Question about Logitech Cordless Mouse
Lable the mouse - Logitech Cordless Mouse
How do I align my Citizen CLP 7202e Lable printer print head to align with the lables? Currently it starts printing low on the lable and thus the last 1-2 lines print over onto the next lable
Adjust vertical offset in printer properties. If that doesn't fix it, adjust it under "advanced". Or... you can set the offset in the printer itself. Hold down the left two buttons at the same time. Cycle through the settings until you get to vertical offset.
Apr 19, 2015 | Citizen CLP-7202e Thermal Printer
Can't remember where the wires go on the motherboard Dell ry206 can anyone help please?
what wires are you referencing?
this is a SATA MOBO with 24 pin power and 4 pin CPU. the wires to front of case are labeled on wire end and MOBO Blue sata is usually primary to Hard drive but should be labled 1,2,3,4. wires in back are USB Keyboar & mouse, lan and speaker
Why are the wires off?
Jul 13, 2010 | Dell Computers & Internet
Cannot invoke hotkey function to switch computers .Directions say use num loc key plus minus key and release num loc but this doesnt work.
Make sure your keyboard and mouse are plugged into the correct usb slots on the switch. One is labled for keyboard, and the other for mouse. If you mix these up, those hotkeys will not work! :) Also, a much better hotkey for this switch is to tap scroll-lock twice. This automatically switches, so you don't have to hit multiple buttons.
Feb 18, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
Can't switch
Make sure your keyboard and mouse are plugged into the correct usb slots on the switch. One is labled for keyboard, and the other for mouse. If you mix these up, those hotkeys will not work! :) Also, try tapping scroll-lock twice to switch. It's much better than trying to use the num-lock + and - keys, since it's only a two-way KVM. Tapping Num-lock twice automatically switches, so you don't have to hit multiple buttons.
Oct 24, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
My touchpad works to scroll but not when tapping
Under the start menu click on control panel, then double click on the mouse icon, then click on the top box labled tapping, then click on the little box on top left, get a check mark, then ckick apply and ok.
Sep 10, 2009 | Acer Aspire 5610-4648 Notebook
Connection procedure for Toshiba N745 mouse needed.
I don't know if this is the same as my mouse. However I have a satellite1955-S803 with wireless detachable keyboard and full sized optical wireless mouse. The original owner said it came with the laptop.
First I tried very hard to get the keyboard working. After a frustrating day of calling Toshiba, I noticed the "detachable" latches. I removed the keyboard to find a battery compartment. 4 days go by with me calling Toshiba trying to get a replacement. Finally found a battery at batteries plus that does work. about half the mAhr of the original but hey it works.
Now to the mouse. Replaced the AA's batteries but couldn't tie the mouse to the computer. I run linux so no M$ driver would help. Finally found a PDF of the manual and it says "if the mouse has trouble activating, press the wireless mouse button on the laptop."
That button is on the front left edge of the laptop (where the "Intel inside", "XP loaded", and "nvidia" stickers are located ) just to the left of the front silver "mode" button. Under the mouse press the connect button. (round near the optic laser but un-labled) then press the wireless mouse button on the computer and there you go. It just connects and works.
2 weeks I looked for this and it was just that simple.
Aug 26, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
My hp compaq nx9010 notebook is no longer displaying the color black on the Windows xp start up page or on some of my powerpoints and videos. The color black is replaced by a redish color.
It seems that someone changed the desktop background color. point the mouse somewhere in the middle of the desktop, (away from any icons) and right click the mouse, a menu will appear with several options. The bottom one says properties. Click that. Once done another (more advanced) menu will appear with several tabs at the top. Click on the second to last tab, labled, "Appearance". Once in this tab. Toward the bottom right side of this screen you will see 2 buttons one atop another labled, "Effects", (on top), and, "Advanced", (below). Click the advanced button. A new window will pop up with the first option being desktop in a drop-down menu. To it's immediate right you will see "color 1" with a drop-down menu directly below it. That is where you will select the new background, (desktop) color. Once you have selected the new color, click OK, then apply on the remaining screen, then OK once the color is set.
Apr 16, 2009 | HP Compaq nx9010
How to use mouse
I just played around with it and finally found out how to get to the batteries, which did, indeed need replacing. To get to the batteries I had to take the top off, which is not what we usually do.
May 08, 2008 | GE Wireless Optical Mouse
Flash Drive
Open up "my computer" on your pc. Find your downloads from your Zune playlist and right click with the mouse on that folder. It will give you the option to move this folder. Move this folder to the drive labled "removable disk". This should work. Let me know if it does not work.
Cynthia Charczenko
Dec 19, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
Logitech Cordless Mouse Logo
43 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
