Question about ASUS 14" K42JC-C1 Laptop PC with Intel i5-460M Processor, Windows 7 Home Premium (884840689928) PC Notebook
Power cord not making contact - ASUS 14" K42JC-C1 Laptop PC with Intel i5-460M Processor, Windows 7 Home Premium (884840689928) PC Notebook
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 62 Answers
Its possible the power pin on the notebook is worn or damaged and is not connecting properly or the plug is damaged, contact a local repair to test.
Posted on Dec 20, 2013
Where can I get a replacement power cord for sponge bob air hockey table?
You will need to contact the manufacturer or have a shop make a cord if possible.
May 24, 2016 | Sport & Outdoor - Others
Model 6105. Where can I get replacement power cord?
Search the internet for:
Make + Model + the word "cord"
or contact manufacturer support.
Can also check with a local repair shop to see if they can replace the cord using parts form your original power cord.
Apr 22, 2016 | Singer Sewing Machines
Viking 980 foot pedal not making contact with machine although machine has power.
It could be lint jammed into the jack the cord plugs into. Make sure the jack and plug are both clean and free of lint. It also could be a damaged cord. If a friend has a working Viking pedal try borrowing theirs to see if it works on your machine. If not, your machine might need service.
Sep 15, 2014 | Husqvarna Viking 1
Intermittent power in 33600 coffee maker
Possibly a short in your power cord. Try plugging into a different outlet before replacing the cord. Also make sure the contacts where you plug the cord into the coffee pot are clean and not loose/broken.
Jun 04, 2014 | West Bend 33600 Coffee Maker
We used a differed sized power cord and it stopped working is it fixable?
It wouldn't hurt anything to try to use the original power cord. Its possible that the other cord just wasnt making a good contact.
Jan 03, 2011 | Homedics SS-4000 Clock Radio
X4530 InkJet Printer: printer won't turn on. Don't have ink cartridges i...
The printer should turn on even without the cartridges yet. Try this. Make sure the power cord is plugged in straight to the wall. Bypass any surge device or power strips. Unplug the power supply from the printer. It's the black box behind the printer where the power cord is plugged in. With the power cord still plugged in to the power supply, the LED around the contacts should lit solid green. If not, make sure the power cord is properly secured. If this does not help, you may have a defective power supply. If it does, insert it back in the printer in the correct position. Plug it hard just to make sure. If it does not power on automatically, press the power button. If this does not help either, I strongly suggest you contact Lexmark Technical Support for further assistance. Thanks.
May 18, 2010 | Lexmark X4530 InkJet Printer
My c4480 printer will not turn on. I checked the connection on back of the printer. I used different A/C outlets.
Try the following solutions if there are no light indications, no noise, and no movement from the printer when you turn it on.
Solution 1: Make sure you use the power cord that came with the product
Solution:
• Make sure the power cord is firmly connected to both the product and the power adapter.
Plug the power cord into a power outlet, surge protector, or power strip.
• If you are using a power strip, make sure the power strip is turned on. Or, try plugging the
product directly into a power outlet.
• Test the power outlet to make sure it is working. Plug in an appliance that you know works,
and see if the appliance has power. If not, then there might be a problem with the power
outlet.
• If you plugged the product into a switched outlet, make sure the outlet is switched on. If it
is switched to on but still does not work, then there might be a problem with the power outlet.
Cause: The product was not being used with the power cord provided.
If this did not solve the issue, try the next solution.
Solution 2: Reset the product
Solution: Turn off the product, and then unplug the power cord. Plug the power cord back in,
and then press the On button to turn on the product.
Cause: The product experienced an error.
Solution 3: Press the On button more slowly
Solution: The product might not respond if you press the On button too quickly. Press the
On button once. It might take a few minutes for the product to turn on. If you press the On button
again during this time, you might turn the product off.
Cause: You pressed the On button too quickly.
Solution 4: Contact HP to replace the power supply
Solution: Contact HP support to request a power supply for the product.
Go to: www.hp.com/support.
If prompted, choose your country/region, and then click Contact HP for information on calling
for technical support.
Cause: The power supply was not intended for use with this product or it had a mechanical
failure.
Solution 5: Contact HP support for service
Solution: If you have completed all of the steps provided in the previous solutions and are still
having a problem, contact HP support for service.
If prompted, choose your country/region, and then click Contact HP for technical support.
Cause: You might need assistance to enable the product or software to function properly.
Good Luck
Chris (ziraffa)
PS Have you changed the fuse in the plug? Just a thought..
Dec 22, 2008 | HP PhotoSmart C4480 All-in-One Printer ...
Waring DF200 Pro - Power Cord Needed
I have contacted Waring today and they state that the power cord is no longer available or manufactured. What a way to make you buy a new deep fryer. I love my DF200 and there is nothing wrong with it., just cant find a cord myself.
Aug 31, 2007 | Waring DF200 Deep Fryer
ASUS 14" K42JC-C1 Laptop PC with Intel i5-460M Processor, Windows 7 Home Premium (884840689928) PC Notebook Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
