Question about Avanti Refrigerators
Wine cooler does not stay cool
When turned on my Avanti Wine Chiller (WC1500DSS) cools down and the compressor shuts off when the temperature gets to the lower limit of the set temperature dead band. Then, as normal, the temperature slowly rises, but the compressor does not turn on when the temperature reaches the high limit of the dead band. The fan continues to run but the temperature rises back to room temperature. The compressor never turns back on. Any suggestions of what to fix? So far the following have been replaced without success - Main circuit board - Cabinet temp sensor, thermister (DG8-8) - Condenser fan motor
    Problem Solver:
  • 14 Answers
Do only if you are properly trained on live circuits.. Do at your own risk. Check the compressor's capacitor and the relay. Is the compressor getting juice?
Posted on Nov 23, 2013
5 Suggested Answers
drifterK
  • 4924 Answers
SOURCE: I have a Danby Silhouette
The device works like a refrigerator ..and there for the thermostat is to blame that it do not kick in the compressor once that the temperature exceeds the one that you preset ..So the action to do is to change the thermostat and will work fine ..
Posted on Dec 29, 2010
SOURCE: My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Posted on Feb 17, 2010
SOURCE: 3 year old VUAR141 cools but only gets down to 16C
Those symptoms you describe indicate a compressor that is "short cycling", if it is indeed starting and running for those 3 minutes. Is the evaporator cold for those three minutes as well? Many times people think its running, then shutting off, when in fact it is only trying to start. Without proper tools you cant test compressor, but it might be worth finding out from a repair service if its the compressor or the compressor starter, the latter of which is much much less expensive.
Assuming the other motors on the cabinet are running, you've narrowed your problem down to 2 things, the compressor itself, or the start device has failed. Without the proper tools you wont be able to test the compressor first. My advice, go to repair clinic . com, see what a starter will cost you, if you can find a repairman to check your compressor for cheaper than what it costs to buy starter, well there you go. Either way, if its the compressor thats bad, you wont want to spend the money to replace, unless you have a built in worth several thousand, or physical constraints of kitchen prevent you from buying new fridge.
Visit: www.FixMyFridge.net for Chicagoland Refrigerator Repair Service or read our FAQ and Tips.
Posted on Mar 22, 2010
  • 6 Answers
SOURCE: Avanti wine chiller model WC681BG not cooling after replacing cooling fan.
Unplug the fridge first.
Then try looking at the capacitor on the main board. If it is gooy or weird in any way - I'd try changing it.
John
Posted on Nov 25, 2012
Has anyone replaced a compressor relay on this chiller? Looks like it is not designed for replacement, but if it can be done with a generic relay I would like to know. Thanks.
The cost of one of those compressors is over $100. When you factor in tax and labor you're better off junking it. Its also possible you have a compressorless cooler called Peltier.
Jul 30, 2014 | Avanti WC1500DSS 30 Bottle Wine Chiller...
Not colling
Check the back to see if the compressor is running or just really hot. If it is not running it could be a thermostat issue, but if it is hot and not running, that means your compressor has problems and will need to be replaced.
Apr 07, 2014 | Whirlpool 22" Dual Zone 38 Bottle Wine...
My avanti wine chiller mod ewc 16 b serial n.0800854 stop cooling what can i do ?
I've added a link for an Avanti ewcb,
http://www.retrevo.com/support/Avanti-EWC16B-Refrigerators-manual/id/867bh235/t/2/. There you can find a complete manual on the product which will help you to locate where the problem is coming from. hope I've helped!
Oct 24, 2012 | Avanti EWC16B Thermoelectric Wine Cooler...
My Avanit WC54 wine cooler turns on, however it does not cool. Every few minutes it makes a clicking sound
if you are handy go to a refrigeration supply hoese and buy a 3-1 pack remove the wires from the compressor let it cool if hot and hook to 120 volts wiring it shows you on the package..........luck
Jun 16, 2011 | Avanti WC54 Wine Cooler
Nov 20, 2009 | Avanti WC3201D Wine Cooler
Our wine fridge doesnt seem to be cooling properly
it may be as simple as the coils needing cleaned you can buy a can of condeser cleaner at your local hardware store.
Oct 14, 2009 | Avanti WC681BG Wine Cooler
My Avanti wine cooler is not cooling any more.
piece of junk, can not be fixed. Join all the other ones who have bought this unit.
Aug 01, 2009 | Avanti WC3201D Wine Cooler
Oil appears to be leaking from my Avanti Wine Chiller
Is it cooling ok?Where did you find the oil? If is not cooling and you see an oil spot inside or outside where the compresor is that means there's a refrigerant leak.
May 01, 2009 | Avanti WC3200BG Wine Cooler
My cooler cannot cool
pull it out and lay hands on the compressor and see if its running if not replace the thermostat
May 27, 2008 | Avanti EWC28 Wine Cooler
Avanti EWC28 Wine Cooler TOO Cool
contact avanti cust svc they are easy to work with and want you happy tell them your promb but i suspect you need a new themostat
Dec 31, 2007 | Avanti EWC28 Wine Cooler
Refrigerators Logo
235 people viewed this question
Top Avanti Refrigerators Experts
John Tripp
John Tripp
john h
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
