Question about Toymax Viore 42 in. Plasma TV
I have a viore 42" tv model#-PDP42V18HA,i have no picture or sound.The green power light comes on but thats it
I press the menu,channel and sound buttons and nothing
SOURCE: Magnavox 32mf231d - Just a blinking green light, No Power
I had this problem, but saw other places that it was a cheesy capacitor on the power supply circuit board causing this. I opened it up and took the power supply board out and it was obvious which capacitor was bad...top was bulging and had black stuff on it. It was rated 2200 uF @ 25V...got a new one @ Radio Shack that was 2200 uF @ 35v. Soldered it in (I stink @ soldering, but gave it a shot and it was EZ). Watching the first weekend of college football w/o waiting on a flashing green light for up to an hour so the TV would start! I'm going to try to find the other websites that directed me to this to say THANK YOU...BTW my brother used to have fits with several Magnovox TV's and thier power supplies back in the old tube style TV days. I thought I didn't need to worry about this with an HD flatscreen, but was wrong. I will think twice before buying a Phillips/Magnavox/Funai/whatever else they are again. They have a long list of complaints and I believe a class action lawsuit to refer to about this problem. They should have stepped up and done something!
Posted on Sep 05, 2009
  • 2973 Answers
SOURCE: my viore 42 in plasma is not projecting image. I
The video IC module seems to be giving problems. Open the back cover and take a peep inside. Look for the module just short of the screen. replace it if need be.
Posted on Nov 07, 2009
maatmartin7
  • 1229 Answers
SOURCE: Maganovox 37'' power button not lighting up anymore.
Set your volt meter to the diode check and measure across the white fuse [power off and unplugged],Shuld read zero. Then the fuse is good, an open fuse will have no reading. If you replaced the caps....be sure the voltage is the same or greater. The Mfs must be the same...and most importantly be sure they are 105dgrees. In some cases they could be 125 degrees. If you replaced them with 85 degrees you will definitly not get a good start up. And always be sure you check the polarity on the caps to the board. The board should show a plus or minus. The long leg on a new cap is always positive. Locations for the caps I believe are2074 which is 25volt 2200Mf and cap 2081 is 35volt 1200Mf and a third cap 2066 at 16volt 10Mf. Be very careful with cap 2066 as the trace on the board can be damaged when you unsolder this! Good Luck!
Posted on Jan 13, 2010
  • 37 Answers
SOURCE: dish network code for a viore, volume/power not working
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Posted on Jul 06, 2010
  • 70 Answers
SOURCE: MY VIORE PDP42V18HA HAS NO PICTURE ONLY SOUND 1
it is the y-sustain board that has a blown fuse.. it is problably the one on the left. by replacing the fuse wont solve the issue, you need to replace the whole board.
Posted on Dec 24, 2010
Viore 42" (PDP42V18HA) HDMI WOES
More than likely you ruined the HDMI circuit. Over twice the required voltage is never good.
Jul 11, 2016 | Vizio 42" viore pdp42v18ha 720p widescreen...
I have a viore led42vf80 when turning on the light turn green but still no picture or sound can you please help me
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jan 20, 2015 | Viore 42" 1080p Led42vf80 Lcd Led Hdtv
Viore tv troubleshooting
if you get no menu then it might be the lighting control board.
its it bright white but no video then you likely have video board issue .
youll need help. working on the inside will put you eye out
Aug 03, 2014 | Viore 42" 1080p Led42vf80 Lcd Led Hdtv
MY VIORE PDP42V18HA HAS NO PICTURE ONLY SOUND 1 BLOWN T4 FUSE ON VIDEO BOARD CANT FIND A CERAMIC FUSE TO BUY
Dec 04, 2010 | Toymax Viore 42 in. Plasma TV
Viore tv sound but no picture
the sound suddenly stopped working on my Viore 42" plasma.
Aug 17, 2010 | Toymax Viore 42 in. Plasma TV
I have a viore model pdp42v18ha with no pic but has sound. in the main supply board it sound like one of my transformers is cracklin like rice crispies. any suggestions will be great
The power board has definitely failed. Sounds like a short that could be causing the cracklin sound.
http://www.shopjimmy.com/sanken-3501q00201a-power-supply.htm
I have ordered from this place before with fast shipping and no problems.
Hope that helps.
May 12, 2010 | Gateway GTW-P42M303 42 in. Plasma...
VIORE LCD TV/DVD won't turn on
19 in wont turn on. red light just solid , unplugged for a day still same , is there a reset button
Aug 18, 2008 | Televison & Video
Plasma tv screen has green pixelating into pictures
I had the same problem and solved it with a factory reset. hold menu button dowm for 10 seconds and it will alow you to reset all the colors.
Feb 01, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Toymax Viore  42 in. Plasma TV Logo
166 people viewed this question
Top Toymax Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
