Question about Hammering
Hitachi pr38e spills oil from the hexagonal hole of cover front
2 Suggested Answers
jeepguyracin
  • 2443 Answers
SOURCE: TIPO DE ACEITE QUE utiliza El Roto Martillo Hitachi Pr38e
Do you know how to do English ??
Posted on Jun 04, 2017
I am trying to change my gear box oil and I can't find where to put the new oil into
There is a hole on the side of the gearbox that generally has a large hexagonal socket hole in it. You remove that fill plug and fill it until it starts to dribble out of the hole.
Google
year make model change gearbox oil
and look at the video tab.
2015 honda civic gearbox oil change Google Search
Oct 07, 2017 | Cars & Trucks
How do you check the front differential oil?
Usually you will find a ***** plug with a large hexagonal head. There is one at the top for filling, and one at the side for checking level. Sometimes there is only one in the side. Gear oil for diffs comes in a bottle with a tube spout. You put in in the hole and squeeze the bottle until the oil starts to dribble out. Replace the plug and you are done.
Apr 08, 2016 | 2002 Infiniti QX4
Remove the engine cover on a 2008 holden captiva?
not sure if you have answer to your oil filter. Diesel looking from front of vehicle left corner rear of engine , cover removed. 27 mm socket required . care taken awkward to remove oil will spill grab it with a piece of rag moving it down and under filter as it is removed. advise to suck out oil from lower filter body before refitting filter or oil will rise as filter is fitted and will spill over . Please also be aware which groove you remove the old oil ring from so as to fit a new o ring into the correct groove.
Dec 14, 2014 | Holden Cars & Trucks
We have oil in the spark plug wells
Most likely you have a leaking valve cover gasket. There is a gasket the goes around the valve cover, and also a gasket where the cover mates to the head for the spark plug holes.
Mar 16, 2010 | 2003 Mitsubishi Galant
Where is the manual gearbox oil filler plug on 2006 Hyundai Accent MC
hi from uk if memory serves ?the g/box oil level/filler plug is-- as you open the hood/bonnet in uk then look down at the gearbox on the front side behind radiator the filler plug is half way down in the center of g/box the filler is a hexagonal heade nut and the size of wrench needed is 17 or 19 mm ?? the level is correct if when you remove plug the oil is at the lower end of hole hope this helps ?
Mar 04, 2010 | 2006 Hyundai Accent
I have a Hitachi projection color tv and I cannot get the color adjusted good especially the red. Can you help me?
U know how to solders?Ur convergence it dead,need it replaced parts,by buy convergence kit.Tries Tv repair World.com,Tvrepairkits.com.
Dec 20, 2009 | Hitachi 43UWX10B 43" Rear Projection...
How do I install/adjust color lamps on a Hitachi 51UWX20B rear projection tv
Read Each Step Completely - Make Sure 3 Color Guns Are Off And Cool -
1. Remove Rear Dust Cover 2. Remove the Front Speaker Cover May be Held In By Plastic Pins and or Anchors on the Bottom Note" - Remove The Plastic Cover Just Above Speaker Cover Maybe 2 Piece. Remove The Screws Holding Top Of Speaker Cover. Then Pull Toward You the Bottom Maybe Anchored So Lift Up. 4.Once Speaker Cover Removed, May Have Screws Just Below Center Plastic Cover Remove Them, Now Remove Center Cover Between Speakers -NOTE" Do Not Touch, Move Any Color Convergence KNOBS" - Lift Front Screen UP - Towards Roof - It Has 3 Flex Grab Anchors On Top And 2 Pins One On Each Side Of TV Frame. - NOTE" Lay Screen On Floor It Is Plexi Glass So It Will Brake If Bent Or Drop Hammer On. NOTE"- May Have To Remove plastic Cover Frame positioned Around Front Screen And Then Remove Screws. 5. I Use Windex Glass Cleaner And Either Cotton Balls Or White Tube Sock On Color Gun Lens Covers And Clean Mirror Like The One In Bath Room. 6. Take White Sheet Or Bead Spread And Anchor On top Of TV With Weights, Stretch Around Each Side Of TV Use Chairs To Anchor On Each Side Of TV. Place Dust Cover Or Heavy Card Board Where Plexi Glass Was Positioned. 7. Turn On TV - go To Rear and Now You Can Adjust Colors Brightness And Low Light - High Light - Horizontal - Ect....While Looking at Picture. 8. Install In REVERSE - Order Just Wipe Color Guns Lens Last. Note" - If you have Wet/Dry Vac or Fan Or Blow Dryer Take A 2 - to - 3 Inch Paint Brush And While Brushing Circuit Boards Any Dust For That Matter Blow Dust Off And Out Even Brush Speaker Cover"...ECT...Do This Before Any Cleaning 9. Just A Thought If You Ever Want to Change Color Gun Cooling Oil - Wrap All Circuit Boards With plastic Bags And then I use Bath Towol And Paper Towols To Catch As Much Spill As I Can And Then Spray With Windex To Make Dry While Blowing Air Onto Spill - Also I have Found Clear Mineral Oil Like Johnson Baby Oil To Work As Well If Not Better Then Glycol Oil. I Get For $2.50 For 20 Oz Bottle.
Nov 22, 2009 | Hitachi Televison & Video
Every thing on the tv is mostly blue
Nov 20, 2009 | Hitachi 51G500 51" Rear Projection...
Where is opening on for oil on the gearbox. lost lot of oil and now needs more
hi the oil filler is on the side remove the plug fill gear box till the oil runs just runs out of the hole put plug in
Apr 24, 2009 | Volkswagen New Beetle Cars & Trucks
Hammering Logo
100 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
