Question about Microwave Ovens
Users Manuals for microwaves alaska MW 1000 GC
ALASKA MW 1000 GC manual
PERFAVORE IL MANALE DEL MICROONDE ALASKA MW 1000 GC
Nov 29, 2013 | Microwave Ovens
Westinghouse wmg281sf microwave Microwave (mw) less than 6 months old and after selecting start the mw makes a noise that seems to come from the light and during operation impedes the power source to the...
Hello mbz... Since the operation is impeded, the problem is more than the light bulb. This unit has an internal short, and should be under warranty for the first year. Return it. Joe
Thanks for choosing Fixya!
Dec 16, 2010 | Westinghouse Microwave Ovens
I have a Corningware MW-A-10 Microwave Browner which I have never used - could I use it in a conventional / thermofan oven?
No. The bottom of this utensil is coated in tin oxide. It is not recommended for use in any appliance other than a microwave. Tin oxide (SnO) is flammable and particles may contaminate your food. It is suggested that you use the MW-A-10 only in the microwave, or look for a different CorningWare piece that is not in the MW series.
Oct 07, 2010 | Microwave Ovens
Display on my westinghouse microwave says CHIL it wont work now
hello,
what you are to do to fix up the problem is that,put iff the the oven for some time and allow it to relax it self with out an operation, then put it on again then if it has time programming or reset button then click on an of this button for it to restart it self ,
but if this problem remain then you will have to open the the oven then trace the wire down to the panel to clean up any from of dirt or liquid around the panel then couple it back at it was with this the problem will be solve.
thank you and thanks for using fixya.
Jun 14, 2010 | Westinghouse WST3504 Microwave Oven
How many watts does Emerson MW8675W Microwave have?
Is the cubic foot size of the microwave on the name plate?? It seems that with Emerson the size relates closely to the wattage .. 0.9 cu ft is 900 watts, 1.1 cu ft is 1000 watts .. 0.7 cu ft is 700watts .. That would be the closest info I can get.
Please vote !!
May 10, 2010 | Emerson MW8675W Microwave Oven
How do I remove my ge jvm 1653 microwave?
Clean out the cabinet above the micro wave and you will find 2 or 3 bolts that secure the unit (MW) to the bottom of the cabinet. They will normally be towards the front of the cabinet.
I always put a towel or cardboard over the surface of the range for protection and a place to set the MW once it is ready to come down.
Have someone either hold the MW up by putting pressure upwards on the front of the MW or take the screws out. (don't forget to unplug the MW)
Gently let the front of the MW fall forward about 6" to 8" and lift the back of the MW upwards and it will release from a mount that is attached to the wall.
You may feel a little resistance as it might be duct taped to the exhaust going up or out the back.
Be aware that these older micro waves can be a little heavy and it is recommended that 2 people are used to do this.
Apr 09, 2010 | GE JVM1653 Microwave Oven
Replace the buttons on a kitchenaid microwave Khhs179lss-5
First, you need to uninstall the microwave (MW) from the cabinet by removing the screws that hold it in place at the top. Open the cabinet doors above the MW to locate the screws.
You will need someone to help you at this point in removing the screws and dropping the MW down. Be sure and unplug the MW before you remove the screws.
Next, you need to take the cover/shell off by locating and removing screws A/R. They are mostly across the back and side bottom.
From there on out, you should be able to methodically find and locate the various fasteners that will get to the button pad.
Dec 16, 2009 | KitchenAid KHHS179LSS Convection /...
JVM1850BH02 Microwave completely shut down, not working after...
The extreme heat has opened up one of the thermostats / thermal cutouts (TCOs) in the oven.
If it was the bottom TCO or magnetron TCO, you should be able to access them by just removing the control panel.
But if it's the one on top of the cavity, the oven will have to come out of the wall, then you need to pull of the outer cover..
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You should locate and look this over first.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
MW8107WA 1000 Watts How do I set the time? .
Cant find a manual, but on most microwaves, the clock is set by pressing the 'Clock' key, then the numbers for the time, and pressing the 'Clock' key again.
Jul 13, 2008 | Emerson MW8107WA Microwave Oven
Microwave Ovens Logo
166 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
