Question about Hotpoint HSS25GFP Side by Side Refrigerator
Pops Circuit breaker when plugged in
Replaced defrost heater and when plugged back up it trips the circuit breaker
    Problem Solver:
  • 18 Answers
Have you tried plugging it in to a different outlet? You may have too many things using that same circuit. Seems worth a try - hope it helps. We found that our fridge was using the same circuit as our washer and microwave and this kept it from popping the breaker after we used another outlet.
Posted on Jun 12, 2014
2 Suggested Answers
  • 64 Answers
SOURCE: Got an APM6855 with LCD display. The defrost
This is what i found but im not sure what the age of your unit is. Hope this helps.
http://www.espares.co.uk/part/fridges-and-freezers/hygena/apm6855-0/p/1084/1037/0/1332606/1110133/refrigerator-no-frost-pro.html
Posted on Apr 24, 2011
Holmes hch6150 will not produce heat
Without having the heater to tear apart to see what is not working, you may try the following. Your heater is a 1500 watt heater and pulls about 13 amps of current. If you plug it into a recepticle that is already have load turned on, most recepticle circuits are rated for 15 amps and you have probably tripped the breaker for this circuit. Check your breaker panel to see if a breaker is tripped. If it has tripped, this will tell you your pulling to much current. Try another circuit that allows the heater to operate or find the other load on the circuit that is causing the breaker to trip. By the way to reset the breaker take the breaker to full off, this resets the trip, and then turn it back to on.
Hope this helps
Feb 13, 2015 | Heating & Cooling
No lights upstaires circuit breaker keeps tripping
Jan 2013
1) Move wire to another same-size circuit breaker to eliminate bad circuit breaker as suspect.
Do NOT increase size of breaker or it will cause fire.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
http://waterheatertimer.org/Troubleshoot-household-electricity.html
2) Put hand on each appliance and outlet to see which ones are warm. Outlet should never be warm or hot. Replace outlet. Inspect wires for loose and burned connections.
3) If the breaker is good, then add up total watts being used by checking watt rating on each device. 100 watt light bulb is 100 watts. Big screen TV has a label that shows 300 to 500 watts. Computer has label. Space heater has label showing 1500 watts. Iron has a watt rating label. Take total watts and divide by 110Volts and this will give amp load. Total watts used = 2000 and then divide 2000 by 110 volts = 18.8 amps
Compare amp load with circuit breaker.
20 amp circuit breaker has 80% safe maximum, or 16 amps.
If amp load is 18.8 amps, then 20 amp breaker is starting to get hot, and weak breaker will start tripping.
If amp load is 18.8 amps, and breaker is 15 amps, then you are overloaded and breaker is feeling the heat, and tripping because of heat.
Solution is to reduce amp load.
4) If you have short circuit, that can also trip breaker.
Unplug everything and then plug things back in slowly to see which plug or appliance is causing the problem.
Jan 18, 2013 | Electrical Supplies
. I have a Kennmore Coldspot Fridge that runs for
A 15A circuit is mainly reserved for lighting.
Even some vacuum cleaners would trip a 15A circuit breaker.
The problem isn't with your refrigerator...its with the breaker installed in the breaker box.
Check your wire size and follow these rules :
12 gauge wire can have 30A c/b max
14 gauge wire can have 20A c/b max
16 gauge wire can have 15A c/b max
So, if the wires coming out of the wall socket is 12 gauge or even 14 gauge...you should be able to swap that 15A circuit breaker with a 20A circuit breaker.
This should be plenty for your refrigerator...if it "pops a 20A"...then you've got appliance problems.
If you don't feel comfortable doing that...then get a new 15A breaker...because it sounds like the other one has gotten weak.
Hope this helps
Jul 23, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have have my sunbeam electric heater model number sfh090 for a month now and it just stopped working and wont turn on or anything! i tried leaving it unplugged for a while then plugging it back in but...
