Question about Homelite Garden
How do I figure out which primer bulb for the homelite ut20706?
    Sergeant:
  • 340 Answers
Frank most primer bulbs are Universal. The top unscrews and the new one fits under the ring.
Posted on Nov 24, 2013
4 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: Where to find a replacement primer bulb for
Here is the part you need for your Walbro carburetor.
http://www.ereplacementparts.com/search_result.php?type=search-part&q=01201&manufacturer=Homelite
Posted on Oct 15, 2010
SOURCE: broken primer bulb
home depot has a fuel system rebuild kit that includes bulb, filter, hoses all for less than 7 bucks.
Posted on May 06, 2010
goldenglove1
  • 144 Answers
SOURCE: Replace a primer bulb on a Homelite Mighty Lite
There should be two to four screws right around the primer bulb cover, which is located around the primer bulb. Remove those and switch the primer bulb out.
Posted on Aug 12, 2010
Why won't primer bulb fill on homelite 26cs weadeater?
a primer bulb should not actually fill, that said, if it is not priming your carb then there might be a tiny crack or pin hole that is letting air in as you try to prime, order and change the primer bulb.
Oct 16, 2016 | Homelite Garden
How do i remove the primer bulb on my homelite mighty lite 26cc blower
The primer bulb should be attached directly to the carburetor. There will be a plate with 4 screws, once on each corner, which you will have to remove to get the primer bulb off of the carburetor. You can find replacement primer bulbs at PartsBuggy.com.
Sep 29, 2011 | Homelite Mighty Lite Lawn Trimmer
My Homelite Mighty Lite 26b Leaf blower has a punctured primer bulb. Homelite doesn't list the part number. Model number UT08520A Can you help? Thanks, Ed Mckinney,Tx
Homelite wants to sell you a new carburetor assembly. Your blower came equipped with a RuiXing brand carb. RuiXing does not offer any repair parts for their carbs, only replacement units.
Now for the good news....a Zama brand primer bulb fits perfectly on the RuiXing carbs. Check with your local small engine repair shop for a Zama primer bulb. The blower requires removal af the carb to get at both of the screws that hold on the bulb. It is not difficult, just one nut holds on the outer airbox cover...don't lose the little washers. Then one long stud and one short screw will take the carb off. Replace the primer bulb and reinstall everything the same way it came off.
Dec 21, 2010 | Homelite Garden
Replace a primer bulb on a Homelite Mighty Lite 26cc trimmer
Aug 12, 2010 | Homelite Mighty Lite Lawn Trimmer
Is the primer bulb suppose to have gas in it this is a homelite
Here's a sketch that might help you. The primer bulb will keep fuel in it. 3985d0d.jpg
May 01, 2010 | Homelite Mighty Lite Lawn Trimmer
Primer bulb is part of the fuel cap.
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can
I find a replacement primer bulb fuel cap?
Jun 24, 2009 | Garden
I have a homelitejacobsen 320 snowblower i replaced the primer bulb with one that has a single line running to it after it starts gas starts squrting out of the hole on the primer bulb how do i stop this
You need a "wet" primer bulb for the Jacobsen / Homelite snowblowers. A wet primer actually pumps gas - not air - a primer bulb with a hole in it was designed to pump air.
If you need a "wet" primer bulb email me and I will tell you where to get one for around $10 - basscatt at hotmail dot com
Feb 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
