Question about Liebherr KIKNV3056 Bottom Freezer Refrigerator
How to tell the model number
Water flowing out the refrigerator
Is it coming out under the vegetable drawer? We just had a problem with water dripping down into the freezer. Check the drain at the lower back left of the refrigerator, above the bottom shelf to see if it is plugged. Water will be pooling there. If it is, use a turkey baster and warm water to flush it out.
I never found the serial number for our unit but used the model number from the manual.
Posted on Dec 10, 2013
How do I get water flow back after replacing a Whirlpool water filter?
The replacement filter may have been installed backwards with the flow direction arrow point toward the source.
May 11, 2014 | Whirlpool Refrigerator Water Filter
I have a whirlpool gold refrigerator, it is still making ice but no water coming out of water dispenser? Filter has been checked ok any answers?
Hello Jane
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable.
Best Regards
Neciforo Llanto
Sep 21, 2013 | Whirlpool Refrigerators
Water flow too slow on lg fridge
The solenoid on the water inlet vale is faulty and need to be replaced. Here is the part to order.
Nov 24, 2012 | LG LFX25960ST Stainless Steel French Door...
Water dispenser is not working
The water flow needs to be checked,if the flow of water is very slow or no water is flowing then water dispenser will not dispense water.But water flow is checked ok then other possibilities like water valve and water line needs to be inspected.For more details.Click the link below:---
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
This should help.Thanks.Helpmech.
Oct 20, 2011 | GE GSL25JFPBS Side by Side Refrigerator
My water has a lot of sediment in it and poor taste. I started installing a GXRTDR filter and have cut the line and inserted the line into the inflow end of the filter. I turned the water back on but no...
Not on the refrigerator, only where the water comes out of the wall to your refrigerator. First make sure the line is not clogged by removing the filter and making sure you have water flow through the hose. Then reattach the filter to the hose only and then make sure you have water through the hose and filter (may get a little messy). Then attach the filter to the refrigerator to see if you have flow. If you do not then your refrigerator water lines are clogged. Here is a video that shows how to fix problems like this:
Nov 21, 2017 | Kenmore 21.7 cu. ft. Top Mount...
Ge side by side refrigerator/freezer. Water flow is very slow from water dispenser. I have changed the water filter but water flow is still very slow. What might the problem be?
Could be low water pressure coming into the refrigerator or some kind of partial blockage in the water tubing within the refrigerator. I would first check at the on-off valve that connects the house water to the refrigerator tubing. Turn off the valve, disconnect it from the refrigerator line, hold the valve over a bucket, and open the valve. Does the water flow look good? The openings in these valves are very small and are easily stopped up with mineral deposits.
If the water flow is good at the valve, the problem is somewhere within the refrigerator tubing. I have found that plastic weedeater line is good for opening up blockages in these lines.
Oct 18, 2009 | Refrigerators
My Kenmore Refrigerator makes ice but will not dispense the ice through the door when the lever is depressed. There is no sound either. The water works fine.
Hi
Please accept this solution and ask for any further assistance.
Thanks
Rylee
Mar 22, 2009 | Kenmore Refrigerators
Water constantly runing to ice maker/ over flowing ice tray
Flow level has to be clean, or remplace.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/fredis_44a2b9c16ffcde8e
Jan 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Reverse osmosis causing poor water flow
cheak the main water flow and clean the machine inlet water filter
Jun 17, 2008 | Whirlpool GD5SHAX Side by Side...
Liebherr KIKNV3056 Bottom Freezer Refrigerator Logo
101 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
