Question about Vacuums
I lost my manual for hoover exclusive 2 tank cleaning system
Hoover quick & lite carpet cleaner stopped spraying solution. What can it be
Hey, this is Jeremy with Crucial Vacuum,
Sorry to hear you are having difficulties with you Hoover Quick & Lite. There are a few different things we can try to fix your hoover and get you cleaning again.
1. The sprayers may be clogged. Over time they will get clogged with soap and mineral deposits. This is a natural thing to happen, so don't fret. Fill you tank with a solution of half warm water and half vinegar. Let the mixture sit in the tank while the vacuum is running for awhile and then try to spray solution. This should loosen up anything clogging the sprayers and allow for a consistent flow of liquid.
2. Your handle may mot be attached properly. To fix this remove the 2 screws at the base of the handle on the back of the vacuum. Check the control arm inside. Make sure they are aligned properly. Below I have attached a video showing you how exactly they should look.
https://www.youtube.com/watch?v=UXwLERxWjGU
3. The clean water solution tank is not installed correctly. Make sure the tank is attached firmly to the gasketets and nothing is out of place. Below i have attached a link to your vacuums manual which has diagrams for exactly how the tank and unit should fit together.
http://hoover.com/file/958/
You can purchase replacement parts for Hoover direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/hoover.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jul 12, 2015 | Hoover Vacuums
Hoover F7425-900 SteamVac V2
http://www.hoover.com/pdfs/manuals/F7452900.pdf Heres a link to the manual if you dont have one, Ive emailed them and they gave me the same solutions that are on page 17. ? Make sure tank is securely locked in position ? Clean water tank or detergent container empty ? Refill container according to instructions for surface being cleaned ? Recovery tank lid not on correctly ? Make sure lid is firmly in place ? Valve cap clogged ? Remove and clean valve cap (see following instructions) 1. Remove clean water tank. 2. Turn valve cap (A) counterclockwise and remove. Soak valve cap in warm water for at least 15 minutes. Wipe cap dry. 3. Align slots (B) on cap with tabs (C) in opening. Turn cap clockwise to tighten.
Sep 17, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
How to clean brushes on hoover steam vac?
Hi, it's Allie from Crucial Vacuum!
Cleaning the brushes on your unit is a very easy and important tank to do! Your deep cleaner is equipped with removable brushes for easy cleaning. First, make sure to remove the clean water tank and recovery tank to prevent possible leaking. Tilt your unit backwards making sure the handle is in the upright position. Grab the brushes and pull firmly. You may clean the brushes with running water. Do not forget to check the brushes for any tangled hair strands or debris that can prevent the brushes from spinning properly.
You can purchase direct your replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Alejandra (Allie) Sepulveda-Rivera
Aug 21, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Install upper control rod
Hi, it's Jeremy from Crucial Vacuum.
To attach the upper handle to your Hoover Steam Vac remove the clean solution tank (upper tank) from the deep cleaner. Then, attach the upper handle to the lower handle by pushing the upper handle down onto lower one. Use the provided bolts to secure the handles. Push the bolts into the accompanying holes on the front of handle. If the bolts do not go through the holes easily, your handle is not pushed completely down. When the handle sections are completely together, squeeze the trigger on the upper handle to snap the trigger rod into place.
If you require further help with your assembly, you can find a step-by-step manual at: http://www.searspartsdirect.com/partsdirect/user-manuals/f5865900-hoover-parts-steam+vac-manual
You can also purchase all of your Hoover Steam Vac replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover+steam+vac
Jeremy Lerner
Jun 10, 2014 | Vacuums
I have lost my owners manual and need to find out how to hookup upholstery cleaning tool
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner2_bing.gif handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
May 01, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I lost my instruction manual to my hooversteamvac and need to know how to hook up the upholstery tool
Hi There,
tank aside (do not set tank on furniture).
on the floor.
remove lid.
tube.
tank.
before cleaning.
and solution tube.
Raise carpet cleaner handle to upright
position.
Thanks again,
Chris J.
