Question about MedQuip MQ5800 Rotary Piston Mini Nebulizer
Problems setting up a MQ5800 nebulizer for the first time
Do not know where the filter goes
Where does the filter go on a mq5800?
YOU SHOULD BE ABLE TO LOOK INSIDE AND ON OUTSIDE AND NOTICE THE FILTER AND WHERE ITS LOCATED AS PER UR MODEL, SEE THE PICS
May 15, 2015 | Refrigerators
Where can i buy a filter for the nebulizer
You can buy a filter for a nebulizer at just about any pharmacy. Just to be on the safe side, I'd make a phone call before I drove to the pharmacy. If you were asking where you could buy a nebulizer filter online, go to opentip.com, csnstores.com, jrsmedical.com, amazon.com & the list goes on and on. I hope that helps!
Jun 18, 2010 | Inspiration 626 Compressor Nebulizer...
Where is filter?
It is located on the back of the penquin to the right of the on/off switch. It looks like a black knob. Simply pull it out.
Nov 11, 2009 | Penguin Nebulizer Neb U Tyke Ic Nebulizer...
Sterlize my nebulizer
From Pari.com:
What is the best way to clean and disinfect my PARI Nebulizer?
Cleaning: After every treatment, thoroughly rinse the nebulizer to remove medication. Hand-wash with warm water and dish soap. Rinse thoroughly. OR... Wash in the dishwasher using a dishwasher basket on the top rack.
Disinfecting: (done after cleaning) every 2nd treatment day, mix a solution of 1 part distilled white vinegar and 3 parts warm tap water in a clean bowl. Soak the nebulizer parts (except the tubing and mask) for 60 minutes. Rinse thoroughly. OR... Mix a solution using Control III® Nebulizer Disinfectant and soak for 10 minutes. Rinse thoroughly. OR... Boil the nebulizer parts for 10 minutes.
Source: http://www.pari.com/pdd/pdd-faqs.htm
Apr 20, 2009 | Pari Proneb Ultra II Compressor Nebulizer...
Routine cleaning Mabis XP.
If your unit is the one pictured, he cup with the medication can be taken apart to be cleaned... the top unscrews and the nebulizer comes out....and should be done so after every use. Do not use house hold chemicals to clean the unit. Use a water/distilled vinegar mixture to clean, then rinse with clean water.
Apr 07, 2009 | Mabis Neb Xp Portable Handheld Cmpressor...
Omron nebulizer will not mist. All tubing is intact. What to do?
You'll read a lot about making sure that the filter is clean and that the medicine cup is cleaned and that hard water can effect the operation of the nebulizer. However, the problem is most likely in the pump. Even though the pump is running, it is not pushing enough air into the medicine cup. You may even feel air coming out of the tube. When unrestricted, the air will come out, but, once restricted by the medicine cup, the air may not be fast enough to nebulize the liquid. If you want to confirm this, take the tube and hold it to the end of a bike pump, if, while pumpung, you successfully see mist, then you know for sure.
Fixing the pump is not too difficult. Over time, the chamber where the air is compressed becomes dry and, just like a dry bike pump, the air escapes from the chamber due to poor seals. The pump is pretty simple. Make sure it is unplugged from power and remove the screws holding the housing together. Inside you will see the motor, a fan, a power switch and the intake and outtake tubes. Follow the outtake tube to the pump. The junction where the tubes meet the pump is the location of the air chamber. You may need to remove the screws that secure the tubes to the chamber. Once apart, take some grease and lightly coat all of the interior surfaces of the chamber. When finished, reassemble and you're good to go!
Mar 23, 2009 | Omron Healthcare Omron NE-C25 COMP-Air...
Probasic riteneb
If it looks like fog coming from the mask it is doing it's job,If not,the filter may need changing.(A little water goes a long way in those machines)
Jan 07, 2009 | Probasics Rite-Neb Mini Compressor...
Nebulizer filters
Hello annb19702,
The nebulizer you have is made by Invacare Supply Group. You can order online at onlinemedicalsupply.com or you can call them at 1-800 860-0305. Have a nice day. and please dont forget to rate me.
Mike
Sep 19, 2008 | Probasics Rite-Neb Mini Compressor...
MedQuip MQ5800 Rotary Piston Mini Nebulizer Logo
54 people viewed this question
Top MedQuip Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a MedQuip Health and Beauty Expert? Answer questions, earn points and help others
