and shaft seal . A bit more expensive. It it is the rear main seal then the clutch ( if applicable) and flywheel have to come off as well. All in all about $20.00 dollars for seal and about 6 hours labour.
Mar 22, 2014 | 1997 Toyota RAV4
My 97 honda civic has been in an accident before now my trunk doesn't close completely and water gets in my trunk how do I fix that
The fix depends on what was bent - the deck lid or the back of the car. To find out, clean the rubber seal with brake fluid on a rag, then dry the seal with another clean rag. Put a small amount of motor oil on your finger tip and put a small line of oil on the top of the seal, making sure you have enough oil on the seal to wet it all the length of the seal.
Now close the deck lid GENTLY. Open the lid and inspect the surface of the lid that contacted the seal, as well as the seal. The area of the lid that is dry is where the lid and seal are not contacting.
If you cannot determine where there is oil or not, you can try putting a small amount of fine ground dirt on top of the oil before closing the lid. If you can see bends in the deck lid surface, replacing the lid should fix the problem. If the deck lid is straight, then you'll need to have a body shop fix the car ( expensive). It is also possible the seal is flat, torn, or just worn out - in which case replacing the seal will cure your problem.
Hope this helps!!
Jan 25, 2014 | Cars & Trucks
1987 Ford F-350 Steering Gear Box Seal Leaking. Is it possible to replace the seal to fix the leak?
csk auto parts store has steering seal kits and steering gear shaft input seal kits...as for the replacement procedure, I would recommend having a quality repair manual on hand and do a "dry run" before attempting the fix for real.
Aug 17, 2011 | 1987 Ford F 350
How to fix iner seal on the oven door
I have a Zanussi ZDF290X which requires a new top oven seal. I have pulled the remainns of the old one out, but without dismantling the oven it seems impossible to fit the new seal. Any easy way of fixing this, please?
Jan 13, 2010 | Zanussi Ovens
DUE TO OIL OVERFILL BY SHOP, ENGINE SEEPS OIL. IS IT A SEAL? WHAT SHOULD COST BE?
It's probably a seal but how much to fix depends on which seal it is.If it's not leaking too bad I'd leave it alone unless it was an easy fix. Some seals require a partial tear down of the engine, some only need a piece ortwo taken off. The best bet would be to take it in to a shop and find out exactly which seal it is andtake it from there. Hope this helps.
Oct 08, 2009 | 1993 Honda Accord
My ricoh 6513 leakes lot of developer
u nuts ?? replace the seals or buy a used dv unit
Jun 25, 2009 | Ricoh 6513 Copier
White smoke 84 mazda rx7
the engine must be torn down to repair the cooling passage seals, there is no way other than that to fix this, while u are in there might as well overhaul the engine.
Mar 23, 2009 | 1984 Mazda RX-7
Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump Logo
102 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
