Question about Consumer Cellular Motorola WX416 Full Featured Cell Phone
What does the headphone icon mean when I connected to UCONNECT/
Want a manual
When will UConnect be available with the iphone
Uconnect® Access for Chrysler, Dodge, FIAT , Jeep & Ram https://www.driveuconnect.com ... the next generation of in-vehicle connectivity system for Chrysler, Dodge, FIAT, Jeep & Ram ... There are several Uconnect ® Systems available ... iPhone and ...
  • Services and Apps from Uconnect® Access www.driveuconnect.com/features/uconnect_access UCONNECT ® Access. Learn how Uconnect ... Check out the features and applications that are available on your Uconnect ... iPhone and iPod are registered trademarks ...
  • Uconnect Access on the App Store - iTunes - Apple https://itunes.apple.com/us/app/uconnect-access/id550295151?mt=8
    • 1.7/5
    • 106 REVIEWS
    • FREE
    • LIFESTYLE
    2016-02-25 · Download Uconnect Access and enjoy it on your iPhone, iPad, and ... and if/when they will be available inside ... a compatible Uconnect 8.4 or ...
  • Iphone and Uconnect ' Apple Support Communities discussions.apple.com > iPhone > Using iPhone
    • 6 POSTS
    • FIRST POST: 2011-01-19
    2011-11-16 · ... Just an update to everyone experiencing connection issues with the iPhone 4 and the Chrysler Uconnect handsfree ... when it became available a couple ...
  • Set Up Your Phone for Voice Texting ' Uconnect ... - YouTube www.youtube.com/watch?v=R8SaEXTJiTE
    • BY UCONNECT®
    • 3 MIN
    • 50K VIEWS
    2013-12-23 · Video embedded · We'll show you how to set up your phone for Voice Texting† once ... ††Uconnect® Access is available only on equipped ... iPhone uConnect ...
    • 1.7/5
    • 106 REVIEWS
    • FREE
    • LIFESTYLE
    • 6 POSTS
    • BY UCONNECT®
    • 3 MIN
    • 50K VIEWS
  • May 14, 2016 | 2015 Jeep Cherokee
    How to connect my phone to my car system?
    Not all Chrysler products have uconnect; it may show the button on the radio, but if the uconnect system isn't installed you get the error you're getting; My Dodge Nitro is the same. You can buy the uconnect from the dealer or off of eBay (they run about $300, plus it has to be installed) Details about Dodge Chrysler Jeep Ram Hands Free Uconnect Kit OEM MOPAR
    May 24, 2015 | 2010 Chrysler 300 Touring
    Why won't uconnect work in 2013 chrysler200
    There are a few things to note. The pairing has to occur between the Uconnect device in the Chrysler 200 and the Samsung S3 using bluetooth. I noticed there are 4 possible Uconnect systems available. Depending on which one you have you can check the recommended cell phone to go with it. Samsung S4 is defnitely compatible to all of the of them and SIII also with some. But that does not mean SIII will not work with others. It just means it may not have been tested.
    Go to this link and select the vehicle model and year and then follow the instructions to get to the correct pairing instruction. If SIII is not listed I would still check S4. Should not be much different.
    Chrysler Uconnect
    Aug 07, 2014 | Chrysler Cars & Trucks
    Uconnect instructions
    My 2010 Dodge Ram appears to have uconnect. However, I can not get my phone connected. When I try it says not equipped with uconnect phone. Is this a fake display? Or do I have to have a certain phone hook up?
    Jan 12, 2014 | Chrysler 300M Cars & Trucks
    Need set-up Information for Blue Tooth phone in Chrysler Pacifia 2005
    I found the link below containing a download of the .pdf file and also pasted the phone pairing portion below it. These instructions are exactly the same as when pairing to my system in my '08 Caliber,so they're probably universal. Keep in mind, though, that the system just may not be fully compatible with your phone. EVERYTHING that Chrysler makes is EXTREMELY finicky-and you may be doing everything right! Before you begin, set your phone into its pairing or "find me" mode, then press the UConnect button. I hope this helps! Good luck.
    http://dcxtraining1.com/dcxtraining1/docs/ExperienceFreedom_UConnect.pdf
    Linking to UConnect – Required for First-time Use of Each Mobile Phone
    To complete the pairing process, the mobile-phone owner’s manual will need to be referenced. One of the following vehicle-specific Web sites will also provide detailed instructions for pairing with the phone: www.chrysler.com/uconnect, www.dodge.com/uconnect and www.jeep.com/uconnect.
    • Press the Phone icon button to begin
    • After the Ready prompt and subsequent beep, say Set Up Phone Pairing
    • When prompted, after the voice or beep, say Pair a Phone
    • You will be asked to say a four-digit PIN that will be needed later to enter into your mobile phone. You can use any four-digit PIN. You will not need to remember the PIN after the initial pairing process
    • For identification purposes, you will be prompted to give the UConnect system a name for your mobile phone. Each mobile phone that is being paired should be given a unique phone name
    • You then will be asked to give your mobile phone a priority level between one and seven, one being highest priority. The priority allows the UConnect system to know which mobile phone to use if multiple mobile phones are in the vehicle at the same time
    Making a Phone Call
    • After the Ready prompt, say Dial
    • The system will prompt you to say the number you wish to dial
    Making a Phone Call Using Your UConnect Phonebook
    • After the Ready prompt, say Call followed by the name and designation of a phonebook entry you wish to dial – for example Call, then John Doe, then Work
    Terminating a Phone Call
    To end a call in progress, press the Phone icon button. All calls in progress will
    be terminated.
    Phone Redial
    • After the Ready prompt, say Redial
    • The UConnect system will call the last number that was dialed on your mobile phone. This may not be the last number dialed by the UConnect system
    Answering or Rejecting an Incoming Call - No Call Currently in Progress
    When you receive a call on your mobile phone, the UConnect system will interrupt the stereo audio to ask if you would like to answer the call. Press the Phone icon button to answer the call. To reject the call, press the Phone icon button until you hear a single beep indicating that the incoming call was rejected.
    UCONNECT
    CHRYSLER GROUP TECHNOLOGY 17
    Dec 29, 2009 | 2005 Chrysler Pacifica
    What does the headphones icon on Motorola v170 cell phone mean?
    it usually means there are headphones connected to your phone, i would take out battery and put it back in. cell may be confused wth usb port or something
    Aug 24, 2009 | Motorola Mobility V170
    HTC Touch Diamond has a constant headphone icon
    The headphone icon means that you are connected to either a headset or bluetooth for external audio.
    If these are not plugged in or running, it would be the headset connector is stuck, thinking that you have a headset still plugged in.
    Unfortunately you wil need to visit a service centre for this.
    Try turning off all wireless, incl bluetooth and see if this goes away
    Jan 15, 2009 | HTC Touch Diamond Smartphone
    Consumer Cellular Motorola WX416 Full Featured Cell Phone Logo
    75 people viewed this question
    Top Consumer Cellular Video Game Consoles & Games Experts
    James Wishart
    Are you a Consumer Cellular Video Game Console and Game Expert? Answer questions, earn points and help others
