Question about Frigidaire FGGF3032MW White 30" Freestanding Gas Range with 5 Sealed B
How do I lift cooktop?
A mouse has been getting in my gas range, under the cooktop. I can pry it up enough to see underneath with a flashlight, and can see droppings. I need to get the cooktop up to clean this out, but do not want to damage the gas burner assembly by doing it incorrectly. Can you tell me how to go about lifting the cooktop?
How do I clean under the electric elements on my basic westinghouse stove
Hello friend, thanks for your post!
I understand that you would like to clean under the cooktop on your Frigidaire range. Could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the storage drawer on the right hand side. With this information I can better assist you. -Matt
Sep 16, 2014 | Electrolux White Westinghouse Stove Range...
1 burner of 4 does not get enough gas to work properly
The burner probably hes plugged holes for the gas to get through.
You can clean them out with a tooth pick or paper clip.
Feb 17, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
How do I lift out built-in KitchenAid glass cooktop KECT 365 when mounting brackets wern't used
You are either:
A) missing the mounting screws and brackets that hold the unit in place
B) it is stuck and will require brute force to remove
C) both
Dec 30, 2013 | KitchenAid Cooktops
HOW DO i REMOVE THIS COOKTOP THAT IS ALREADY INSTALLED. wHAT TOOLS DO i NEED
For most cooktops no tools are needed they simply lift out... at the most there are a couple of clips underneath that need to be loosened with a screw driver...
heatman101
Aug 28, 2010 | Dacor 36 in. EG366SCHLP Gas Cooktop
All 5 ignitors constantly spark
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Feb 26, 2010 | GE 30 in. Profile JGP933 Gas Cooktop
No spark to ignite gas on cooktop
Shut off the stove. Then lift up the range top and you will see pilot lights. Remove the cover on the pilot lights. They could be blown out, but usually they are just dirty. Take a pin and poke it through the hole, then carefully scrub the tubes with a brush that go from the range to the pilot light. When your done with that....use a long match and light the pilot light, make sure no gas is on when you do this. No flames will come out, but it doesn't hurt to be extra careful.
This just happened to me so good timing!
Hope this helps
Sep 10, 2009 | GE Profile JGP636 Gas Cooktop
Stove top keeps turning off
if your breakers have become week they may trip with a lesser amp draw.sooooo if they trip right when you turn on a switch on the range, then it is a short in the range.if it trips after your using it abit its your breaker.hope it helps God bless ,tom
Jan 08, 2009 | Jenn-Air JED8230 Electric Cooktop
Burner cap
The cook top should be bolted to the counter. Look under and look for brackets that attach the bottom of the cooktop to the sides of the counter. and also the model number should be somewere underneath. If you can get me the Model number I can get you the maintenance manual in PDF format.
Eddie Rentas
Tupper Lake NY
Jul 24, 2008 | GE 30 in. JGP336 Gas Cooktop
Jenn-Air JGD8130 Gas Cooktop
grab hold of the installed burner cartridge at he top of unit and pry up slightly, should lift up without much effort, if not try lifting front side. they jsut lift up and slide back in no screws hold them in place
Feb 21, 2008 | Jenn-Air JGD8130 Gas Cooktop
Thermador wcggcv30 gas cooktop - how to remove glass top
Remove the brass ring nuts and the screw from each of the burners and pull off the knobs, then lift up the glass cooktop; no need to remove the three screws around the perimeter or even take out the box.
Nov 23, 2007 | Cooktops
Frigidaire FGGF3032MW White 30" Freestanding Gas Range with 5 Sealed B Logo
14 people viewed this question
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
