Question about Garden
Ut20706 homelite fuel assembly
Homelite ut 20706 primer bulb how do I determine which one to get. can't find the part number on any of the parts diagrams????
  • 115 Answers
SOURCE: primer pump rotten need replacement show parts page
The hoses run through a hole into the gas tank, they are fitted with a filter inside the tank. Drain the tank, and manipulate the hose end to where you can grab it throught he filler hole, Remove the filter, run new gas lines into the tank and through the filler hole to replace the filter, reattach to the carburator. The primer bulb should have 4 small screws attaching it to the carburator. Remove the screws, place in new primer bulb, and you should be back to trimming asap.
Posted on Jul 06, 2009
canbruce75
  • 1776 Answers
SOURCE: Any ideas of where i can get/order a Homelite
I was able to get one at Ace Hardware. Take the bulb with you wherever you go looking for one so that you can match it up. Hope this helped.
Posted on Jul 18, 2009
  • 3600 Answers
SOURCE: the primer bulb does not draw fuel thru carb
you need to buy a primer bulb kit and replace it cost about $8.00 and is easy to put in, the check valve is damaged.
  • 6 Answers
SOURCE: looking for a primer pump for Homelite htc12 tiller
Hi, I live in cedar rapids, Iowa. I just bought a primer bulb for my htc-12 homelite tiller. You should be able to order as many as you need, but I don't have the part #. Find out what the part # is and call this # 1-319-393-0443. They have 2 sizes, the bigger one is for the chain saws, the small one is for the tiller.( they have both) Carefully pry the plastic band off the primer bulb, press the new bulb through the band, then go get a tube of permetex weather strip adhesive ( orange box, black adhesive). Don't buy any other brand!. Lay a thin bead around the base of the bottom of the ring, press into place and let dry for a couple of hours. This adhesive works on almost any thing, and is not affected by gas, oil, or anything.
Posted on Mar 31, 2010
SOURCE: broken primer bulb
home depot has a fuel system rebuild kit that includes bulb, filter, hoses all for less than 7 bucks.
Posted on May 06, 2010
Homelite UT-08544 fuel line which one goes to bulb which one goes to carb
I wish those posting answers could get things right.
The remote primer does not push fuel into the carburetor; it for pulling fuel mix through carburetor removing air line the system.
Here is the basic setup for a remote primer.
Apr 02, 2015 | Homelite Garden
NEED PART # FOR PRIMER BULB ON HOMELITE BP30185
Thanks for providing the UT number.
When cross reference the carburetor part of up00651 it came as as Zama C1U-H36 which has a Zama 0057003 which is superceded to Zama 0057030
Mar 18, 2015 | Homelite Backpack Leaf Blower
How do the fuel lines rout on a homelite 45 including from tank, primer bubble to the carbeurator
Without the UT number from the saw won't be able to give more detail carburetor hookup. Here is a generalize fuel hook-up diagram.
Depending on the carburetor both of the fuel lines can be on one side only. The suction line connection for the primer is usually closest the the metering diaphragm.25331542-pzxv2dmyt02yqunciumgycfv-5-0.png
Dec 21, 2014 | Homelite Garden
How do I figure out which primer bulb for the homelite ut20706?
Frank most primer bulbs are Universal. The top unscrews and the new one fits under the ring.
Nov 23, 2013 | Homelite Garden
Homelite ut-08068-r leaf blower leaking fuel
If we are talking about a hand held leaf blower. The fuel leaking from the carb is likely caused by a stiff metering diaghram holding the needle open. Rebuild your carb ( I suggest also replacing the fuel lines and primer bulb while you are at it) and double check the lever adjustment.
Oct 23, 2012 | Homelite Garden
My Homelite Mighty Lite 26b Leaf blower has a punctured primer bulb. Homelite doesn't list the part number. Model number UT08520A Can you help? Thanks, Ed Mckinney,Tx
Homelite wants to sell you a new carburetor assembly. Your blower came equipped with a RuiXing brand carb. RuiXing does not offer any repair parts for their carbs, only replacement units.
Now for the good news....a Zama brand primer bulb fits perfectly on the RuiXing carbs. Check with your local small engine repair shop for a Zama primer bulb. The blower requires removal af the carb to get at both of the screws that hold on the bulb. It is not difficult, just one nut holds on the outer airbox cover...don't lose the little washers. Then one long stud and one short screw will take the carb off. Replace the primer bulb and reinstall everything the same way it came off.
Dec 21, 2010 | Homelite Garden
Bgreen. Need correct part no. for primer bulb for sx135 bandit string trimmer. old one has cracked due to age.
Your SX-135 string trimmer was built by Homeliteand has a model number of UT-20601. That said, your trimmer's primer bulb part number depends on teh type of carburetor it has. If your trimmer has a Walbro carburetor, the primer bulb part no. is 01201. If it has a Zama carburetor (the most likely one) the primer bulb part no. is A01195A.
You can go to the following website to order the part: http://www.homelite.com/service_support/order_parts
Good Luck, hope this helps!
Oct 15, 2009 | Garden
Primer bulb is part of the fuel cap.
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can
I find a replacement primer bulb fuel cap?
Jun 24, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
