Question about KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher
Error code - electronics malfunction
Hi, our Error Code indicates an "Electronics malfunction" according to the troubleshooting guide. The dishwasher starts, but doesn't ever get to the part where the water starts before it starts beeping.
    Top Expert:
  • KitchenAid Master
  • 12,957 Answers
You are in deep doo doo. When those electronic boards go, only repair is to get new board. Parts are proprietary and expensive. I prefer simple mechanical controls that are reliable and inexpensive to repair when and if. Check ebay for part - you just might get lucky if someone is parting out similar unit.
Posted on Nov 23, 2013
Error code 90
i90 error code means Check sum (model programming) MCF or Check sum CCF not OK, or in other words faulty electronics.
Dado
Feb 25, 2016 | AEG 23 in. Favorit 50750Vi Built-in...
E6 error code on fisher & pykel single door dishwasher
1-Time Flash & E6 error troubleshooting, part 1 of 3 for ...
? 3:04
https://www.youtube.com/watch?v=sYNN1Rvc7r0
Dec 18, 2012 - Uploaded by MitsubishiHVAC
1-Time Flash & E6 error troubleshooting, part 2 of 3 for Mitsubishi Electric Cooling & Heating - Duration: 2 ...
LG Control Panel Overview
www.lg.com > ... > Repair > Locate Repair Provider
LG ElectronicsAn OE error code indicates the washing machine is draining slowly or not at all. This is usually ... When you see the E6 error icon, it means there is a clutch error.
Nov 19, 2015 | Fisher and Paykel Dishwashers
What does a blinking orange light on 65" Mitsubishi dlp rear projection TV mean?
Self Diagnostics
The V18 Chassis features Self Diagnostics to aid in troubleshooting problems that may cause the set to
automatically turn off or "shut down." The "Timer/Power ON LED" provides an indication of the sets operation,
and the possible cause of a malfunction.
1. Initial Control Circuitry Check
Immediately after the TV is connected to an AC power source:
• The LED flashes three times ... indicating the Microprocessor has initialized and is functioning
properly.
• If the LED does not flash ... the Microprocessor is NOT functioning.
2. Error Code Operational Check
To activate the Error Code Mode, while the set is OFF, press the front panel "INPUT" and "MENU" buttons
at the same time and hold for 5 seconds. The LED will flash denoting a two digit Error Code.
Note: The Front Panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: For Error Code is "24", the LED will flash 2 times, pause, and then flash 4 times.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
"12" ... indicates no error has occurred.
"21" ... X-Ray Protect circuit.
"22" ... Short Protect circuit.
"23" ... Horizontal Deflection failure.
"24" ... Vertical Deflection failure.
Jul 24, 2014 | Mitsubishi WS-65809 65" Rear Projection...
Keep getting code e1
According to page 24 of your owner's manual, the E1 error is indicative of a short circuit in the Indoor Air Thermistor. The unit will likely require service.
Good luck,
Marty
Jun 21, 2014 | LG Electronics LP0910WNR Portable Air...
Need manual
Good Morning Steve - I am happy to assist you, however according to my database I'm not showing that Frigidaire has an error code FR for a dishwasher or for any product for that matter. Could the error code possibly be an ER, PF, FL or RF?
· Typically error code ER indicates that the main control board has detected a stuck key or a key pressed for more than one minute.
· Generally error code PF means that the dishwasher has experienced a power failure and you should be able to resume the cycle.
· Error code FL is advising you that the water valve is in the open position.
· RF indicates that the rinse aid reed switch in dispenser is open and needs to refill the rinse aid.
Let's try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the dishwasher. If issue persists, then I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
I hope these troubleshooting tips help you in some small way.
Jun 25, 2013 | Frigidaire Professional Series 24 in....
Error code oE
According to page 25 of the users guide you can download from Samsung's web site at http://www.samsung.com/us/support/owners/product/DMR57LFS oE means, "Water level error (over-level)"
Jan 20, 2013 | Samsung DMR57LFS Stainless Steel Builtin...
F70 error code
F 70 error code indicates a communication problem between the component electronics and the control electronics. You will need an appliance tech to come to your home to service it.
May 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Hello, i ve buyed a honda accord ex 1993 model ,but in that the radio is not working i mean its asking to enter the code ...........so can u suggest me the code for the car.
Their is a code inside your owners manual if you have it. IF you do not have it then you can try and follow the step by step guide at the following link.
http://www.hondaaccordforum.com/forum/audio-visual-electronics-10/accord-factory-radio-display-error-e-code-instructions-32694/
Jun 04, 2011 | Car Audio & Video
My dishwasher keeps flashing F1 error message
The f1 code is caused moisture in the electronics part most likely in the door.see if there is any way that you can see where moisture might get in and plug that spot up. In the case of the f1 code when not using the dishwasher leave the door propped open to help dry out the electronics.
Nov 18, 2008 | Fisher Dishwashers
Clean light flashes 7 times
Here's what I could find on the your error code:
A blinking clean light that flashes 7 times and cannot be reset, occurs when the electronic control does not detect a water temperature increase during the main wash. This could be an indication of a failed heating element, in line thermostat, electronic control board and/or wiring. This problem can also occur if the main wash pump becomes clogged and it not spraying sufficiently. I hope this helps you.
PS A faulty door latch can also cause this error code.
NOTE: There should be a tech sheet located behind the lower panel under the door that lists all the fault codes and how to troubleshoot them. If you need further assistance, please let me know.
Jun 20, 2008 | Whirlpool 24 in. DU1050SS Built-in...
KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher Logo
90 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
