Question about Acer Aspire 4520-5582 Notebook
My power adapter light on but if i plugin to my pc the light off why
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
Usually indecates a short..theres a blocking diode.that only alows current to flow one dirrection.or if theres a burst of current it goes off. thats a safty feature in chargers. therefore when you plug it in its detecting impropper current flow and stopping the charger..Try doing a Hard reset on the computer.I've had that same notbook.There pretty good machines
Posted on Nov 26, 2013
Laptop ed 500 not working after windows 7
Does it not power on at all.. logo screens, backlight, powerlight etc? If the answer is no... remove a/c adapter then battery.. hold down power button for at least a 1minute then put battery back... plugin A/C adapter then try to power on.
Nov 16, 2011 | LG E500 Express Dual Series Notebook PC
My dell studio 1537 is not booting, volume lights are on min. volume indicator blinks
Power off the machine and then remove the battery. Once the battery is removed, plugin the AC Adapter and power on the machine. If it boots up fine, the problem is most likely your battery. If it still gives you the same issue, the problem is most likely your AC Adapter.
Jun 12, 2011 | Computers & Internet
It won't turn on
Hi. Try theses simple steps:
Remove the Battery
Remove the AC Adapter
Press/hold down power button for 10 seconds
Plug AC Adapter in and turn the computer on
If the system doesn't turn on still then there's a problem with your motherboard. and it might need replacement.
Jun 06, 2010 | IBM ThinkPad T40 2373 Notebook
My emachine d620 laptop will not power on. the led light is green and the battery is charged. the power button is not working.
Hi. I would suggest that you powerdrain your computer might fix this. To powerdrain your computer you must remove first the battery and unplug the ac adapter then press and hold the power button for 20 seconds, after that you must place back the battery and plugin the ac adapter then turn on your computer. If this doesnt work try to powerdrain again the laptop then just use the ac adapter to turn on your computer and that is without the battery. Hope this helps.
Jun 03, 2010 | eMachines eMD620-5133 Notebook
Hi i am using dell latitude d600 problem with charging the battery 3 or 4 time orange light flash n 1 time green light . im unable to use my laptop with battery it working well with A.C power
Try to perform power drain. Take out the battery unplug the power adapter then press and hold the power button for 30secs. Put the battery back in then plugin in the power adapter then turn on the computer. If same issue occur, then you need to replace your battery.
May 18, 2010 | Dell Latitude D600 Notebook
Battery has gone dead. When I plug the A/C cord in the light on the charger immediately goes out and won't charge battery.
try connecting ac adapter alone without the laptop, check if ac adapter light will stay green or blue.
try another power outlet using the ac adapter alone without the laptop check if the ac adapter light will stay as green or blue. if all fails replace ac adapter.
if ac adapter stays green or blue try connecting to the laptop without the batt, check if the ac adapter light will stay on, if yes then try connecting ac adapter to laptop with the batt plugin check if the light stays green. if not update the BIOS. if fails replace motherboard.
Oct 12, 2009 | Dell Latitude D610 Notebook
MT6451 Display will not work.
Hello
It sounds like your AC cord or the female plugin soldered onto the motherboard has gone bad and will no longer make a connection to charge the battery or power the laptop on.
You would have to try a new power cord to find out which is the problem. If the cord fixes it, then it was just a bad cord (as you said it gets very hot, this maybe a sign of a cheap cord that has gone defective).
If the cord is not to blame, then the female plugin is loose and there is little you can do unless your an expert at soldering.
Post back with anymore questions or comments for additional help. Thank you for choosing Fixya!
Jun 23, 2009 | Gateway M305CRV Notebook
Ac adapter light is solid green, but when plugged into laptop...
the most likely reason is a systemboard problem (the ac plugin port cannot changed independently for notebooks)
Mar 23, 2009 | Toshiba Satellite A65-S126 Notebook
Acer Aspire 4520-5582 Notebook Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
