Question about HEWLETT-PACKARD ProBook 6550b XA673AW Notebook
How to enable mouse pad on hp 655? - HEWLETT-PACKARD ProBook 6550b XA673AW Notebook
I need to turn off the mouse pad on my hp probook 4525s, do I need to install any special softwer or what to do?
you do not need to install any special software.
Here is what you have to do to turn off the mouse pad of your hp probook 4525s;
Turn on your hp probook 4525s, wait till it boots completely.
Click start,
Scroll to Control Panel select Control Panel.
Under control panel, (you will find a Mouse icon), click Mouse and a dialogue box will pop out.
On the dialogue box, click "Device settings".
Under device settings, you will find "Synaptics Touchpad..."
Highlight the "Synaptics Touchpad..." by clicking on it once, then click disable.
By now the mouse pad should be disabled. Apply the changes for it to take affect.
To enable follow the same procedure and click enable using an external USB mouse.
Yours sincerely.
Elect_Comp.
May 23, 2011 | HEWLETT-PACKARD HP 4525s ProBook
Orange light on mouse pad came on preventing use
Hi.
Press the button above the touchpad where the amber light is, when it turns blue the touchpad will be enabled.
Regards.
May 01, 2011 | HP Pavilion dv9000z Notebook
When my new hp mouse pad locks, how do i unlock it without restarting the computer?
There should be a button above the pad or work your way using the keybord to mouse properties and go to the page that has the name of your track pad and select enable.
Mar 01, 2011 | HP Pavilion dv7-1020us Notebook
Orange light comes on occassionally on mouse pad and cursor freezes, how do i stop this
Tap the orange light quickly two times to enable the touchpad. Touch the same spot twice to disable the touchpad. To see the instructions from HP type "mouse" into the Search Programs and Files. Click on "Change mouse settings" and click Device Settings. Click on "Settings" and click "Touch pad disable zone". I was delighted to have found this as I had been restarting the computer manually to enable the touchpad. Shame on HP. The instructions for this simple problem are difficult to locate for the average user. They can do better.
Dec 08, 2010 | HP Compaq Presario F730US Notebook
Scroll pad not working on hp laptop mouse still works though
Need to enable Scroll function on the notebook.
Scrolling function is not working:
  1. The scroll function may stop working if the scrolling feature is disabled in Mouse Properties. To enable the scroll function, follow the steps below.
  1. Click Start , Control Panel . Select Classic View from the left side of the Control Panel window.
  1. Double-click Mouse in Control Panel, and then select the Device Settings tab in the Mouse Properties window.
  1. Click Settings , Virtual Scrolling . Select the boxes labeled Enable vertical scrolling and Enable horizontal scrolling .
  1. Click OK to save and exit the Mouse Properties window.
  1. After changing these settings, the scroll function on the touchpad will be enabled.
Jul 24, 2010 | HP Pavilion dv5000t Notebook
I am using my phone to ask this question.
the touch pad is usually controlled by synaptic.
To turn it on back, press start menu from your key board and scroll to control panel.
From control panel, use the tab button to select the icons on control panel and go to mouse.
From mouse, use your keyboard to control to device settings.
From device settings, you would see synaptics touch pad, then press enable and that's all.
You touch pad would then be enabled again.
All the best.
Jan 05, 2010 | HP Compaq Presario 2200 Notebook
Enabling mouse pad tapping
Dear,
You will have to install SYNAPTIC Drivers/Software to enable tapping and other features. Just log onto your manufacturers website and search for your model in support, and download SYNAPTIC driver file.
Good Luck
Nov 02, 2008 | HP Compaq nx5000 Notebook
HEWLETT-PACKARD ProBook 6550b XA673AW Notebook Logo
29 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
