Question about Jl Audio 500/1 Car Audio Amplifier
Orion amp beats hard for while, then it starts to cut in an out
    Problem Solver:
  • 19 Answers
It sounds like heat. If your running it at 2 ohms or 1 ohm it's going to run hot. You location is critical. If it's under a seat it may be above you catalytic converter and it will be too hot. In the past I have run a small fan that was used in boats that's compact and runs at 12 volts and in one case I used a fan similar to a computer hard drive fan that I found at radio shack that was 12 volts. Also your alternator will become taxed as more heat is developed during driving. Heat lowers the out put amperage of any alternator and will start to cause the amp to cut out. I also use at least a 10 gauge or larger power supply wire for the amp that's fused no more than 8 inches from the battery. The ground should be just as large and the ground point clean. I always use dialectric greas on all connectins to prevent corrsion.
Posted on Dec 03, 2013
What cause my 15 speaker go off when the beat kick in but the amp still on n make noise out da speaker
Sounds like it's overloading you may have a sub to small for your amp cut all the settings on your amp back to minimum wind them up until sub cuts out then drop them back a bit .
Aug 01, 2014 | Car Audio & Video
I have a d5000 amp and its wired up to a 15.2 hcca orion sub when i turn it up high volume,it cuts out anyone know why
make sure you have the frequency cuts right. if ur giving the sub anything lower then 30hz (assuming ur using 15's) the amp will cut out to protect the woofers from overload
Nov 18, 2009 | Orion HCCA-D5000 Car Audio Amplifier
My Orion d-5000 amp which is wired to an Orion hcca 12.2 sub cuts out at high volumes , it's wired with 0 guage wires
Your speaker is a dual 2ohm sub. If you have both voice coils wired Parallel that will drop the ohm load to 1, which the amp can not handle. You need to wire the voice coils in series. Treat each voice coil as a speaker.
Jun 30, 2009 | Orion HCCA-D5000 Car Audio Amplifier
My amp keep on cutting off
wha amp do you have? and when it cuts off? did ou try to find a different ground make sure it is a good ground anx make sure your widt of the mains can handle the amperage of the amplifier
Apr 04, 2009 | Orion 1200D Car Audio Amplifier
Amp gain problems
amp gain controll need to be changed
Jan 18, 2009 | Car Audio & Video
Amp gain problems!!!
is more than likely a loose connection
Jan 18, 2009 | Earthquake Sound PH-D2 Car Audio Amplifier
Orion 2100 hcca
I have a few photos of the 2100hcca. Where are the burned resistors on the board?
Nov 05, 2007 | Orion 2500D Car Audio Amplifier
Car amp's stopped working. Putting out a heart beat sound through subs but no bass.
could be low current ,disconnect all power including ground for 20min N.B most amps will seem to be shorted at output but this is normal due to damping ratio.
Jun 11, 2007 | Jl Audio E1200 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
22 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