Have you tested the receptacle that the heater is/was plugged into, to make sure it's working and a circuit breaker hasn't been tripped?
If not, plug a lamp into the receptacle to see if it works. If it doesn't, check your home's circuit breaker panel for a tripped breaker. If you find one, make sure there's nothing still plugged into the offending receptacle and reset the breaker. Then, plug the heater in and turn it on. Does it trip the breaker again? If it does, there's some type of short in the electrical system of the heater. If it doesn't trip the breaker, but still doesn't work, return it to the place of purchase for a replacement. However, you must have your Proof of Purchase Receipt to do this.
Hope this helps solve your problem.
Feb 17, 2011 | Sunbeam Heating & Cooling
When plugged in, no power, dead and not functioning
Have you checked the receptacle that the heater is plugged in to, to see if it's still working? You can do this by unplugging the heater and plugging a lamp into the receptacle and turning on the lamp. If that fails, then there's a circuit breaker tripped in your home's circuit breaker panel. Check that and if you find one, make sure nothing is plugged into the offending receptacle and reset the circuit breaker.
Now, plug the heater back in. Does it work or does it trip the circuit breaker? If it trips the circuit breaker the heater has an electrical problem, that may or may not be able to be repaired.
Since you didn't mention what brand and model heater you have, there's not much more I can do to help you trouble shoot the problem.
Never the less, I hope this helps steer you in the right direction.
Feb 15, 2011 | Heating & Cooling
New defrost timer on fridge keeps tripping circuit breaker
The problem is the defrost timer you just replace on your refrigerator, you will need to check the ratings on the broken defrost timer to ensure it matches the ratings on the present defrost heater on your refrigerator, beside, you will need to test the continuity on your present defrost heater to see if the voltage rating is ok, because, if it can be tripping the breaker off while it kicks into defrost mode signify that the present defrost heater is not compatible with your refrigerator, it is either it is not well wired or fixed, and if it is, then, it means the defrost timer voltage rating is low compare to the former, you will need to get exact specification as the the broken one.
Take care.
Jul 10, 2010 | GE Refrigerators
An rec code pops up on my freezer then it trips the breaker...whats the problem?
"REC" means recovery. this is way the display shows as part of the defrost cycle. Look for a short in the heaters or some of the wiring and/or devices as part of the defrost circuit. Let me know if I can be of any further help.
Jul 06, 2010 | Hoshizaki Commercial Freezer KM-500MAH
I have a rheem 81VP2S Electric water heater it keeps tripping the circuit breaker. If I flip the breaker back on it will run for a bit then trip again. Or the breaker will trip If I I plug it in when it is...
Hi , when a breaker trips immediately, that can indicate a problem in the circuit. But the circuit stays on for a bit , then trips, so there is a problem with the heater. Could be that a thermoastat or heating element is shorted out. You can replace these items yourself, I would check the heat element first. Or there may be some corosion residue around the heater terminals.
Apr 02, 2010 | Rheem 81VP2S Point-of-Use Electric Water...
No electrical power
You must find the reason the main breaker is popping ...
I'd start by unplugging everything and remove all breakers. Turn the main on ... does it pop? If it pops here look between the breaker panel and the end of your cord. Turn the power off - reinstall the first breaker - turn power back on. What happens ... keep doing this until the main or individual breaker pops - investigate that circuit to find your short.
If you get all breakers back in with out popping anything ... start plugging stuff back in. Something is shorting somewhere.
Let me know what you find please.
thanks
a
Oct 06, 2009 | Hilltop Rv 60 AMP CIRCUIT BREAKER CARDED
Refrigerator tripping ground fault circuit
The thing you were "spinning" was the defrost timer, not a circuit breaker. The problem may be you have a shorted defrost heater; It is on a timer that runs it for 30 minutes every 8 hours of compressor use.
May 31, 2007 | Frigidaire FRT15G4B Top Freezer...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
97 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
