Question about Ultraviolet Heat Shield Covers For Causes for a Volkswagen Rabbit
Baby blowing bubbles with saliva
What are the main causes for a baby one year and one month to be blowing bubbles with her spit?
    Problem Solver:
  • 25 Answers
All babies do it
Posted on Nov 23, 2013
What causes excessive mouth watering?
A watery mouth is caused by an excess of saliva produced by the salivary glands. Normally, the salivary glands constantly produce small amounts of saliva throughout the day to keep the oral cavity moist, keep bacteria in check and assist with digestion; the body reacts by swallowing periodically.
Sometimes the salivary glands produce too much saliva, resulting in difficulty swallowing or speaking, drooling or trouble sleeping. While not typically serious or permanent, excessive production of saliva can cause embarrassment and anxiety. Those suffering from GERD are especially susceptible, as the digestive acids present in the mouth can cause the salivary glands to produce as much as two teaspoons of saliva every minute.
Watery mouth usually goes away on its own. In prolonged or especially severe cases, it may be a symptom of a more serious underlying condition such as a sinus infection or other illness.
Mar 16, 2017 | Miscellaneous
My 1989 vn commodore series 1 keeps overheating randomly
Possible leaking head gasket, this will cause bubbles. Have pressure check done.
Feb 28, 2014 | Holden Cars & Trucks
2001Buell/Cyclone motorcycle spits out oil from primary case vent hose @ 1,500RPM
its the crank case breather. either rig up an oil catch can or plug it and drain in every month...its caused from blow buy or too much oil
Dec 26, 2013 | Buell M2 Cyclone Motorcycles
I'm having a problem with my finish line flg 3.. I'm getting air bubbles blowing back up into the cup of my gun causing the paint to spit out when I try to spray.. Is there any reason this would be...
Make sure that the vents on the gun are clean and if the problem is still present then you have a problem with wear on the bushing or the needles. Air is blowing back into the cup before the needle is opening enough. So this could be a pressure, timing or wear issue.
Nov 25, 2013 | Air Tools & Compressors
Navara over heating
When you say spitting out coolant, from which area are you talking about?
If you take off the radiator cap, top up the radiator and start the engine, then is the radiator blowing bubbles out of its cap? If the answer is yes, then you likely have a blown head gasket.
Nov 15, 2012 | Nissan Cars & Trucks
Sometimes, my watch gives me crazy readings such as 221 bpm at rest for my heart beat when I use the chest strap transmitter. What causes that and how can I prevent it? Could it be my WiFi internet network...
Make sure your chest strap is a good fit so it doesn't move, not too slack. Also you need to wet the sensors so that you get a good connection. On the Garmin ones they recommend using an electrode gel but that costs money and I find spit/saliva works just as well.
Jul 25, 2011 | Sport & Outdoor - Others
Ds lite not reading game card
The main reason they do this is oxidation on the contacts. Sometimes the metal contacts on the game may even look clean but there will be a film that bonds itself to them over time that will prevent a good contact. Remember the old NES games that would have to be cleaned with a Q-tip. Same concept here. You can use a Q-tip and one of the best things that works oddly enough as is sounds is spit. Dab the Q-tip in your mouth a bit so its wet and clean the contacts on the game first, after that if the Q-tip fits do the same thing in the slot where the ds game goes into the system. If it doesn't fit you can also use a butter knife or something small covered with a piece of cloth with some saliva on it. When you put it in the slot just work it back and forth a few times. There may be a bit of dirt on the cloth or Q-tip when your done. If you don't want to use saliva you can also try Electric Contact Cleaner, or as a last resort rubbing alcohol.
Good Luck and Happy Gaming!
Jan 25, 2011 | Nintendo DS Lite Console
Heater works for a little than blows cold air , when doing 40mph hot air works
Check your coolant level. My mother was complain about the same thing last month. I checked it out for her figuring it would be a bad thermostat. Removed the radiator cap and started adding fluid to it. 2 gallon later the problem was solved. No leaks, just years of not bothering to check it let the level fall so far that there was no longer enough fluid to circulate through the system properly, it would only get warm when the cars temp hit boiling point. Then it would bubble up enough to circulate into the heater core and drop the cars temp down for a few miles the the heater would get cool again and repeat. Hoping your problem is as simple as that.
Nov 25, 2010 | 2001 Chevrolet Blazer
The coffee has started spitting out, spraying
The group seal gasket needs to be replaced.
Jul 15, 2009 | Gaggia Baby Espresso Machine
I have a logitech headset with microphone
I would suggest purchasing a new one.
Headsets are very "cheap" these days....
Any kind of saliva, spill or humidity renders them useless...
~~Jasta~~
Mar 30, 2008 | Radio Communications
Ultraviolet Heat Shield Covers For Causes for a Volkswagen Rabbit Logo
62 people viewed this question
Top Covercraft Vehicle Parts & Accessories Experts
Tenderfoot
 Ronnie
Ronnie
Level 1 Expert
ptpumpman
Are you a Covercraft Vehicle Part and Accessory Expert? Answer questions, earn points and help others
