Question about Food Mixers
The lip of the planetary ripped off and I am having a trouble replacing it for a Kitchen aid K5-A mixer
The Lip of the planetary ripped off my old K5-A Kitchenaid mixer and the replacement part does not look like it. do you know how I can replace this?
  • Food Mixers Master
  • 1,248 Answers
The planetary is replaced by removing the chrome drip ring from the housing and then knocking the through pin out that holds the planetary hub onto the shaft from the gearbox. In New Zealand the planetary comes as individual parts not an assembled unit so will certainly look different to the full assembly you take off. The lip of the planetary ripping off is most likely caused by one or more of the 5 gearcase screws under the planetary coming loose and rubbing. Check the other 4 (total) screws at back and middle of gearcase as well.
Posted on Nov 24, 2013
Testimonial: "I did expect as quick of a response, and yes it probably ripped off because of the screws luckily, I got it off and even though I was uncertain about the way the planetary looked internally, it seems to work just fine. Now I need to figure out how to attach the screw to the speed lever so that i can control the speed of my machine. You don't by chance have pictures of an old k5-a kitchenaid mixer laying around. With details on reassembly of the motor? :)"
  • Erika
    Erika Nov 26, 2013
    Thank you!
SOURCE: I have a Kitchenaid Professional
hi
there is a ring clamp on top of the main worm follower gear on the drive shaft. you might not see it due to the grease.
you need to get one of those weird little pliers with points on them to spread the ring clamp to remove it. Then the gear is just friction fit on the shaft...it's pretty tight. I carefully used a screwdriver to slowly separate the main follower gear from the lower gear and it goes up the shaft....
after a bit you can wiggle the follower gear by hand and it will come up. Then you can see there is a pin holding the drive gear underneath it in place. The pin in my mixer was actually bent (must have been some tough dough).
then you reverse the process to put the gear back on -- except that the top follower gear has to go on the pin in the right orientation or the ring clamp won't fit.
buy your parts from mendingshed.com
hope it helps.
Posted on Aug 25, 2008
hslincoln
  • 235 Answers
SOURCE: i have a kitchen aid stand mixer KG25HOXWH.
Hi ZPAORUSKI. I suspect your switch problem has to do with the speed control assembly inside your mixer’s head, and yes you can order and replace it.
The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case: KG25H0 (use zero and not ‘O’), and select one of the last two files listed under Parts List (9) (check to ensure this matches your mixer model. KA made a -4 series and a -5 series with slightly different insides, so make sure you have the correct Parts List manual.) For a series -4 mixer, turn to pgs. 2 & 3, titled Case, Gearing And Planetary Unit that shows an exploded view for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. No. 8, Control Assembly. This is where I suspect your problem lies. (For a series -5 mixer, turn to Pgs 4 & 5, and locate Illus. No. 18, which is the speed control assembly).
First inspect around the controller assembly to ensure that all the wire connections are OK. It's possible a connection has come loose. Unfortunately the whole controller assembly is fabricated on a little PC board filled with resistors, capacitors and other electronic parts, which was not meant to be 'home fixed'. My 'expertise' ends at being able to recognize a resistor from a capacitor, but I don't get much deeper than that. A local small appliance repair shop should be able to determine if the controller assembly is functioning properly or not.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping.
Once apart you can check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your mixer yourself.
If you feel troubleshooting and repairing is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping. Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Posted on Dec 03, 2009
hslincoln
  • 235 Answers
SOURCE: How do I replace the Speed Control Knob on the K5 Kitchenaid Pro
Hi PETER, Happy New Year! Your Speed Control Knob can be replaced quite easily (OK, maybe with a little effort) by yourself, if you are a DITY type person, feel adventurous, and your mixer is not under warranty.
Before you start taking your mixer apart, be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Your speed control assembly is attached to the bottom of the top part of the mixer’s head (or Illus. No 1, Gearcase Motor Housing, on pgs 4 & 5).
Turn to pages 6 & 7, titled: “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixers electrical components, along with all the parts. Locate lllus. Nos. 1, 2, 3, 4 - Pivot screw, Spring Washer, Switch Lever and Stud, and Control plate spring, respectively, which is the speed control handle assembly and Illus No. 5 and 6 - Speed Link & Cam and Flat Spring. Carefully inspect these parts to see if they have not come loose, particularly the Pivot Screw and Spring Washer. Also check to see if the Speed Link & Cam hasn’t shifted from its position. You should be able to see if something just needs to be tightened or if parts need to be replaced.
Also, with your mixer apart you can check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your mixer yourself.
As far as parts go, here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. Prices can vary widely between vendors, so do your comparison shopping.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links may be different than your KA model, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
If you feel this repair is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good Luck. I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Posted on Jan 04, 2010
  • 110 Answers
SOURCE: Mine is a K5-A Hobart Kitchen Aid mixer and the
sounds like you need a new bowl lift cam, on the n-50 which is a hobart table-top model pull top off pedestle, you will see the cam you have to remove one cotter pin and remove one split pin install new cam reassemble
Posted on Jan 09, 2010
justinbur167
  • 257 Answers
SOURCE: Which is the better mixer of these old models: K5A
Hello ajlina,
All of these are great home use units, all the attachments are interchangeable between these. The difference between these mixers is the K5 is a 5 quart mixer and the K45 is a 4.5 quart mixer. As I own both of them they are great in the kitchen and have the same durability.
