Question about Dishwashers
My GSD2200G00WW dishwasher motor does not turn on
The motor hums but does not turn on
    Top Expert:
  • Dishwashers Master
  • 12,962 Answers
Do not turn on again !!!!!!!!!! Motor is jammed and will not turn. You are risking burning out the motor windings and rendering it totally unusable. Expensive part.
If unit has not been operated for a while it is possible that the bearings may have seized temporarily. Since those motors do not develop high torque at start up it will stay stalled and burn out if powered up.
Get to motor and make sure that you loosen the shaft with a good pair of vise grips and possible extension for leverage and power.
Posted on Nov 23, 2013
2 Suggested Answers
SOURCE: Turn on unit and motor just hums
The motor bearing is more than likely broken. The seal eventually start to slowly leak its way to the bearing. It then rusts and breaks.
New motor is the solution. Almost imposible to just replace just the bearing due to the way the motor is manufactured. If you are technical its not too hard to replace.
Posted on Jan 01, 2010
Ge dishwasher gsd2204
Check this out for the GE GSD2200 series dishwashers.
https://www.geapplianceparts.com/store/parts/assembly/GSD2200D03
If you find the link does not work then go through to the GE Parts website and type in GSD2204 in the model search.
Apr 23, 2014 | Dishwashers
Dishwasher fills with hot water then does nothing
Do you get any humming noise when you turn it ON?
How long its been you used the dishwasher last time...?
If you are getting an humming noise then Sounds like the water circulator pump is stuck. The motor tries to turn it (humming noise), but cannot. So a breaker trips (self reset). Not claiming this is actually the problem, but this is what the motor turns.
Aug 30, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
GE Dishwasher motor hums but doesn't engage.
These motors will stick sometimes during periods of not being used. With the power turned off to the the dishwasher, remove the front lower grille. There are usuallly 2 screws on each side of the panel. Looking under the D/W your will see the motor and pump assembly. If you feel around you should be able to feel the motor's cooling fan. Simply rock the fan back and forth and the motor/pump should become unstuck.
Jun 21, 2010 | GE 24 in. GSD2000Z Built-in Dishwasher
Would like a wiring schematic for GSD2000F00WH model dishwasher motor hums but no action from motor
I removed plug to motor, found the fan blade and rotated stiff blade til it became easy to turn reconnected plug to motor turned Dishwasher on added soap and happy days are here again
Oct 06, 2009 | GE Dishwashers
Dishwasher just hums, faintly, when I turn it on.
motor is locked up.. if you let it hum faintly for a couple min it will cut out most likely.. thats the thermal trip built into the motor.. the motor assm needs to be replaced..
Apr 10, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwasher starts to fill then just hums
Sounds like a motor problem. Behind the chopper is an access to the impeller, try turning the impeller or the chopper blade and see if the motor will rotate. If it doesn't, then something is stuck preventing the motor from running.
Mar 07, 2009 | Dishwashers
Dishwasher GU1500 Whirlpool--motor just hums and blades do not turn. Dishwasher fills correctly and drains well.
this strongly indicates the motor capacitor - normally mounted on or close to the motor. easy to replace and a cheap part. also possible motor seized - disconnect from mains and see if motor turns by hand
Aug 27, 2008 | Dishwashers
I HAVE A GSD2200G00WW GE DISHWASHER; BUT YOU DIDN'T HAVE IT LISTED.
Use a HE type detergent, Cut back on how much used, Discontinue the use of jet dry.
Jun 24, 2008 | GE 24 in. GSD2000Z Built-in Dishwasher
Frigidaire dishwasher does not clean
the start switch in the motor is probably bad,it could also be the motor relay.if you can get to the motor run the unit and while it hums try to turn the motor.it also could be something is stuck in the motor let me know.
Aug 13, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher fill with water then just hums
the hum is probably the main pump powered up but not turning. the pump is an induction motor and a usual fault is the motor capacitor. try to access it, find the value of the capacitor and replace. it is a cheap part
Apr 02, 2007 | Kenmore 24 in. 16039 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
