Question about Ovens
Roper bakemaster wall oven won't light
Gas was shut off and now pilot won't light
hotuna
  • 288 Answers
SOURCE: lighting a pilot light in a 30 year old roper gas range
Lift the top lid and look for a cylinder or something similar with tubing going into it there should be a button of some sort on the side. if you are lucky the button will have a red cap on it. press the button in and light the pilot inside the oven. hold the button for a minute or so until the pilot stays on. kind of like lighting a water heater.
Posted on Nov 04, 2007
bigg t
  • 640 Answers
SOURCE: vulcan oven will not stay lit
I would take out the pilot and clean it up and see what happens,also look behind the unit and see if theres a gas regulator on the gas line,if so you will see a nut on it take it off with a pair of pliers and clean as well.that valve is actually the saftey valve,when the pilot lights the flame impinges on the thermocouple and that sends a millivolt back to that valve in order to open.if none of these resolve your problem i would replace the thermocouple first as this is a cheap part and easy to put on.if you need a part # i can give it to you.let me know.
Posted on Nov 17, 2007
  • 1314 Answers
SOURCE: Roper gas oven won't work
replace the thermal coupling on the pilot make sure it is in the flame of the pilot it looks like a copper wire or tube if its bad it wont open the gas valve after the pilot heats it up
Posted on Mar 02, 2008
SOURCE: Tappan Gas Range Pilot light went out.
throw the piece of **** out! nobody seems to know how to do this, and there is zero customer service or help available. there are problems like this all over the net with no answers.
Posted on Oct 30, 2008
  • 306 Answers
SOURCE: I just cleaned by hand by magic chef wall oven and now I can't
Pilotless ignition means that a hot surface ignitor lights the oven burner. It does take a little bit of time to light the burner. Maybe 30 seconds. If you want to make sure it lights take the bottom panel out from the oven and observe the hot surface glow and the burners light. No real danger as the gas valve will only open after the hot surface ignitor has satisfied the gas valve. Let me know how it goes. ken
Posted on Jan 02, 2009
1965-70 roper wall oven gas any information on how do I turn on the oven is appreciated, the pilot is lite
I already sent you some advice...read it! It tells you to go to the Roper Wall Oven website. Roper makes alot of products and sends them out to the stores with an owner's manual in each box!
Dec 27, 2012 | Ovens
Oven won't light
ck thermal coupling see if its to far from pilot light or burnt out
Feb 18, 2012 | General Ovens
Burners work fine, pilot light in oven is on, but oven won't ignite
Make sure the thermocoupler is being heated by the pilot light flame. It could also be gunked up but you can clean it with a scouring pad, or it might need to be replaced. The thermocoupler is the most likely cause because if it isn't heated then the gas valve will not open up and no gas will flow to the burner. Since your pilot light is on then you do have gas to the valve.
Aug 28, 2011 | Ovens
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 | Ovens
Oven is very sporaditic, will heat up get to temp , go to load mode then shut off. Sometime after an hour or two sometime after 15 minutes
Your pilot light is probably blowing out. If you follow the pilot light gas line from the pilot flame back to the main valve, you will see a screw about the size of a pencil in diameter. If you take that screw out, there is another screw down in the hole you just uncovered. You have to have a very small screwdriver to reach that screw. If you turn the little screw counterclockwise, the pilot light flame will get bigger. A lot of times this will help. If you have a drafty location, the pilot will get blown out and that shuts the main gas valve off.
Sep 22, 2010 | Blodgett DFG-100 Gas Single Oven
Oven won't get hot
If your oven still uses a pilot light, it also probably has a thermocouple positioned in the pilot's flame path to detect whether if is safe to turn on the main burner. When the thermocouple fails, the oven thinks the pilot light is not lit and will not let gas flow to the primary burners. The part isn't costly (should be <$20 US) but replacing it may require some expensive labor.
Feb 11, 2010 | Frigidaire 30 in. Electric Gallery Series...
Blodgett 961-P pizza oven
Go here find what you seek.
BLODGETT
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-0183
Great Co.
Sep 30, 2008 | Blodgett 911-DOUBLE Gas Oven
Mar 02, 2008 | Ovens
Lighting a pilot light in a 30 year old roper gas range
Oct 31, 2007 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
