Question about Samsung RS2530BBP (25 cu ft) Side by Side Refrigerator
Rs2530bbp control panel - Samsung RS2530BBP (25 cu ft) Side by Side Refrigerator
Freezer temp
adjust the control that say more air to freezer .
Jul 13, 2014 | Samsung RS2530BBP (25 cu ft) Side by Side...
Where is control board?
hi there .well most samsungs the main control pcb is at the rear end right hand side.behind cover.hope this helps.Ali
Aug 23, 2012 | Samsung RS2530BBP (25 cu ft) Side by Side...
How do you turn off the ice maker?
Hi Juanita, I can help you with you ice maker problem.
Page 6 of the manual says to: Press the "Ice Type" button on the control panel to cycle between "Cubed Ice", "Crushed Ice" and "Off". You can call Samsung toll free at: 800-SAMSUNG if you have any problems.
I hope this helps and good luck!
Mar 05, 2012 | Samsung RS2530BBP (25 cu ft) Side by Side...
We have a Samsung RS2530BBP. The ice maker works ok... water stop coming out... What do I need to do to fix the problem?
My Samsung RS 2530BBP frige Ice maker stop tp make ice.
The water tray stays verticly after pushing the reset button and the water pours in the container instead in the tray. I purchased a new ice maker but it did the same. Any idea how to fix it
Aug 12, 2010 | Samsung RS2530BBP (25 cu ft) Side by Side...
Noise coming from the back of my Samsung RS2530bbp refrigerator, fan like noise
if it is a squeeking noise it could be that the bearing on the fan motor is going out, if it is a tapping noise or a fluttering or maybe even a thuding the fan blade is hitting something like papper,mouse,insulation that was taped to the fridge for either sound barrier or temp. control.You will need to pull refrigerator out and use 1/4 or 5/16 nut driver and pull back cover off to determine the cause, be sure to er-install cover for if you do not it will not keep compressor cool there fore temp. in fridg. will not be consistant.
Aug 05, 2010 | Samsung RS2530BBP (25 cu ft) Side by Side...
Freeze works fine but ref side won't get cold samsung rs2530bbp anybody know what to do?
Remove the rear panel of the freezer, and also remove the vent in the fridge side. There is likely ice build-up in between the two that has to be thawed or scraped out so the air can flow.
Jul 25, 2010 | Samsung RS2530BBP (25 cu ft) Side by Side...
Samsung rs2530bbp... Not cooling... Compressor
my frigerator RS2530BSH has the EXACT same problem! can anyone help??
Jan 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
Samsung RS2530BBP (25 cu ft) Side by Side Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
