Question about Magnavox DP100MW8B Player
Remote standby on button wont work - Magnavox DP100MW8B Player
  • 37 Answers
Had this problem [with a similar unit] some time ago. It was just OLD and worn out. I picked up a brand new [identical] one on EBay from CHINA for very little outlay.
OR you may find someone in your local shopping center/mall who fixes mobile phones etc.
These guys can quite often fix the problem for you or change the keypad ... ok
Posted on Nov 24, 2013
Testimonial: "thanks"
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
My sony kdl-46v3000 standby light blinks 5 times tv wont turn on
The TV enters standby mode when there is no signal for 30 seconds. https://docs.sony.com/release/KDL46V3000.pdf
I searched standby using Ctrl+F and found this information. It seems you should be able to bring it out of standby using the power button on the remote. You want to make sure there is an input connected and if it is connected to a PC that the PC isn't telling the TV to go into standby.
Try pressing the input button and changing inputs once you press the power button and the Standby is flashing.
If this doesn't work you may need to contact Sony Support.
1-800-222-SONY(7669)
Apr 10, 2014 | Sony Bravia V-Series KDL-46V 46 in. LCD...
Denon AVR-3200 wont go into standby mode
Not sure what you mean by standby mode. The power button on most of the audio remotes I deal with merely turns the equipment on and off.
Nov 24, 2013 | Denon AVR-3200 Receiver
Wont go on standby
Possible that the processor section needs to be checked. When the remote is clicked to standby and if there is no response even if the remote is working perfectly with other modes then the power - off button and IR trigger from the remote must be checked to work. Use a mobile camera to see if the remote is emitting IR with the power off button pressed.If so the processor section and the standby out must be traced.
Jan 20, 2012 | Televison & Video
Bose 321 series wont play region 1 dvd
To convert Bose 3-2-1 GS Series 2 DVD system to Multi-Region playback
1. Press the Right button on your remote control
2. Press the Up button on your remote control
3. Press the Shuffle button on your remote control
4. Press the Stop button on your remote control
5. Press the Mute button on your remote control
6. The disc tray should eject twice to confirm the region change
7. Press the Standby button on your remote control to power off your machine
8. After one minute, press the Standby button on your remote control to power on.
Done!
Nov 29, 2010 | Bose 3 2 1 GS Series II DVD Home...
I have a toshiba tv with a broken power button
Generally the power button has to be on first to put the TV in standby mode. If you cant do this no remote can ever work. Remotes are not capable of turning on a set that has no power mechanically turned off. and that is what the master switch does. once that standby light is off it is not live and consuming power and not under the control of a remote anymore
please rate our help++++Y=Thanks for using FIXYA
Sep 25, 2009 | Sharp 27N-S100 27" TV
Hi, i have 2 televisions different makes both turn on to standby but wont turn on fully, the bush tv when i push programme button to turn on the red standby button flashes but nothing else.
I have the same problem, my Bush LCD worked fine last night but won't turn on today. The main power button on the TV puts it onto standby but the remote or the buttons on the side won't turn it on!....HELP!
Sep 06, 2009 | Televison & Video
Unlocking my DVD Player
Try this,it should work....Rod
To change the current region setting on this player
1. Press the Standby button on your remote control to place the unit into Standby
2. Press the Standby button on your remote control to turn on the unit
3. Press the Open/Close button on your remote control to open the drive tray
4. Press the Clear button on your remote control
5. Press the 1 button on your remote control
6. Press the 3 button on your remote control
7. Press the 6 button on your remote control
8. Press the 9 button on your remote control
9. Press the 0 button on your remote control
10. Press the Open/Close button on your remote control to close the drive tray
11. Press the Standby button on your remote control to place the unit into Standby
12. Press the Standby button on your remote control to turn on the unit
Jul 16, 2008 | Durabrand Televison & Video
Magnavox DP100MW8B Player Logo
44 people viewed this question
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
