Question about Baby Lock Ellure
How to thread the GLACO serger Model FR850 - Baby Lock Ellure
Viking Huskylock 560 ED threading diagram
Viking 560 ED Huskylock Handbook
Threading Serger this may be helpful even if it is not the same model. The sequence of threading loopers is VERY important. If you thread them out of order, be prepared to be frustrated beyond belief!!! Something else (I don't think she mentioned) is to ALWAYS RAISE the presser foot when threading your machine. This is true for sergers AND sewing machines!
How to thread Serger
Nov 17, 2016 | Sewing Machines
My serger is still not working properly trhread still breaking lower and upper
Generally, thread breakage is due to incorrect threading, threaded out of order, tension too tight, or the threads are looping or hanging up on their way through the thread path. Be sure to remove ALL the threads from the machine and RAISE the presser foot while threading. Give each thread an extra little tug when going through the thread tensioners to make sure they are seated all the way. Consult the owner's manual to verify the thread paths are correct and the threads are threaded in the specified order. (If not threaded in the proper order, the serger will most likely never work satisfactorily.) Perhaps changing thread brands will help--and avoid old or bargain bin threads. Set the tension guides to the midway point between high & low numbers before testing.
If there continue to be issues, the timing may be off or a looper may be bent. Take it for service.
Make It Handmade How to Thread Your Serger Out of Order
sewing patternreview com
https://answers.yahoo.com/question/index?qid=20120705022414AAvIeRH&submit=y
Serger threads Threads Magazine Gatherings Forum Sewing Questions Answers
serger thread keeps breaking help
Mar 19, 2016 | Sewing Machines
Threading diagram for rimoldi 3 thread serger model 627
Rimoldi Serger Manual PDF And Ebook Files - DocsFiles
docsfiles.com/pdf_rimoldi_serger_manual.html
Rimoldi Serger Manual PDF Files, Manual For Rimoldi Serger honda nx 250 service ... Manual FREE Parts Crochet - Loopers RIMOLDI 8 8 Kl 327 , 527 , 627 , F27 ...Rimoldi Serger Manual Rimoldi B.27.77 Industrial Serger, 3-Thread, Nov 26, ...
rimoldi 329 threading diagram Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your rimoldi 329 threading diagram question. ... Rimoldi orion 627... rimoldi overlocker how to thread Which Model Rimoldi? ... Level 3 Expert.
rimoldi pdf - P(1) - Docs-Engine.com
Feb 05, 2016 | Sewing Machines
Have an Toyota 6600 model Serger. The knives won't cut, won't stitch and tread keeps breaking from the right hand needle...
you might want to replace the knives
you might have the serger checked for a timing problem
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Nov 05, 2013 | Sewing Machines
Glaco sewing machine manual
I am looking for a manual for a Glaco industrial sew machine model 118-2BR
Apr 01, 2013 | Sewing Machines
How to thread a serger model 934d made from brother it has 4 thread to do
You can look at youtube.com and see various sergers being threaded, also Brother at www.brother-usa.com, and www.singerco.com is quite helpful for threading a serger. All sergers pretty much thread the same way, remember always thread the 2nd from the right first. You can download your manual for free at the Brother site and enlarge the diagrams. Just take your time, it took me almost an hour to finally get it , now I can thread any machine without any problems. At first, I was very intimidated, but you will get it, really.
Mar 20, 2011 | Sewing Machines
I am having trouble threading my minilock fr850
Well, the first thing is check the thread tension. (the part that you thread it through that has a knob on it). Grab right after the tension knob and pull gently. if the thread will not pull through easily, adjust the tension to a lower setting, pull out the thread, and try again until it will pull through fairly easily.
May 06, 2009 | Sewing Machines
2nd needle/4th thread - threading confusion
With some sergers, but not many (singer 14u64 comes to mind), the top of the stitch will be an overedge that mates with the right needle thread, and the left needle thread will appear as a separate straight stitch. When you look at the underside of the stitch, the overedge will go all the way over to the left needle (the full width of the stitch). This is normal if you have this type of machine. Another stitch some sergers do (2/4 thread sergers) is a 2 thread chain thal looks like a lone straight stitch on both sides, and a 2 thread separate overedge.
As far as the threading of the takeup, it totally depends on your model. Always post your model number when you have questions as sergers vary greatly in design.
Mar 11, 2007 | Juki MO-644D Mechanical Sewing Machine
Sewing Machines Logo
27 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
