Question about Craftsman Garden Tractor Snowblower Mounting Kit (Craftsman)
My snowblower won't go into gear when I start it.
My snowblower will not go into gear when started, it did when I put it away in the spring. Is there some trick or simple thing I am overlooking?
    Novelist:
  • 212 Answers
If your snow blower is a two stage, you can tilt unit up by handles and carefully rest unit on front auger housing. (Most units you can do this, but be careful, not all do). Then, remove bolts that hold bottom plate on snow blower, and remove bottom plate. If you follow the shift linkage down from handle to where it enters inside the unit, you will soon see how it works. Most types have the gear shifter hooked up to an apparatus that moves a rubber friction disc along a shaft, further towards the center for lower gears and vice versa. My guess is that you need to lubricate the shaft that this rubber disc slides along. Try some white lithium grease and have someone carefully move shifter throughout gear range. Be careful to not get grease on round friction plate below, this is where the rubber friction disc mates up to when drive is engaged(you don't want it slipping). Try this and let me know if you have questions. If you post actual make, model and serial# I can post pics if you like. Good luck and happy wrenching!
Posted on Nov 24, 2013
125cc Kawasaki dirt bike, cranks on first kick, idles but won't run in any gear, doesn't die out but doesn't seem to engage gear, possible problems?
Does it jerk forward when you put it into gear and die? Or you put it into gear and the bike doesn't move when you let the clutch out? Badly adjusted clutch in both cases. Worst case, you need new clutch plates and springs.
Mar 25, 2017 | kawasaki Motorcycles
How do I fix my snowblower when the wheels won,t move ahead or back
Sounds like gear on axle shaft broke shear bolt or key. Take bottom plate off base of snowblower.It is ok to tip snowblown up on front end so wheels are in air. After plate is off turn wheels and see if drive gear is moving with axle. If not key way or bolt has broken off, replace and will be back in motion.
Feb 18, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Yardworks snow blower
Leaks are normally from bad seals or ones put on engine wrong. Many snow blowers leak oil, very common. Electric start needs to be taken apart. Rust is problem most likely. When you engage the starter it kicks out the gear to turn over engine. Carefully remove the starter from engine, try to start starter an if the pinion gear does not kick out from starter disassembly it an try to clean rust away from action. Dont break wires around electric motor careful about getting dirt an rust in winding. Try to lube spring an moving parts around gear. One other thing it could be a sheared off gear on starter also.
Mar 22, 2014 | Tecumseh Garden
Electric starter will not engage when trying to start snowblower
A common problem with snowblower starters. Rust gets all around the kick out pinion gear. When you apply power the throw out gear spring or mechanism is rusted an will not operate. Take it off engine an check for broken teeth as well. Most often is rust on starter clean if you can an lube but usually there is no fix
Jan 31, 2014 | Garden
Snowblower won't start this year. Machine
Did you run the engine for about 15 minutes after you added the fuel conditioner? If not then the conditioner didn't get into the carburetor and you probably will need to take it apart and clean it again. The ethanol in today's fuel causes problems in carbs that sit
Jan 20, 2013 | Garden
My toro snowblower keeps stalling. It starts up fine, but won't run continuously.
If you haven't already, dump out gas and put fresh in it and try this, if it doesn't work you will have to clean the carb, take it apart and clean all jets ports etc and put back together and you should be Good to Blow Snow, pretty common problem with Small Engines that set half the season.
Dec 04, 2011 | Garden
Borrowed a neighbor's snowblower last night and cleared a driveway. Stored blower in unheated garage. Went to use blower today and got it started but the auger would not move. Very little wiggle in auger...
using the snow blower warmed it up ,it developed moisture in it then you put it away then it froze put a electric heater next to it but keep it away from the water[ the heater i mean].
Dec 21, 2009 | Toro Lawn Mower With Toro Power Tools
Can't start snowblower with electric start.
Our pull cord broke .came out and now can not thread it back in and when we do cannot do it tight enough . Will not work . Thanking You Linda
Dec 20, 2008 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Craftsman Garden Tractor Snowblower Mounting Kit (Craftsman) Logo
230 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
