How to program remote for a orion tv model # SLED2468W LED-LCD HDTV
On the remote it says LEDTV numbers underneath it says 076KOUT011
jbreth
  • 69 Answers
SOURCE: code for orion
Here you go! Hope this gets you going.
Posted on Sep 02, 2007
robotek
  • 1512 Answers
SOURCE: Need radio shack remote control code.
It will be one of these codes.
Orion 0236, 0463, 1463
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=radioshack&dv=universalremote&md=1521473in1easytouse&kw=&st=&ar=&dt=&so=&pg=3&file=others/radio_shack/152147-manual.zip
you can go to the manual direct at. Good luck
Posted on Jan 29, 2008
aprmaejun
  • 97 Answers
SOURCE: philips universal tv remote not working
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
Thisis the user's manual for a Phillips remote control. There is a list ofcodes in it. They should be rather universal. There's also instructionsas to how to program it. I believe that there is a way to program itwithout using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.Press the Channel Up button repeatedly (up to 300 times) until thedevice could be controlled changes channel. The red indicator blinks,then stays lit. If you accidentally overshoot the code required, pressthe Channel Down button to backtrack through the library until thedevice changes channel. Pressing Channel Up changes direction toforward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jul 29, 2008
davidsspa572
  • 51 Answers
SOURCE: Programming it to a Sylvanvia TV model 6420FF
Hello thank you for choosing FixYa.com for your answer my name is David.
I have found a list of codes for the rcu600m for the sylvania tv here they are
Code For Model RCU600M
Code 004 for Sylvania TV Code 006 for Sylvania TV Code 008 for Sylvania TV Code 019 for Sylvania TV Code 062 for Sylvania TV Code 068 for Sylvania TV Code 069 for Sylvania TV Code 075 for Sylvania TV Code 076 for Sylvania TV Code 077 for Sylvania TV Code 088 for Sylvania TV Code 116 for Sylvania TV Code 130 for Sylvania TV Code 132 for Sylvania TV Code 134 for Sylvania TV Code 161 for Sylvania TV Code 183 for Sylvania TV Code 196 for Sylvania TV Code 353 for Sylvania TV Thank you again for choosing Fixya.com
Posted on Nov 08, 2008
I cannot find a fuse on the CEM859A power supply board. Anybody have any ideas?
The part marked with Red circle is the fuse. As you have standbys led it would not be faulty.
26219823-wjiv2naiw2hezlgumsee5x5g-3-0.jpg If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 16, 2016 | Orion 24" Class LED-LCD 720p 60Hz HDTV,...
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
Dec 16, 2015 | RCA Televison & Video
Windows 7 driver for orion SLED2468W
Settings usually with a good USB cable, the settings on your TV when doing input go to USB where pictures and cable will show and connect from your computer to the back of TV and if doesn't work call TV company they always know the hook to this.
Aug 13, 2015 | Orion 24" Class LED-LCD 720p 60Hz HDTV,...
Is it sold with its own remote?
All TVs will have its own remote control, and is an attached device with its package. http://electronicshelponline.blogspot.com/
Jul 22, 2014 | Orion 24" Class LED-LCD 720p 60Hz HDTV,...
Recently I purchased Toshiba REGZA 47 XL 700 E is LED. Is this TV LED ?
Yes and NO your tv is a LED. To be exact it is a LED Backlight LCD TV. An LED-backlight LCD television is an LCD TV that uses LED backlighting instead of the CCFLs used in traditional LCD televisions. It is not a true LED display but is called "LED TV" by some manufacturers.[1] The use of LED backlighting has a dramatic impact, resulting in a thinner panel, less power consumption and heat dissipation, and a brighter display with better contrast levels. You can go to http://www.regza-asia.com/pdf/LEDTV/XL700/47XL700SPEC.pdf and look at the complete specs for your tv
Mar 07, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Remote code insignia 720 for comcast remote
A variety of remote control codes can be found at InsigniaProducts.com; just search for your TV model number and click Support. Also, try codes for the following brands: Orion, Emerson, Memorex, Sansui, Sylvania, Zenith.
May 27, 2010 | Insignia 42" LCD Flat-Panel HDTV
Remote code for my new insignia 19 inch tv using a verizon remote
May 10, 2010 | Insignia 37" LCD Flat-Panel HDTV
My company's remote will not work on my high def Insignia TV. They told me I have to get a code to be able to turn it on or off Need code for Model NSewL
May 08, 2010 | Insignia 42" LCD Flat-Panel HDTV
Need tv code number for 32"LCD Dynex Television for my universal
Ran a search and someone said Funai made it's codes are 0818, 0179, 0171
Someone else said it's made by Orion codes are 0236, 0179, 0463
You can try these codes hope they can help you.
Mar 25, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Tuning in SKY remote control with Orion TV
buy a better telly
looooooooooooooooser
Dec 17, 2007 | Televison & Video
Televison & Video Logo
184 people viewed this question
Top Televison & Video Experts
Electro Med Services...
