Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washing machine
On and not responding to any fix or reset. Problem occurred when water was shut off while system was on and running.
    Sniper:
  • 97 Answers
Have you tried unplugging it, waiting 30 seconds, then plugging it back in to see if it will reset itself? Best of luck
Posted on Nov 23, 2013
SOURCE: The duet washing machine fills up with water in between loads. What is Causing This?
Dont want to endorse a commercial site, but you can by a generic part for a bit over $10 for this problem, so do some seraching for a reasonable site (other sites are charging 40-50 dollars for a fill valve.
Posted on Aug 09, 2007
  • 56 Answers
SOURCE: I have a whirlpool duet sport front load washer. It was running in the wash cycle. I had to cancel the cycle. Now the machine will power on, but when I put the start button it turns itself off. I've t
make sure you havent locked the console by accident it is in small print on the front right of the console other than that you will probably need a technician
Posted on May 30, 2009
  • 212 Answers
SOURCE: whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Posted on Jun 22, 2009
57 varieties
  • 1653 Answers
SOURCE: My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Posted on Oct 02, 2009
rickead1
  • 1998 Answers
SOURCE: My Whirlpool Duet Front Load Washing Machine is
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has concluded Thanks again Rick
  • Posted on Jan 16, 2011
    Ho do I reset the whirlpool error codes f6
    F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
    Potential Causes
    • Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
    • Check the Drive Motor
    • Check the MCU
    • Check the Wire Harness
    Replace failed component.
    Whirlpool Duet error f6 Google Search
    Sep 06, 2014 | Whirlpool Duet WFW9151YW 27" Front-Load...
    My whirlpool front load keeps cycling without the water filling.
    If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
    Washing Machine Problems No Water
    Washing Machine Fix Washing Machine No Water
    heatman101
    Apr 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    My Whirlpool duet washing machine is collecting water in the tub after laundry is long done
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
    Kind of the opposite of these tips... your fill solenoid has dirt in it and it won't shut off...
    If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
    heatman101
    Sep 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    My whirlpool duet washer's cold water valve is stuck, causing flooding. How do I fix it? And is it considered a washer problem or water problem?
    Yes, usually this problem IS caused by heavily mineralized water and sediment from your water supply, it onlys takes a small amount to jam the solenoid. It is more than likely that the only way that you can solve this problem is by replacing the water valve. Since your washer calls for water at different times it would be impossible to shut the water off, once full, AND still have a normal wash cycle. Depending on how badly it has flooded the area, there may be more damage than just the water inlet valve. I would contact a technician to ensure no further damage has occured. Hope this helps .
    Thanks
    Dec 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
    Whirlpool duet front load washer has standing water inside
    Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet HT GWH9300P Suds then F2
    Clean the pump and hoses......if that does not help need new pump
    May 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool duet washer leaking water into the drum when not used
    water leakin in tho the drum is sign of a faulty water inlet valve, not shutting off water supply to machine, it continues to trickle in , in beween washes. you can turn off the water supply between washes see if this helps, and if it does then youll know its the water valve
    Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    220 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
