Question about Samsung Convoy Cell Phone
Ringer is silenced on my samsung flip phone - Samsung Convoy Cell Phone
I want to take off the ring silencer on convoy 3
I use Convoy 2. Go to "Setting" and select "Sounds settings".Select "Call Sounds" and select "Call ringtones". Then select "Call ringtones". Find "no ring" if you see it just select the ring tone you want and test the ring tone. I hope it is work for Convoy 3.
Sep 28, 2014 | Samsung Convoy Cell Phone
Tracfone customer service
  1. Check a ringer volume and profile. Press a volume key to see the volume status bar at the top of the screen. Use the volume up and volume down keys to adjust the loudness of the ringer (scale 0 to 30). Tap on the text next to the ringer icon to change the profile (vibrate only, ring+vibrate).
  2. Check if the issue is with a specific ringtone: Go to Settings > ringtones+sounds > Ringtone, and tap on a playbutton to preview the ringtone.
  3. Switch off the ringer vibration (Settings > ringtones+sound > vibrate) temporary, to determine if your phone is affected by any motion settings i.e. Flip-to-Silence.
  4. Make sure that call forwarding is not switched on: Tap the phone icon > ... > Settings.
If the problem persists, restart your phone by pressing and holding the power and volume down keys simultaneously until the phone vibrates. Release and the phone will restart. After this operation, you may need to re-adjust the volume and set date+time on the phone. Note that this does not remove your personal content.
Mar 13, 2014 | Computers & Internet
My phone is making no sound
Hi, check profile settings. Make sure your phone is not on silence. Also make sure the volume is set to highest.
If non of the above seems to be the cause of problem, then it means the phone speaker/ringer is defective because that's what brings out sound.
Regards.
Jan 06, 2012 | Samsung Galaxy S GTI9000 Smartphone
Droid X phone won't ring for incoming calls.
Found on Motorola Support:
1. Make sure that the "Smart Profile: Face Down" feature is enabled.
2. Hold the phone face up in your palm.
3. Call your Droid X from another phone.
4. As the phone is vibrating, DO NOT ANSWER.
5. Still holding the phone, flip the phone face down as it vibrates.
6. Still holding it face down, hit your volume key to silence the phone.
7. Flip the phone back over so it's face up. You should feel a quick vibrating jolt indicating the ringer is back on.
8. End the call. It shouldn't matter which phone you end the call from, as feeling the jolt is the key.
9. Leave phone face up and call yourself again. If the ringer is now working again, turn OFF "Smart Profile: Face Down" until there's a true fix.
10. If it does not work initially, try all of the steps again a few more times and hope you get lucky.
Jul 29, 2010 | Google Android
-Ringer is on 1. How to increase volume?
check wheather the phone is in silence mood and change the settings and then change ringer volume .
Jul 14, 2010 | Panasonic KX-TG1033S Cordless Phone
How can I turn off the ringer on a secondary phone?
go to phone menu.
go to profile.
select a profile and personalize it.
select silence and activate the profile.
May 27, 2010 | Samsung Prostar 816 Phone
DECT 6.0 Is it possible to silence the ringer?
how do you shut down the ringer on my vtech dect 6.0 phone
Mar 11, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Silent mode (vibrate only) capability
Although there is no real profile support in the SCH-u740, a simple downward press on the volume rocker lets you quickly silence the phone, while pressing upwards will reactivate the normal ringer.
With the phone open, a long press on the 'T' or '#' key will toggle the VIBRATION mode. The device comes with 11 ringtones built-in, but they are very basic sounding.
Jan 17, 2008 | Samsung SCH-u740 Cellular Phone
Samsung Convoy Cell Phone Logo
176 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
