Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
Drum flopping around and making clunking noise
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
Almost certainty that the bearings are faulty, major problem usually no worth repair fault is caused by overloading the machine
Posted on Jan 02, 2015
2 Suggested Answers
  • 12 Answers
SOURCE: washer drum feels like its
HOUSING CONNECTED TO DRUM IS CRACKED. MADE OF WHITE METAL, CANNOT BE REPAIRED.
Posted on Jul 26, 2010
The car make a clunking sound when breaking and occasionaly when turning and just recently the key got stuck in the igntion
motor mount or mounts getting old and loose will cause clunks as the engine flops around in the vehicle. there is a recall on the ignition mechanism that a dealership may fix for you for cheap.
Mar 14, 2015 | 2008 Saturn VUE
Clunking banging noise
It may be something stuck in the drum, ie a bra wire, which would have extra weight on it whilst the clothes are wet. If this is the case, it will need looking at sooner, rather than later, as it will just be causing further internal damage
Dec 19, 2013 | Fisher and Paykel Dryers
I have an LG gas dryer it has black sticky pads stuck to the drum. one of them came loose and was flopping around inside the dryer and even went around the idler pulley. I can remove the material from the...
It just help the drum does not make noise if it touches to the cover when the drum has heavy load. You can clean it up and forget about it.
Sep 04, 2013 | LG Dryers
Rear drum brakes making clunking sound when braking
Recheck your work
Did you install new springs?
Flush/Bleed the System?
Turn the Drums?
New Wheel Cylinders?
Jan 06, 2013 | 2002 Chevrolet Cavalier
My frigidaire gltr1670a washer is making a banging noise when on the spin cycle. I took the bottom cover off and watched the drum it doesn't seem to be from the outside of the drum cover it sounds like its...
It sounds like the spider arm supports in your washer has failed. The spider arms hold the stainless steel wash drum to the axle. You need to stop using the machine immediately since the wash drum is flopping around the plastic tub. It is an expensive fix. The replacement drum/spider can cost over $300 with shipping. Get a few estimates before deciding whether to repair or replace. Sorry.
Dec 09, 2010 | Frigidaire GLTR1670A Front Load Washer
The compressor makes a big clunk clunk sound when it shuts off
The compressor motor mount is broken and that allows the compressor to flop around and clunk when shutting down.
That also allows it to twist and turn as it starts...
this will have to be fixed before the refrigerant piping breaks...
heatman101
Oct 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Makes clunking noise when changing modes--does not spin dry
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Clunking noise
The clunking noise may be a broken weld on the drum.  Every time it turns and passes through the guide wheel supports, it makes a thunk thunk noise.  You will need to have a qualified LG technician diagnose the problem correctly but that's what it sounds like.
Jun 07, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
