Question about Samsung 4 Channel Dvr
How to configure ip address for samsung dvr shr 1041
Forgot my password
Posted on Dec 09, 2013
Is this dvr capable of recording OTA TV?
The SHR-2082 cannot record OTA TV because it does not have a tuner. It is meant to record video from a set of security cameras.
The manual for the SHR-2082 is available from Samsung support here: http://www.samsung.com/us/support/downloads/SHR-2082 .
I wish that I had better news for you.
Jun 17, 2011 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung SHR-1041K. Cannot connect to DVR system "Unknown Error"
Samsung 1041k DVR - Camera Web Server Solutions. ' UNKNOWN ERROR' OR 'CANNOT CONNECT TO SERVER'
Holy Smokes! Can't anyone write a simple solution? The manual totally sucks. It tells you everything except the details that will complete the puzzle. The answers here, so far, are written by gearheads who can't write an easy sentence.
1. The user name is case-sensitive. So if you program the DVR with a user name it will only take capital letters by default ... so when entering the user name (USER ID) in the web setup ... It MUST BE CAPITAL LETTERS otherwise you will get an 'unknown error'. There is no mention of this important little fact anywhere....
2. Use Internet Explorer ONLY (becase of old Active X controls), not FireFox, Chrome, or Safari...etc...etc. IE9 doesn't like it either .. just goes white for the most part or flickers ..so IE8 seems to work best.
3: When programming the DVR Box using the MENU button and the 'NETWORK OPTION ...Use Port 6100 in the NET CLIENT PORT. In the WEB SERVER PORT use port 80. The difference is ... port 6100 is used for the basic connection of the network to the DVR device and camera hardware and software ..... and port 80 is for viewing through Internet Explorer. (Port forwarding in the router must direct those ports right back to the IP address of the DVR (whatever you set it to). TCP and UDP together work just fine... not necessarily one or the other . I tried it both ways .. they all work.
4. If you are lucky enough to finally get Internet Explorer to hit the DVR software via the correct IP address and port of the DVR.... then it will prompt you to install the Active X control software embedded in the DVR. You might hae to refresh the screen a couple of times for it to download and install. If indeed it does then you will get a blank box that will wait for you figure out you need to click on a little wrench to configure the DVR connection. Add the DVR (give it a name). Enter the IP address it was configured with .... and set the port to 6100. Remember to capitalize the User Id and put in the password and save .. Completely IGNORE the confusing little matrix boxes that are used for setting up multiple DVRs and cameras. Save the setup, it wil take you back to the blank Samsung box interface and wait till you figure out to hit the connect button in the center. If you did it all correctly then you should connect to the camera views..
4. If you are going to view the cameras from the home network .... then enter the IP address assigned to the DVR PRECEEDED by http:// . Believe it or not it seems to make a difference. If you are viewing from ..say .. your work.. put in the numerical address of your home IP address and if you have the port forwarding set up correctly you will be forwarded directly to the DVR camera software where you can sign in and see the screens.
I have set up many, many IP cameras and various DVRs and software packages professionally.. I must say that this DVR and software is not very intuitive and was very difficult to get past some of the issues. The included instructions were of little help. I hope this helps somebody else.
Gary
Jun 28, 2010 | Samsung 4 Channel Dvr
Can't view my cameras
The DVR will be programmed with an IP Address via the DVR main menu function (network settings) and a valid password. The network viewing software (web viewer) you will need to ensure that the IP address is entered correctly for your DVR along with your valid user password.
Trust the above info is of assistance if you require a manual in order to check your settings try this link http://tv.manualsonline.com/manuals/mfg/samsung/samsung_dvr_product_list.html
May 23, 2010 | Samsung 4 Channel Dvr
I have a shr 1041, I can view on computer using network cable but do not know how to view off site. any help? Thank you
Your DVR has a built in webviewer. Connect the RJ45 network cable from DVR to your DSL router. Now the IP address of the camera is all you need to type in the browser to see it.
Let me know if you want to broadcast it over the internet as well.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 21, 2010 | Samsung 4 Channel Dvr
SHR-1041 network access problems
You can try adding it to trusted sites on IE. It worked on two of my machines. One running XP Pro and the other on Windows 7 Pro. I am having troubles with Windows 7 Home and Vista though (same problem) . So I could use a little help myself.
Jan 02, 2010 | Samsung Home Security
I can't configure my Samsung SHR-1041 for remote
It depends on the router you are using but you should be able to open the dvr in your router to get through your firewall.
Dec 29, 2009 | Samsung 4 Channel Dvr
Samsung dvr shr 2082
go to samsung-security.com and type in shr-2082 to get to archived discontinued literature.
May 09, 2009 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
LINKSYS ROUTER
You need to know the ip address of your dvr. It might have a factory set ip address or a dynamic ip address from the router. You can then use this ip address to access your dvr.
If your dvr has a static ip, that static ip should be in the same range as the router's ip address so that the router can communicate with the dvr.
Mar 12, 2008 | Linksys Wireless-G WRT54G Router
Shr 2082
Question is pretty broad, what specific issues are you having connecting to the internet with your SHR-2162?
This is the link to the user manual for SHR-2162, http://www.samsungsecurity.com/files/product/SHR-2162(P)_User_eng.pdf . It might take a while to load because it is 190 pages. You would need to review Chapter 5-8 and 5-9 (for Network Setup on the SHR-2162 & Chapter 9 Smart Viewer.
You would need to install the Smart Viewer s/w on computer you would like to use and also you would need to setup the SHR-2162 for networking (ie are you using static or dynamic IP?). If you are still need troubleshooting, please ask specific networking questions so that I can help you.
Jan 14, 2008 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung 4 Channel Dvr Logo
75 people viewed this question
Top Samsung Home Security Experts
Mike
Heilcode
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