GoVacuum.com
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
How does it work lost instructions were does soap go what tank does water go into
There are 2 containers in the upper tank assembly. The Soap goes into the smaller one (no need to mix). Fill the other side with hot water. The lower tank is also called the recovery tank and this is where the dirty water is collected. You can find manuals for your model at the hoover web site if not the same one then any of the V2 or models that start with "F74" should work.
Oct 21, 2009 | Hoover F7431-900 SteamVac Vacuum
Instructions on Using The Hoover Steamvac Ultra cleaner
CARPET CLEANER\r\n™
i went the xtra mile to look this up you give me a incorect modlel # put the user guide are the same ps: dont for get to vote for me when it ask if i helped you lol sawdust46
MaxExtract™ technology features the most advanced
combination of multi-action agitation, carpet washing, dirt
removal and direct heat drying - all in one machine. This
technology delivers a floor that is not only deeply cleaned,
but a room that can be lived in again within hours!
• High intensity LED
- illuminates problem areas
• Stream Setting
- ideal for smaller spots
and stains
• Spray Setting
- attacks heavy traffic areas
Dual scrubbing1, multi-directional
brushes have been specifically
engineered to surround carpet
fibers, removing dirt at every angle.
1Patent pending
High velocity suction removes both
dirty water and soap residue, leaving
carpet revitalized. Forced heat further
speeds the drying process. No sopping
wet carpets. No musty odors. Just
clean carpet.
STREAM
SPRAY
REMOVES MORE DIRT2
INTEGRATED SPOT CLEANING
2Test of leading brands of household extractors using FCTP-0024p
Our exclusive pre-programmed
cleaning modes take the
guesswork out of revitalizing your
carpets. Simply select your carpet
type and cleaning task, and let
the pre-programmed modes take
care of the rest. Fully equipped
with Process Feedback Lights
and Full Tank Indicator Lights,
this Intelligent Cleaning System
makes cleaning your carpets
easier than ever before.
HOOVER PLATINUM COLLECTION™ DETERGENTS
TO MAXIMIZE CLEANING PERFORMANCE
PROFESSIONAL STRENGTH
Carpet and Upholstery Detergent
PET PLUS
CARPET CLEANER
Instant Stain Remover
Carpet and Upholstery Spray
AN EFFORTLESS CLEAN
CONVENIENCE IN HAND
Powered Scrubbing Tool,
Upholstery Brush and
Crevice Tool included for
cleaning fabric covered
items such as:
• Stairs • Upholstery
• Mattresses • Pillows
• Area Rugs
To learn more about the Hoover Platinum Collection™
visit www.Hoover.com ™ ®
Six new vacuums, six new standards of clean, and six
new reasons for Clean Freaks to Rejoice. The Hoover
Platinum Collection™ saves you time and effort while
giving you the confidence of knowing your home is truly
clean. Whether corded or cordless each item is distinctive
in both appearance and performance, offering best in
class cleaning through a combination of innovative
technologies and carefully engineered ergonomic design.
With the Hoover Platinum Collection™ you get fast and
effective deep cleaning so you can move on with what
is next in your day, knowing you have efficiently
accomplished the deep clean you desire. With these six
superior cleaners from Hoover®, it is a wonderful time to be
a Clean Freak, and a terrible time to be a dirt molecule.
EXCLUSIVE HOOVER PLATINUM COLLECTION™ MEMBER SERVICES LINE:
1.877.MYPLTNM (1.877.697.5866)
Hoover®’s Best In Class,
Limited Six Year Warranty
Jul 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Clean Water Tank Leaks
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40471&thid=612034
Posted by Liviaa on May 21, 2008
The clean water tanks leaks. What's causing the problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Floormate H3000 Upright Wet/Dry Vacuum. You can down load the owner manual from the Hoover website www.hoover.com . It looks like the one of the holding or recovery tanks my not be in place, leaking, cracked or damaged, or the clear tube is leaking and needs replacing. I looked 2 the owner’s manual and it does not show the clear tube but the vacuum does come apart and just back track the clear tube and mark the screws when you disassemble the unit. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 21, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Vacuums Logo
209 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
