Question about Lexmark X83 All-In-One InkJet Printer
LEXMARK X83 PRINTER 1) A few times papers jammed too far back to pull out from the front so i pulled them out the back. Now when the paper feeds there is a clicking noise and the papers feed only partially forward or just out of reach. 2) I can't figure out how to take off the sides of the printer to access the rollers inside. Thank you for your help
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Mar 24, 2008
SOURCE:
My lexmark x83 is making a clicking noise and will not pull paper through.
hello, the problem with your machine is a gear that drives the paper feed section, not the paper feed roller but the platen roller, well its cracked, unless you have an identical machine, you will not be able to repair this printer, i have tried. so, this machine has performed for you extremely well, but now it time to look for another one. sorry
Oct 07, 2010 | Lexmark X83 All-In-One InkJet Printer
Paper will not feed through the printer . . , ''paper jam'' message appears . How can i open the printer to check for a paper jam? I have a Lexmark X83 printer/copier/scanner.
behind the printer there is the tray that can be opened easily to check if the printer is jammed in or the paper feed sensor is stuck up.just open the back tray of your printer and check.
get back if you require more assistance on this.
thanks.
Jul 08, 2009 | Lexmark X8350 All-in-One Plus Photo with...
How do I remove the cover of my lexmark X83? The paper will only feed part of the way then I get a paper jam message.
there is a cover there at the back of your printer, pull it down then remove the paper hang on their, then after you remove , check if there is another paper to hang, after that try to print
Jul 01, 2009 | Lexmark X83 All-In-One InkJet Printer
Printer 2480- my printer is pulling paper only on right side
Try this :
Jan 16, 2009 | Lexmark X2470 All-In-One InkJet Printer
Lexmark z2300 printer won't pull in paper
Jan 03, 2009 | Lexmark Color JetPrinter Z23 InkJet
Paper jam error, but no jam present
mabey its the wrong paper youre putting in it:O?
Jan 03, 2009 | Office Equipment & Supplies
X83 lexmark A06 error (paper jam)
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 31, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark X2250 uneven paper feed
Oct 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
Paper will not feed into printer
Oct 17, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 all-in-one printer
Hi gerby, need to eliminate a few issues to get to the cause. First, check for a jam. Paper jams can be so tiny you can barely notice them. Use a torch and check thoroughly down back of unit in paper feeder, open cover, let cartridge carriage roll left and settle. Now look inside thoroughly too. If no jam, check rollers are even and look same on each side. Post back if no good.
Sep 01, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
195 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
