Question about Canon CanoScan LiDE200 Flatbed Scanner
Release the lock switch - Canon CanoScan LiDE200 Flatbed Scanner
Trunk release for 98 pont gp no power, can't find the fuse and the switch itself was checked and was good
Check trunk release solenoid for power and ground when applied from switch. If power and ground ok, then release solenoid is the problem in the trunk lock mechanism. If misssing power or ground, then electrical diagnostics will be required
May 15, 2015 | Cars & Trucks
Shift lock release
There should two brake switches located above the brake petal, one is designed to activate the rear brake lamp relay, the second would be the park/neutral safety switch which may be defective and failing to activate the shift handle release relay. You can test this by first turn the ignition key forward then jump the two wires behind the switch, you should then hear the transmission shift handle lock release. If this is heard, the switch has failed and requires replacement.
Dec 22, 2013 | 2008 Honda Civic
How do i tear apart my steering column in my 84 dodge pickup so i can change my ignition switch?
  1. NON TILT WHEEL
  2. Remove the steering wheel.
  3. Remove the turn signal switch.
  4. Unfasten the two screws that release the buzzer switch (if equipped), then remove the switch.
Fig. Fig. 2: Removing the ignition buzzer
  1. Remove the retaining screw and lift the ignition lock cylinder lamp out of the way.
Fig. Fig. 3: Ignition key lamp
  1. Remove the bearing housing.
  2. Detach the coil spring.
  3. Remove the lock plate from the shaft.
Fig. Fig. 4: Lock lever plate removal
  1. Unfasten the 2 retaining screws and lift the lock lever guide plate to expose the lock cylinder release hole.
  2. Insert the key and place the lock cylinder in the LOCK position. Remove the key.
  3. Insert a thin punch into the lock cylinder release hole and push inward to release the spring-loaded lock retainer. At the same time, pull the lock cylinder out of the column.
Fig. Fig. 5: Depress the lock plate which will expose the lock cylinder release hole
  1. Remove the 3 retaining screws and lift out the ignition switch.
To install:
  1. Position the ignition switch in the center detent position (OFF).
  2. Place the shift lever in PARK.
  3. Feed the wires down through the space between the housing and jacket. Position the switch in the housing and install the 3 retaining screws.
Fig. Fig. 6: Lock levers and spring assembly installed
  1. Place the lock cylinder in the LOCK position, and press it into place in the column. It will snap into position.
  2. The remainder of assembly is the reverse of disassembly.
Aug 14, 2011 | 1984 Dodge Pickup 4WD
I am having a problem with my printer. When I turn it on the copy light is on and the feed switch light and the alarm light and it says in the screen release the scanner lock switch and turn the power off...
Issue: ERROR LCD: Release the scanner lock switch and turn the power off and back on.
Solution: Unlock the scanner lock switch
The scanner must be unlocked before turning the unit on.
Turn off the power.
Lift the document cover.
The scanner lock switch is on the left hand side of the underside of the document cover.
Slide the scanner lock switch to the release mark (an open padlock icon).
Lock the switch before transporting.
Close the document cover.
Turn the machine on.
If machine still is not working repeat the power off / on cycle waiting 5 seconds in between.
Jan 25, 2011 | Canon MP830 All-In-One Printer
The code says i am losing voltage to the transmission due to a failed inigtion switch. Are they talking about the key switch or some module if so were is it?
an "ignition switch" is generaly the switch which is activated by the key fob.
To Remove:
  1. Disable the SIR system by disconnecting the negative battery cable.
  2. Remove the left insulator panel and knee bolster from under the instrument panel (I/P).
  3. Remove the trim covers from the steering column.
  4. Release the ignition lock cylinder locking tab by inserting an allen wrench into the hole on the top of the ignition lock cylinder housing and pushing down.
  5. Remove the ignition lock cylinder from the ignition lock cylinder housing.
  6. Disconnect the passlock and key buzzer from the ignition lock cylinder housing.
  7. Release the ignition switch tabs by inserting a J 42759 ignition switch connector release tool into the ignition lock cylinder housing.
  8. Remove the ignition switch from the ignition lock cylinder housing.
  9. Disconnect the ignition switch connector. .
when you install the new one, just make sure the ign switch is in the same position as the old one was before assembly :)
May 20, 2010 | 2002 Chevrolet TrailBlazer
It says to release the lock switch. Where is the
Look on the bottom of the unit for a sliding switch that shows an icon of an open padlock on one side, and a locked padlock on the other.
Feb 19, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
Location of ignition switch on 2006 gmc envoy
PATH: Chassis Electrical > Instruments & Switches > Ignition Switch > Removal & Installation Removal & Installation
  1. Disconnect the negative battery cable.
  2. Disable the airbag system, as outlined in the Chassis Electrical Section.
  3. Remove the hush and knee bolster.
  4. Remove the steering column trim covers.
  5. With the key installed, turn the key to the RUN position.
  6. Install a hex wrench into the hole on top of the lock cylinder housing. Push down on the hex wrench to release the tab on the lock cylinder inside the lock cylinder housing.
  1. Slide the lock cylinder out of the lock cylinder housing.
  2. Disconnect the passlock and key buzzer from the lock cylinder housing.
  3. Insert into the lock cylinder housing
Release the tabs on the ignition switch using ignition switch connector release tool J 42759
  1. Pull the ignition switch out of the lock cylinder housing.
  2. Disconnect the connector from the ignition switch.
To install:
  1. Verify the alignment of the gear in the ignition switch. If gear is not in position shown, turn gear in ignition switch until you reach the correct position.
  2. Use a screwdriver to rotate the lock cylinder housing gear counterclockwise until it hits a stop. In order to reach a stop while rotating the lock cylinder housing gear you MUST push and hold in the solenoid on the electric park lock.
  3. Connect the connector to the ignition switch.
  4. Insert the ignition switch into the lock cylinder housing. The tabs on the ignition switch MUST be seated inside the lock cylinder housing for proper installation.
  5. Use a screwdriver to rotate the lock cylinder housing gear clockwise to the start position—allowing it to spring return into the RUN position.
Use a screwdriver to rotate the lock cylinder housing gear clockwise to the START position
  1. Align the lock cylinder and install the lock cylinder into the lock cylinder housing.
  2. Connect the passlock and key buzzer into the lock housing.
  3. Install the steering column trim covers.
  4. Install the hush and knee bolster.
  5. Enable the airbag system, as outlined in the Chassis Electrical Section.
  6. Connect the negative battery cable.
Oct 12, 2009 | 2006 GMC Envoy
The battery on my laptop will not come out. The release tab is stuck and no matter what I try it will not budge. Any suggestions?
Run the computer on battery until the battery is dead. Spray the battery bay and release tab with a _LIGHT_ coat of WD-40 and try again. A small screwdriver may help to pry the release out of the way. Too much pressure can break the release. If the battery is working well, you could just live with it in place until replacement time.
Sep 01, 2009 | IBM ThinkPad T40 2373 Notebook
Lock switch
Hi muffin, Turn off the machine, open the document cover, and then release the scanner lock switch. You'll see it. Any other problems let me know. Peace, Dude
Nov 24, 2006 | Canon PIXMA MP830 All-In-One InkJet...
Canon CanoScan LiDE200 Flatbed Scanner Logo
22 people viewed this question
old marine
old marine
