Question about Video Game Consoles & Games
How do you reset a xbox 360
Is their a manual reset button on the xbox 360 console for the game system
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 75 Answers
The best solution for you Ernie, nevigate through your dashboard to your hard drive. Press Y instead of A and select a format. This will reset your hard drive to factory, deleting everything.
Posted on Nov 27, 2013
  • 4 Answers
SOURCE: playing xbox games on my xbox 360
http://www.xbox.com/en-US/games/backwardcompatibilityfaq.htm
http://www.xbox.com/en-US/games/backwardcompatibilitygameslist.htm
Posted on Jan 10, 2008
SOURCE: put this in an xbox 360 console
The Xbox 360 Wont Read The Disk
Posted on Jan 25, 2008
SOURCE: 360 drive only reads dvds, not xbox 360 games, just says put in an xbox 360 console.
You need to flash the drive with the old drive's key; otherwise the your xbox motherboard will not allow that drive to access the gameplay engine and will not allow you to play games.
Posted on Mar 01, 2008
SOURCE: xbox 360 plays dvd but not games
you probably didn't flash the drive correctly. you can find guids how to online. its a pretty in depth process though.
Posted on May 24, 2008
SOURCE: Two XBOX 360 Games won't play on original XBOX Console?
Erm, the clue is in the name guys. ORIGINAL XBOX plays ORIGINAL XBOX games. The XBOX 360 plays games designed for the XBOX 360 plus an array of ORIGINAL games. The original console will NOT play 360 games.
Posted on Dec 22, 2008
How to reset xbox settings
If you are resetting to factory defaults use the system settings, go into storage and use the "y" button to clear the cache of all settings, if you are resetting the entire console there should be a restore to factory default button on the bottom of the system list.
Aug 11, 2014 | Microsoft Xbox 360 Console
My xbox turns but the image docent pop out
To reset Xbox 360 console display settings
  1. If there is a disc in the console, remove it.
  2. Turn off the console.
  3. Turn on the console by using your controller. To do this, press and hold the controller's Xbox Guide button until your console turns on.
    Note If multiple controllers are connected to your console, make sure that you use the player one controller.
  4. While the console is starting, press and hold the Y button and pull the right trigger at the same time. Continue holding the buttons when you see the Xbox 360 logo.
  5. The console will restart and you will see the Xbox 360 logo again.
    The console's display settings are now reset to the defaults.
May 21, 2011 | Microsoft Xbox 360 Console
No video have sound when using component connection on my xbox 360 hdmi ok. help
Your resolution settings on the xbox are too high for your currently used cables or tv. To reset your console's resolution follow these steps: To reset Xbox 360 console display settings
  3. Turn on the console by using your controller (its best to have the controller plugged into the console rather than just using the wireless). To do this, press and hold the controller's Xbox Guide button until your console turns on.
Mar 12, 2011 | Microsoft Xbox 360 Console
My xbox 360 will not let me play my games
If your Xbox 360 console can't play multiple game discs, try clearing your system cache. Here's how:On the console, go to My Xbox, and then select System Settings.Select Memory. Highlight any storage device, and then press Y on your controller.Select Clear System Cache. If Clear System Cache is not available, use the button sequence described in the following article:971755 How to clear the Xbox 360 console cache Try to play a game disc.
Dec 22, 2010 | Microsoft Xbox 360 Console
How do you turn on an xbox 360?
Simply press the big button that has green lights around in front of your console
Apr 21, 2010 | Microsoft Xbox 360 Console
My tv runs on pal50 but some games on xbox360 run on pal60 , how do i play these games on my tv
Standard definition TVs loadTOCNode(2, 'moreinformation'); If you connect your Xbox 360 console to a standard definition TV, follow these steps to set the Xbox 360 display settings to PAL 60 Hz:
  1. Turn on the Xbox 360 console.
  2. In the Xbox Dashboard, select System, and then press the A button.
  3. Select Console Settings, and then press the A button.
  4. Select Display, and then press the A button.
  5. Select PAL settings, and then press the A button.
  6. Select PAL-60, and then press the A button.
  7. When you are prompted to keep these new settings, confirm the settings, and then press the A button.
Note Some older TVs do not support PAL 60 Hz. If you do not know whether your TV supports PAL 60 Hz, contact the manufacturer of your TV or see the owner's manual.
Mar 07, 2010 | Microsoft Xbox 360 Arcade
Xbox 360 loads up then crashes then comes up on screen system error with a code e71
This is likely to be a dashboard error, possibly caused by an update. Try resetting the console. If resetting doesn't work give the xbox team a call, it will probably have to go in for repair.
To reset:
  1. With the console off, press and hold the sync up button.
  2. While holding the sync button press the power button to turn on the console
  3. Continue to hold the sync button until the Console has booted up completely.
  4. During the boot process the console should clear any failed updates, allowing you to use it normally.
Nov 04, 2009 | Microsoft Xbox 360 Console
Resetting 360 controller
Just press the sync button on your console and controller. The sync button on your console is located between the memory card slot 2 and power button. The sync button on yoiur controller is at the top.
Dec 29, 2008 | Microsoft Xbox 360 Wireless Controller
Xbox problem
A friend of mine recently experienced that same problem he just called 1-800-4MY-Xbox and they gave him a button combination to press on his Xbox 360 controller and it reset his system and fixed the problem
Nov 22, 2008 | Microsoft Xbox 360 Console
I want to reset my family settings because i lost my password like reset and the original thanks.
master reset for xbox 360...
left triger / right triger/xylbrb on the pad now left y right right
go to console setting then type this code in the sysem information ..ya with all the fancy numbers...i hope this helps...
Aug 22, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
51 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