Have any more questions please post to this thread and I will be happy to assist. Thank you for using FixYa.
Posted on Mar 06, 2011
Kitchen aid mixer will turn on but not rotate
If the motor is turning and the planetary is stationary then the 3 most likely causes in order of most likely are; 1) Broken fuse gear; 2) broken planetary pin; 3) broken fuse gear pin.
Sep 28, 2017 | Food Mixers
My Kitchen aid Ksm90 mixer got a little noisy, then it just wouldn't even turn on. What could be wrong with it?
You have possibly blown the fuse gear. Need a bit more info on the noise. If you turn it on slow and help the planetary does it try go get itself going?
Jan 16, 2015 | KitchenAid Kitchen Aid Ultra Power Tilt...
Question: How do you put the string and spring wire clip back into the planetary assembly so that it won't interfere with the gears by coming loose?
I have repaired/reconditioned a number of K5-A mixers and have never encountered the parts you have described. They are not in the Service Manual. Try reassembling without those pieces.
Jul 24, 2014 | KitchenAid Food Mixers
Why does my kitchenaid k5-a get hot?
It is likely to be one of two things, Too much friction in one of the gear or motor bushes or a faulty motor armature. Put it on high and switch it off at the wall, if it seems to stop rather quickly then look for a binding bush. If it stops over several planetary revolutions then I'd be looking at the motor. A Kitchen Aid service person will easily be able to sort it out for you.
Apr 26, 2014 | KitchenAid 32685 Mixer
How do you get the planitary pin out of a kitchenaid mixer?
What model is your mixer? How old is your mixer? I hate this problem most of all and it is at the beginning of every mixer fix. in the worst situations I have had to drill it out and replace the planetary and center shaft, I have used a torch which is a good solution except that it trashes the finish, the easiest way is to use a drift punch that will go all the way through the center shaft and a non metallic hammer, turn the mixer on it's side on some towels, find something to put under the mixer to support it so that you do not break the locking handle or the speed switch handle. the n as straight as you can start tapping the pin. I have found some pins actually broken inside and took forever to get out, some bent from being driven in too hard, some have the ends banged out of shape creating a lip that will not drive through the shaft, i usually start with any punch that is smaller than the pin shaft opening to get started, then when the pin is driven in enough to get the drift punch in without hitting the out side finish of the planetary i drive the pin out and yet it may require a good tap especially if the pin is bent inside, try both ends before you try getting brutal with it. one end may go smoother than the other especially if a lip has been created on one end and not the other. I hope this helps. let us know.
Feb 21, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid groove pin removal
NO!!
If you cannot see the groove pin is not visible then you have one of two problems.
1 The last time the mixer was taken apart the groove pin was not put back in or not put back in correctly or all the way through the center shaft and out the other side and the pin has fallen out. I which case the planetary should be slipping, remove the trim ring and take two flat head screwdrivers and slip them between the planetary and the lower gear case and try to pry it off (Not too much pressure) because next problem;
2 The groove pin is broken off inside the center shaft, in which case you can still pry it off but with some serious problems potentially, you can break the planetary lip with the pressure of the screwdrivers or you could crack the lower gear case, either will require a part replacement order.
I have only seen one broken groove pin in years of repair and I could still get it out. It happened when someone tried to beat it in and it got bent and eventually broke. In my opinion if you cant see either end of the drive pin then there is no drive pin, try to pry the planetary off as you have seen in the internet videos. Let us know if this helped.
Jan 15, 2013 | KitchenAid 4159133 Mixer Groove Pin...
Where do I get a planetary assembly for a Kitchen Aid mixer? The model # is KP26M1XMR and the part # is 9708036
There is a dealer on eBay selling it right now (New). Search for
KitchenAid Stand Mixer Planetary Assembly White 9708172
May 01, 2011 | KitchenAid KP2671 Professional 6 Series...
Which is the better mixer of these old models: K5A K5-A or K45 SS and what is the difference? KITCHENAID HOBART K5A K5-A 300 WATT MIXER and the KitchenAid Hobart Vintage K45 250 WATT. Thank you
Hello ajlina,
Dec 09, 2010 | KitchenAid K45SS Classic Stand Mixer
Kitchen Aid Classic mixer
There are 2 possibilities, the attachments are worn out where they go on the shaft, simply replacing them could fix it, the other is the shaft is worn out inside the planetary ( where it spins), if it moves allot, 1/8 " or more from side to side, the housing is probably worn, and the planetary needs to be replaced, easy job, don't know cost, a new mixer may be in order.
Dec 26, 2008 | KitchenAid K45SS Classic Stand Mixer
Kitchen aide mixer
was the bowl snapped in to place.....push down on the back lip of the bowel until you hear it snap
Dec 30, 2007 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Food Mixers Logo
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
