Question about Hoover SteamVac Spinscrub 50 Carpet Cleaner
Solution won`t spay out
When I sqeeze trigger for cleaning fluid to come out nothing happens
Sc20 trigger does not release steam
Clean jet(s) where steam comes out from . They may be clogged.
May 19, 2015 | Top Vacuums
Get Bissell little green pro heat to spray?
These units are known to clog, the water left in from the last use can harden right where the water sprays out. Try using a pin or needle to clean away the harden water. See also if the spay trigger can come apart for a thorough cleaning.
Sep 27, 2014 | Bissell 1425-1 Little Green ProHeat...
My Hoover Two Tank carpet cleaner still dispenses cleaning fluid...but only if I keep my thumb down on the 'extra solution' trigger. The main (and much easier to use) trigger doesn't work anymore. I'm...
The main trigger might have broken. This is common if the trigger is pulled too hard. You can take the handle apart on most units and replace the trigger. Usually the broken spot is where the trigger pivots.
Oct 29, 2013 | Vacuums
My Bissell proheat 2x will not stop spaying when the trigger is depressed, This happens only after the power is turned on and continues until the tank is drained or the power is cut.
I assume you mean that once the trigger is depressed it won't go back to it's original position. Like it's stuck on. I would look in that area for a broken or missing spring. I would also trace the control from the trigger to the valve that it opens and see that there isn't any build up keeping the valve open.
Nov 12, 2012 | Vacuums
Vax match won't discharge solution or water
please see the videos for troubleshooting and help:
http://support.vax.co.uk/help-videos
God bless you
Jul 24, 2012 | Vacuums
Been cleaning for 2 hours now with my Bissell Quicksteamer and on my next run i presses the water release trigger on the handle and water isnt being squirted on the carpet..why?
ran out of water? (if water) >
Is there some form of water filter?
Problem with the trigger?
Bad steam heating element or the power connection supplying the power to it?
Of could it just be tired and need a break? (grin)
Best Regards
Ck
Aug 16, 2011 | Vacuums
Water is not dispensing to clean carpet. Water
the problem is the heater is cloged you can drill it out to clean it
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
No liquid dispensed
I cleaned the water and cleaning liquid tubes and it solved the problem! Thanks.
GMC
Mar 06, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
I have a bissell spotbot. The trigger on the spay head sticks open when pressed. It will not shut off. HOw can it be fixed?
If it comes apart, see if cleaning will help. other then that you will have to replace the hose asm. part #2036665 .
Apr 20, 2008 | Vacuums
Too much water coming out.
When you press the trigger an angled piece on the end of the plastic rod attached to the trigger pushes valve button in that then releases fluid. On releasing the trigger, the valve button is supposed to be pushed back out by an internal spring. The button gets sticky with evaporated cleaning fluid and does not come back out, causing fluid to continuously run. Try taking the machine outside, fill the tank with very hot water, pull the trigger, and let the clean, hot water flow through the valve. Perhaps it will free up. If not, the valvle will have to be replace. Either way, once it is working, ALWAYS flush the entire system with hot, clean, clear water to remove any cleaning solution in the system or it will only clog again
Jan 01, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Hoover SteamVac Spinscrub 50 Carpet Cleaner Logo
44 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
