Question about Acoustic Research AR HC6 System
What kind of fuse do I need for Acoustic Research AR HC6 Sub
I pought a used AR sub and there is no fuse. Just the hole to put the fuse in. What type do I need? Just the regular glass tube ones?
  • 65 Answers
5 Suggested Answers
SOURCE: s112ps ar speaker need new one
I am selling one right now. 1.24.09 Call me 615.473.4676 Charlse
Posted on Jan 25, 2010
sparky1500
  • 1066 Answers
SOURCE: Just got two AR 312
do not use those speakers with that amp, those are 4 ohm speakers, which could damage your 8 ohm yamaha amp. you will have to get a 4 ohm capable amp to run the highs, and another 4 ohm amp to run the subs.
car amplifiers are currently 4 ohm, or even 2/1 ohm stable, but few, if any modern receivers can run at anything lower than 8 ohms without a danger of overheating. you may have to get a vintage amp(s), like a 1970's marantz receiver, or a 1980's to early 1990's kenwood power amp, because 4 ohm home amps are pretty scarce nowadays.
whatever amp(s)( you get, verify that they are DEFINITELY 4 ohm stable.
Posted on Nov 06, 2010
  • 5 Answers
SOURCE: i need manual of acoustic research hc5 sub
this one really strong so you can easly use this
Posted on May 16, 2012
bigbudget
SOURCE: Acoustic Research AR-1 Qusetion- LFE Input and Output functions??
using the LFE input will give you cleaner less distorted bass. You must have a sub out on your receiver or pre-amp. it will give you greater control over the bass output of your system. If you only have one sub-out on your receiver simpley run a 10ft rca from the sub-out of reciever to the rca input of either speaker than use the rca out of 1st speaker to the rca input of second speaker. check to see if you have control of the level of your sub-out on your reciever. adjust the 30hz boost on rear of speakers. now you will have bass that most people only dream of having.
Posted on Oct 26, 2012
Makes a loud humming noise when plugged in, even when it is not conncted t the AVR
Humming noise could be an indicator of bad capacitors in the amplifier. You can take the amp out, pull the cover off, and look at the capacitors. If they appear to be swollen at the top, with some brown ooze coming out of them, then they need to be replaced. You can actually do this yourself from radio shack parts, just get the proper sized voltage and uf capacitors, desolder the old ones, and solder the new ones back in.
I have to do this every 5 years, or so, to my old MTX home sub amp.
Jul 10, 2012 | Acoustic Research HD510 System
I need manual of acoustic research hc5 sub
May 16, 2012 | Acoustic Research S112PS Subwoofer
Just got two AR 312 HO speakers from my brother. I have a Yamaha HTR 6250. The speakers have (2) sets of cable hook up. One I assume is for built in sub woofers? Do I hook one normal and one to the sub...
Nov 06, 2010 | Acoustic Research 312 HO Speaker
May 20, 2010 | Acoustic Research AR1 Speaker
Well I also have a S112PS AR Sub Woofer Problem...
Are you sure it is receiving an audio signal to make it wake up? You don't mention what's upstream in the audio chain.
To eliminate mis-settings or lack of sub-related signal upstream, plug an RCA cable from a CD player directly into it and start a CD that fades in slowly because you won't have any way to lower the volume except to pause the CD. If the sub works you'll hear a muffled version of the program.
Apr 09, 2010 | Acoustic Research S112PS Subwoofer
Hello, the auto on on my acoustic research pr1212 doesn't work anymore. The unit just stays on all the time. It used to sense the signal just fine, but now it just stays on and I have to manually turn it...
Are you certain it isn't sensing a signal all the time? Disconnect its inputs first to prove it.
If you feel compelled to monkey with it, I'd start with the state of the Auto switch. It might be asserting "ON" instead of "Auto"
Apr 06, 2010 | Acoustic Research AR PR1212 Subwoofer
How do I connect my AR subwoofer to the tuner?
If your tuner has a sub out you use that together with a single rca cable for the signel
Jan 02, 2009 | Acoustic Research S108PS Subwoofer
S112ps ar speaker need new one
Jul 28, 2008 | Acoustic Research S112PS Subwoofer
Cerwin vega ht-10d subwoofer won't work in yamaha reciever
Well, as I know, your Cerwin Vega subwoofer is designed for use with stereo systems. Therefore, it has only 2 channels for input, and 2 channels for output as well. However, you can try this out; the first thing I suggest is that you hook up your main front channels through the subwoofer. All you have to do is to connect the subwoofer input to the front channel output on the amp, then hook up your front speakers to the satellite output on the subwoofer. As long as you make sure that system is working on 8 ohms, I believe this can activate the subwoofer.
Sep 15, 2007 | Athena AS-F1 Main / Stereo Speaker
Acoustic Research AR HC6 System Logo
108 people viewed this question
Top Acoustic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
