Question about Sony Ericsson T630
T630 not power problem
Hard resetting a lexmark T630
Press Select and Return buttons at the same time while printer is powering on. Once you have the Config menu, choose Factory Defaults, then hit Select.
Apr 02, 2010 | Lexmark T630 Laser Printer
I have a Lexmark T630 with the message control panel disable when I'm traying to change a setting.
with the power off hold down the select and return buttons while holding power up till the printer comes to performing self test wait until the config menu show in the control panel. toggle the right arrow till you get to panel menu hit select use the right arrow to change to enable hit select it should say setting saved and your problem is gone
Nov 27, 2009 | Lexmark T630 Laser Printer
My Sony Ericsson T630 asks Phone Unlock code when I switch it on
if you havent changed the code from the original the code should be the last four digits of your phone number
Aug 28, 2009 | Sony Ericsson T630
Lexmark T630 frozen
Try to unplug the interface cable from the computer and power up the machine. It is likely the RIP card aka the controller card.
There are two types of controllers for this printer, non-network and network. Here are links to where you can purchase them:
Non-network
Network
Jun 06, 2009 | Lexmark T630 Laser Printer
Need a program
hi just install the sony ericsson pc suite.
http://www.sonyericsson.com/cws/support/phones/detailed/whatissonyericssonpcsuite/t630
you will eather need a wire connection or bluetooth.
Mar 29, 2009 | Sony Ericsson T630
Problem with a T630 Lexmark the message "Change Tray 1 Plain Lett
i take it that the printer does not go to ready? does you printer stop with 64mb in the display? if it does change the network card. if this isnt the problem some more info would be great
Mar 27, 2009 | Lexmark T630 Laser Printer
White display on sony ericcson T630
Hi. Ift's a common problem and requires a new LCD. It's an easy job. There's a guide here and you can buy parts from the site http://www.formymobile.co.uk/Dismantle/t630_dismantle.htm
Nov 12, 2008 | Sony Ericsson T630
T630 wont turn on after flashing
YOu can always flash? did you restore firmware after flashing? if not try to restore firmware and also write a good GDFS file
Jul 30, 2007 | Sony Ericsson T630
Sony Ericsson T630 Logo
11 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
