Question about Toshiba Computers & Internet
Can not force notebood to boot into safe mode. I have tried F8 and just continues normal boot. F2 and F12 will take me into setup. What alternative do I have to get into safe mode?
    Problem Solver:
  • 15 Answers
Pressing the F5 key will also take you into a startup menu where you'll be able to select Safe mode. If all else fails try booting the computer with an ERD Commader disc and manage it from there. You can download them for free.
Posted on Nov 24, 2013
4 Suggested Answers
SOURCE: my acer aspire one netbook tries to boot ,but then
i was able to go on the acer website on another pc and found that if when you turn on your acer and hold down ALT key while hitting F10 that will bring you to a system recovery screen. you can restore factory settings from there. It will wipe out all of your documents and pix but it does fix the problem.
Posted on Apr 22, 2009
  • 3940 Answers
SOURCE: How do I boot this Dell Inspiron 1440 in Safe Mode?
F8 at boot
or
MSCONFIG, Boot.ini tab, check safeboot (You will need undo this to boot in normal mode)
Posted on Apr 22, 2010
pcj141414
  • 62 Answers
SOURCE: I forgot my password. I have bought a recovery
Sounds like your computer is protect with a BIOS password. A BIOS password is a protection measure that can be used to stop someone powering up a computer system or making changes in some of the computers most sensitive areas. That's why the CDROM has been disabled and you can not run the recovery disk.
As a computer enthusiast, it is possible to reset the BIOS password but could be potential fatal to your notebook if you don't know what your doing.
Here is a method to bypass or remove a BIOS password.
Note: Make sure you are working in a static free environment before opening up your computer.
The simplest way to remove a BIOS password is to simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery.
If you pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password.
Open up the computer case using a screw driver and locate the flat, circular and metallic CMOS battery. It should look something like the picture above.
There are many different ways to remove a CMOS battery but the most common way on newer computers can be seen in the picture below.
The computer must not be able to get power from anywhere for this to work so make sure its unplugged from everything.
Take out the CMOS battery and wait 10 - 25 minutes before putting it back in. The reason for this wait is because the computer can still store power in its capacitors even though everything is unplugged. The waiting period allows enough time for them to discharge.
Plug everything back in, power up the computer and enter the BIOS again. If everything went well there should be no more password. In some cases, if you get weird error messages during bootup now, you will need to goto "Load BIOS Defaults" in BIOS and save the changes to fix them.
Enjoy, Have Fun and Don't Stress.
Posted on Dec 30, 2010
I don't see my question but this could be a repeat. My screen states hit F2 or F12 to start but neither of my F keys will work. Please help. Thank you.
F2 or F12 or Delete gets you into the BIOS. Why do you want to go there? To boot normally just power down and back up. Leave the Function keys alone unless you have a reason to go to the BIOS. You can create a lot of havoc in there!
The only function key you might need is F8 which you keep tapping as the computer boots. That gets you into Boot Normally, Boot with Last Known good configuration or Boot to Safe Mode.
Apr 09, 2016 | Computers & Internet
What is the f2,f8, r f12 want work? only the Ctrl+ Alt+ del that wroks
F2 usually takes you to the BIOS setup screen, you need to hit the keys as soon as you power up.
F12 selects on a Dell instant boot menu to select booting from CD-ROM, USB, etc rather than the BIOS options.
F8 goes to safe mode start up for windows, this must be done before the windows logo comes up (ie when it is a black screen).
Control - Alt -Delete Keys together can be used any time, after windows boots as it tells it to re-boot the computer, back to start up.
Jan 30, 2015 | Computers & Internet
Can not get computer to startup in safe mode even when I hit F8, I can go into setup with F2 and F12, but not boot in safe mode.
The approved method for accessing the advanced options menu of Windows is to tap the F8 key rapidly and continuously starting immediately after the initial POST screen fades. That works much better than merely pressing and holding it.
Nov 23, 2013 | Computers & Internet
System won't boot up window XP
HI Joe. It's likely you have a virus. Or could be just a corrupted section of the hard drive. The F8 is what gets you to the black screen with the differnt boot options. F2 or Del button gets you in the the BIOS or start up instrutions for the PC. F 12 will get you boot device options. The F12 or F2 needs to be pressed before it ever gets to try starting windows. So when you first power on, immediately start tapping the F12 about once a second. This should bring up a menu of which items/ device, to start from. [If you get a stuck key message just clear it and continue tapping F12 or start over] I would suggest you use the windos CD and choose the CD device to boot from, then it will recognize the CD drive. You could follow the CD start up options to peform a repair of windows. If you do a repair, then you should also perform a virus scan immediately after. If after all that, you still have issues, then it's likely the hard drive itself is bad or going bad and you should look at replaceing it. Good luck.
Dec 05, 2012 | Dell Dimension 8200 PC Desktop
F8 at boot
or
Apr 22, 2010 | Dell Computers & Internet
Will not go beyond the boot screen at startup, pressing F2 or F12 does not respond
2 ways to try
1) Boot in safe mode F8 key while booting. if possible right click C:\ properties tools open error check tick small box to fix errors and reboot Windows on reboot will check disk for errors and fix them then restart.
2) Reinstall windows in repair mode
After all drivers etc loaded windows will ask what you want to do install, repair etc press R key for repair and follow instructions
Nov 05, 2008 | HP Vectra VL400 P3 Skt 370 Motherboard...
Screen goes blank soon after switching on
Try "Safe Mode" (holding F8 key on boot and selecting "Save Mode"), then run diagnostics and an up to date (virus definitions) Anti-Virus full scan.
If Safe Mode is not accessible then you may want to consider a format and clean install by booting to your Windows (?) CD.
Sep 06, 2008 | Dell Inspiron 1300 Notebook
Toshiba sattelite A135-S2246
Hard Drive Issues most likely, Try booting to your Bios Setup utility Page...
Hold the f2 key (or delete key)(some are also f12)Check to see if your HD shows up in there, then reboot and hold the F8 key to try and get to the SAFE MODE options screen... there ya can boot it into safe mode if able to get to it..
Jun 04, 2008 | Computers & Internet
Can't Get Into Bios Setup Dell Dimention E521
Check if your keyboard is connected to USB port which is part of the motherboard and not some frontal or 'additional' USB ports you might have
May 07, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
