Question about Frigidaire FGGF3032MW White 30" Freestanding Gas Range with 5 Sealed B
Need to lift cooktop to clean underneath
A mouse has gotten in underneath the burners/cooktop and I need to clean it out. How do I life the cooktop without damaging the gas burner assembly?
4 Suggested Answers
  • 409 Answers
SOURCE: smooth surface frigidaire electric cooktop
hi there,
you will need to replace the elements. it's quite common for them to stop functioning.
Posted on Sep 30, 2008
  • 1462 Answers
SOURCE: Element on ceramic Frigidaire Gallery cooktop won't go off.
take knob off and check the middle is not split and hence not turning the shaft
Posted on Nov 20, 2008
SOURCE: Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
We are having the same issues it sounds like as Larry is...
Posted on Jul 26, 2010
Replacing stove top ignitor
Remove the burner cap and lift the burner the igniter is fitted through the burner and held with a circlip underneath you will probably need to lift the top to access the wiring back to the igniter pack.
May 26, 2014 | DCS Cooktops
I have a very old Magic Chef gas cooktop. One of the burners lost full strength. I cleaned out the pinholes on the stem but this didn't help. Do you have any suggestions?
Have you had a spillover? Lift the burner cap the round thing on top of the burner then pull out the burner you might see a small hexagonal brass thing with a hole in the centre if it's blocked clean it with some acetone/ nail polish remover.
Apr 04, 2014 | Magic Chef CGC2430 Gas Cooktop
I have a 5 burner Dacor Cooktop (SGM365) with which I am having trouble with the right rear burner not sparking. There is gas flow and the other burners are lighting just fine. I've taken the burner apart...
In the middle of each burner, there is a small brass ring that screws in the burner. If you unscrew all five and pull the knobs, the top should come off. From there you can access the electronics. Because all the burners ignite at the same time, I would suspect either a disconnected or shorted wire on your right burner or some corrosion has occurred at that burner preventing it from grounding properly.
Nov 09, 2009 | Dacor Preference SGM365 Gas Cooktop
One burner won't ignite. The electode was
Most likely its dirty meaning the burners themselves and aren't getting any gas through. If you feel lucky you can do this without turning off or unplugging the stove, but on the oft chance there is a short I would do those just to be on the safe side. If you know how lift the top part of the stove up, you did not give model number. Find the electrode and clean with a clean toothbrush, plug in see if there is a sparks, actually look for the spark first. If you have a spark then your issue is the feed to your burners or the burners themselves being clogged. The feed is like a straw should there be an obstruction than nothing passes through. Clean the burners with a pin, blow through the gas inlets that go to the burners. After cleaning retry.
Oct 13, 2009 | Kenmore 36 in. 33384 / 33385 / 33389 Gas...
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
Right front burner on high all the time.
Yes, the entire unit must be lifted out - it is probably secured with screws underneath. Then you can remove the screws on the underside of the glass to access the switch. Hope this helps!
Dec 09, 2008 | Jenn-Air JED8430 Electric Cooktop
GE Profile Cooktop was just cleaned and the burners cont. to clic
you must have gotten water down the igniter switches.try drying out underneath the knobs. or leave unplugged till they dry.
Dec 05, 2008 | GE Cooktops
Clicking on one of the burners
sound like the spark switch got wet or has failed, if it has gotten wet from cleaned to stop the clicking unplug the ct of 24 to 48 hrs to allow time to dry out if that does not work call a appliance service company
Jun 03, 2008 | Jenn-Air 35 in. JGC9536 Gas Cooktop
Possible dead mouse inside?
need more info, make and model
Apr 14, 2008 | GE 30 in. JGP326 Gas Cooktop
Starter keep trying to start when cook top is off.
If you have recently cleaned unit and got moisture behind knobs, this may stop when the spark switches dry out. If not you will need to replace spark switches behind the knobs.
Nov 14, 2007 | GE 30 in. JGP337 Gas Cooktop
Frigidaire FGGF3032MW White 30" Freestanding Gas Range with 5 Sealed B Logo
26 people viewed this question
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
